Latest post Fri, Jul 11 2008 12:40 AM by ravidedit. 4 replies.
  • Thu, Jul 10 2008 5:45 PM
    • ravidedit
    • Joined on Mon, Oct 24 2005
    • Los Angeles, CA
    • Posts 637
    • Points 7,950
    2 Ultra320 LVD docks on one Symphony Nitris
    Is it supported to have two Ultra 320 docks striped together?  Not daisychained but having each in single bus mode on it's own scsi controller and then striping the 24 drives together?  The set up guide isn't clear on this
    Mine: Custom Built AMD 64 3200+/socket 939 2 GB RAM Nvidia 6600gt MC 2.7 Soft Work: dozens of Mac Meridiens, PC and Mac Adrenalines, Unity, Lanshare... [view my complete system specs]
  • Thu, Jul 10 2008 10:43 PM In reply to
    Re: 2 Ultra320 LVD docks on one Symphony Nitris
     Yes, this is an approved setup.  Each chassis is set to Single Bus Mode, and you can create (up to) a  24-drive stripe set.  On xw8000's and xw8200's you can connect to the onboard LSI SCSI Controllers, using the SCSI Extender Kit from HP.  On xw8400's and xw8600's you'd need to add an ATTO UL4D Dual-Channel Controller.
  • Fri, Jul 11 2008 12:26 AM In reply to
    • ravidedit
    • Los Angeles, CA
    • Posts 637
    • Points 7,950
    thanks.  I talked to someone at Avid that said that you won't get the max 2 streams of uncompressed HD with this set up because the docks are in single bus mode as opposed to dual bus.  But we need the storage of two chasis so we have to go with this set up
  • Fri, Jul 11 2008 12:32 AM In reply to
    I'm not (completely) convinced that explanation is accurate.  With this config, you're still using dual-busses on the SCSI controller, and 1/2 drives are on each channel.  The only difference is that you'll have 12 drives per channel, instead of 6.  Unless the channels get "saturated" prior to 12 drives, this should easily provide the bandwidth.  We typically got 280MB/s + ....
  • Fri, Jul 11 2008 12:40 AM In reply to
    • ravidedit
    • Los Angeles, CA
    • Posts 637
    • Points 7,950
    yeah that's what I figured.  You can still stipe the 24 drives across the bus
