Latest post Sat, Jun 20 2009 5:49 PM by Solopost. 66 replies.
Page 2 of 5 (67 items) < Previous 1 2 3 4 5 Next >
  • Mon, Jul 28 2008 4:50 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,165
    • Points 13,375
    Re: This just in...JVC cameras updated in MC3...
     1 - There should be - I would try to search the forums as this thread is nothing to do with what you are asking (apart from it being aboue the JVC camera being added to the approved list).
    2 - None of the systems you list in your specification (outside of Liquid which I have no knowledge of [try the liquid forum]) can capture 24p.
    XW8200 2x3.2Ghz Xeon nVidia 3450 3Gb Ram Media Composer 3.0 w/Mojo 2Tb storage (mixed SCSI/SATA/1394)---------------Mac Pro 2xQuad-Core Intel 3Ghz 9Gb... [view my complete system specs]
    My Two Cents .02
    Kent Brockman
  • Sat, Aug 9 2008 2:55 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,165
    • Points 13,375
    Just got my camera back from JVC after service and 'upgrade'. Now, not being a novice to cameras, anyone know exactly HOW to output 1080 via 1394?
    I am suspect that my camera may have just went to JVC service centre for a visit - as well as the labour charges.
    My Two Cents .02
    Kent Brockman
  • Sat, Aug 9 2008 3:19 AM In reply to
    • videovic
    • Miami, Florida
    • Posts 13
    • Points 175
     Hey Solopost, now that your camera is up-graded and updated, are you able to capture HDV24p in MC3 ? Haven't sent mine in yet [hd200], would appreciate and value your input. Thanks.
    P.S.- wish I had an answer for your question.
    HP9440 portable workstation w/4GB ram 667mhz., Two SATA 7200rpm 120GB drives,XPress Pro 5.8, AVID STUDIO TOOLKIT, AVID MOJO, BORIS RED 4.2, BCC4.2AVX. [view my complete system specs]
  • Mon, Aug 11 2008 5:43 PM In reply to
    • Solopost
    • New Jersey
    • Posts 1,165
    • Points 13,375
     For those interested - the latest firmware for the 200U (my camera was upgraded too) is:
    SYS V0103
    CPU V0107
    VTR V0103
    ENC V0103
    SD CPU V0100
    SD BOOT V0100
    FPGA5 V0107
    FPGA6 V0104
    FPGA7 V0101
    And, get this... the JVC engineer (from THEIR service centre) tells me I can record 1080i to TAPE. Confused
    My Two Cents .02
    Kent Brockman
  • Mon, Aug 11 2008 8:20 PM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 709
    • Points 8,595
    Solopost:
    SYS V0103
    CPU V0107
    VTR V0103
    ENC V0103
    SD CPU V0100
    SD BOOT V0100
    FPGA5 V0107
    FPGA6 V0104
    FPGA7 V0101
    Thanks for posting those numbers...still they aren't what Avid has stated in the Supported Devices list.  Have you tried capturing from your camera to MC3 since the camera update?
    1080i captured to tape in camera would be a good trick...if it was true, which we know it isn't.  Surprise
    Media Composer v3.1.1-IE7-HP xw8000-TYAN Mobo S2663-Dual 2.8 Xeons-Hyperthreading On-3G RAM-Executed Install3GB.bat-Page File Initial/Max set to 2048/4092MB... [view my complete system specs]
    That's right...an xw8000.
  • Tue, Aug 12 2008 4:03 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,165
    • Points 13,375
     I have not.. as the primary reason my camera went to JVC was to fix a dead CCD (they did not fix) which they 'fixed' with the firmware upgrade of v105 (as they call it), this is the latest upgrade that the figures above represent.
    I took the camera back to JVC today for them to, hopefully, repair my camera and - when I visit with them in 2 days (how long they said to fix) I already have them setup to tell me how to perform the 1080i feat!!
    Also, as a rule of thumb, I do not use my camera as a playback device - that's what the HD50 deck is for (this has the latest firmware). Have not attempted 24p anything - I either shoot in HDV 29.97 or SD 30.
    My Two Cents .02
    Kent Brockman
  • Wed, Aug 13 2008 1:53 AM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 709
    • Points 8,595
    Solopost:
    Please report back when your camera is repaired...waiting with bated breath re the 1080i thang.   Stick out tongue
  • Fri, Aug 29 2008 1:11 AM In reply to
    • Rob Stowell
    • Christchurch, New Zealand
    • Posts 379
    • Points 4,195
     Any advance here?
    I assume not...
    Is it possible to import/capture 720p footage via firewire as 1080i? The HD50 and I think the HD201 can output 1080i from 720p tape. If it captured ok with sync audio from the HD50, that might work well enough for me to consider MC3.
    Otherwise it looks like FCP or Edius.
    Dell T5400 quad core xeon, 4 GBs ram, media on striped pair of 750MBs sata drives, nvidia 3700 gfx, MC 3 and Edius 5 with HDStorm. hp xw3200 1 gig ram... [view my complete system specs]
    kia ora- Rob
  • Fri, Aug 29 2008 4:07 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,165
    • Points 13,375
     No update - still waiting to get this going - the deck does output 1080 but NOT via the 1394 out.
    Got the camera from JVC with the latest firmware (reports different than what Avid support document lists). According to JVC the camera does NOT output 1080 to tape.... they did a complete 180 and did not even address that they said it could.... at this point, the camera works again.. i'm happy - back to editing on FCP.
    I just sent Avid a captured file, from the HD50, which shows audio sync (over 1 - 3 seconds [as opposed to Avid's reported 1/2 FRAME])
    My Two Cents .02
    Kent Brockman
  • Sun, Aug 31 2008 10:39 PM In reply to
    • Rob Stowell
    • Posts 379
    • Points 4,195
     Best wishes and good luck!
    A few of us waiting on the outcome of this... I'm looking at FCP and Edius as back-up "solutions" since the institution I work for has bought proHD (and I LIKE the cameras- nice pictures and not bad to shoot with.)
    Like most of us, I'd rather edit with avid, but before I drop the dollars on MC3 I need to know it's not a total waste of time.
    I gather that the HD200 CAN output 1080i via firewire- so I assumed the deck would as well. Has anyone tried that with MC? I was planning on recording to an HD drive in 1080i...
    Looing at other "workarounds" as well- but re-encoding hours and hours of m2t files doesn't seem like a good option.
    kia ora- Rob
  • Mon, Sep 1 2008 4:42 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,165
    • Points 13,375
     "I gather that the HD200 CAN output 1080i via firewire- so I assumed the deck would as well. Has anyone tried that with MC?"
    The camera will output 1080i (post February 2008 - or updated post date) via the 1394 - are you referring to the on-camera deck? Or the HD50?
    My Two Cents .02
    Kent Brockman
  • Mon, Sep 1 2008 6:48 AM In reply to
    • Rob Stowell
    • Posts 379
    • Points 4,195
     I was ahm, HOPING that the deck would do that as well. Didn't want to use a camera for capturing. But for some jobs at least, I will do it if that is the only way. Not taking anything for granted at the moment. But also hoping that footage recorded to the HD in 1080i will be capturable in MC.
    I really thought the annoucement that proHD was supported in MC3 meant - well, it was a viable option. Sigh. Not gonna tear my hair out yet- what little of it is left.
    kia ora- Rob
  • Mon, Sep 1 2008 6:59 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,165
    • Points 13,375
    I'm with you on not using the camera as a playback device - that's why they make decks.
     No need to tear out your hair yet - I have been doing that for 2 years now... luckily I have a think head of hair which grows back quick. Yes
    My Two Cents .02
    Kent Brockman
  • Thu, Sep 4 2008 11:28 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,165
    • Points 13,375
     It seems a road trip to Tewksbury may be in my future.. I will keep y'all updated.
    My Two Cents .02
    Kent Brockman
  • Thu, Sep 4 2008 12:15 PM In reply to
    • grayboy
    • Halifax, West Yorkshire
    • Posts 451
    • Points 5,840
    You  tease.
    MC ver3. HPxw8400 Intel R Xeon quad core 5150@2.66Ghz. 3Gb ram. Xp Pro 4.6 Service Pack 2Pentium 2.8 GHZ2GB Ram Matrox Millenium G550 dual display80GB... [view my complete system specs]
