Latest post Wed, Jul 9 2008 1:17 AM by Todd Sanderson. 2 replies.
  • Wed, Jul 9 2008 12:54 AM
    • Serleejus
    • Posts 187
    • Points 2,400
    Quick question regarding "Reveal File"
    Hi, we have some MXF captured footage as well as its audio as AIF on the same Raided drives, and in the BIN, when I select reveal file, it says
    Video and Audio media appear to be on different drives. Which do you want to see?
    They are BOTH on the same Raided Drive enclosure, Is this an error or can it be fixed (if I missed something?)
  • Wed, Jul 9 2008 12:55 AM In reply to
    • Serleejus
    • Posts 187
    • Points 2,400
    Re: Quick question regarding "Reveal File"
    Wait, it may be because of the MFX video and AIF audio? would it be better to capture audio as PCM with the mxf format?
    would that make a difference?
    is there a way or should i convert the AIF to PCM now? or work with the aif?
    thanks
  • Wed, Jul 9 2008 1:17 AM In reply to
    Sounds like that's the issue... it may be on the same drive, but it is in different media folders since you went different routes for video and audio.  You could indeed convert the AIF's over to PCM, but it doesn't truly matter.
    MC 3, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 4 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
