Latest post Wed, Jul 9 2008 12:29 AM by jwrl. 13 replies.
Page 1 of 1 (14 items)
  • Tue, Jul 8 2008 8:10 PM
    • aedmonson
    • Joined on Tue, Nov 15 2005
    • Portland, OR
    • Posts 43
    • Points 660
    Files don't show up in Media Tool
     I am deleting old projects from our Avid Media Composer and sometimes when I load the Media Tool, no files show up even though the media is clearly online.  I've tried deleting the database files, and letting Avid scan to rebuild.  That has usually fixed the problem in the past, but is not currently doing the trick everytime with every project.  Any suggestions?
    Avid Express Pro - PC Avid Media Composer 3.0 - PC [view my complete system specs]
  • Tue, Jul 8 2008 8:13 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,124
    • Points 73,090
    Re: Files don't show up in Media Tool
     How about File>Load Media Database, and File>refresh media directories after a database rebuild?
  • Tue, Jul 8 2008 8:31 PM In reply to
    • aedmonson
    • Portland, OR
    • Posts 43
    • Points 660
     Just tried that and still notihng when I load Media Tool.
  • Tue, Jul 8 2008 8:33 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,817
    • Points 175,155
    Are you certain that the media is associated with the project you are displaying? Does it not show up if you show all projects in the Media Tool display settings?
  • Tue, Jul 8 2008 8:42 PM In reply to
    • aedmonson
    • Portland, OR
    • Posts 43
    • Points 660
     Does the project not show up in the Media Tool display?  Yes, it does.  I'm not sure what else the media would be associated with.
  • Tue, Jul 8 2008 8:44 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,817
    • Points 175,155
    No, what I am asking is, if you choose "All Projects" when you are opening the MT, does the media you are missing show up then?
  • Tue, Jul 8 2008 9:02 PM In reply to
    • aedmonson
    • Portland, OR
    • Posts 43
    • Points 660
     Yes it does.  The project names had been changed.  Now that I'm aware of it, I see the new project names as well as the old project names in the MT display.  That seems to be the issue.
    Do you think project names shouldn't be changed, or can be changed, you just have to remember to select the old name when going through Media Tool?
  • Tue, Jul 8 2008 9:21 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 958
    • Points 11,620
    • Moderator: Avid Symphony Nitris
     There is a free app on this page called Media Database Viewer..
    http://fiool.nm.ru/progz/
    It is awesome, and I've used it to sort media when the media tool has sometimes failed me.
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Tue, Jul 8 2008 9:31 PM In reply to
    • aedmonson
    • Portland, OR
    • Posts 43
    • Points 660
     Yes, I have MDV.  It's fabulous.  Though, it also displays the old project name after in scans. Do you know why it doesn't scan the pmr files in the MXF folders?
  • Tue, Jul 8 2008 10:00 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,124
    • Points 73,090
     When you change a project name, you must keep in mind that all media captured or imported before the project name change remains linked to the old project name. All media captured or imported after the name change will be linked to the new name. So when it's time to delete, you will need to run the media tool for both project names to delete (or display) all associated media.
  • Tue, Jul 8 2008 10:19 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    Regrettably MDV is currently OMF only. It does not read MXF databases or files.
    MCA 2.8.3 on Dell 490 • 4GB Ram • Quadro FX3500 Driver 6.14.10.9185 • Avid rs146 x 2 striped as one • 2 internal 500 GB SATA drives. Edit monitor: Sony... [view my complete system specs]
    A gentle answer turns away wrath, but a harsh word stirs up anger. (Proverbs 15:1 NIV)
  • Tue, Jul 8 2008 10:28 PM In reply to
    • RUD ONE
    • Joined on Thu, Dec 14 2006
    • Milwaukee, WI
    • Posts 91
    • Points 1,080
    I'm pretty certain MDV reads MXF files. Make sure you have one of the latest versions.
    MCA v2.7.1, 3GB Ram, HP XW8200 [view my complete system specs]
    Rud One - Milwaukee, WI
  • Tue, Jul 8 2008 11:08 PM In reply to
    • Scott Carnegie
    • Posts 958
    • Points 11,620
    Paris MkVI:
    It certainly does work with MXF, make sure you have the lastet version. You might be confusing it with Media Mover that doesn't work with MXF, or the last version I had of it didn't.
  • Wed, Jul 9 2008 12:29 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,488
    • Points 40,350
    I first downloaded MDV because it supported MXF media as well as OMF.  I was previously using MediaSift, but that could only handle OMF.
