Latest post Fri, Aug 1 2008 11:31 PM by Kenton.VanNatten. 25 replies.
Page 2 of 2 (26 items) < Previous 1 2
  • Thu, Jul 24 2008 5:15 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 581
    • Points 6,925
    Re: Error Message in v3
    Both old titles and new titles.  Titletool and Marquee.
    Also, sometimes happens on importing.
    HP 8600 Symphony Nitris DX v4.0.2 Sapphire v2.081 Boris Continuum Complete v5.0.4 AvidFX (Boris Red) v5.8 Heroglyth v2.6 Vitascene v1 Adrenaline... [view my complete system specs]
  • Thu, Jul 24 2008 6:18 PM In reply to
    • Lord-Q
    • Los Angeles
    • Posts 34
    • Points 350
     The Titles were originally created on MC 2.8.3 in off line then the sequence was brought to me on the SN
    Avid Editor DS Nitris:Symphony:Media Composer
    Online/Offline Editor
    • Project Runway
    • Top Chef
    • Top Chef Masters
  • Thu, Jul 24 2008 7:01 PM In reply to
    That's what I thought....
    Titles created in MC and/or XpressPro use RGB and Symphony uses RLE.  That's why the dialog box says something about converting RGB to RLE.
    What version of Symphony are you using?
    I had seen issues (ie Access Violations) with titles created in XpressPro 5.2.4 or 5.6.4 and brought into Symphony 1.6.3, but it was fixed as of 1.6.7, I believe
  • Thu, Jul 24 2008 7:20 PM In reply to
    • Lord-Q
    • Los Angeles
    • Posts 34
    • Points 350
     I just up graded to SN 3.0. Never had the problem with 1.8. Just the new version.
    • Project Runway
    • Top Chef
    • Top Chef Masters
  • Thu, Jul 24 2008 7:29 PM In reply to
    • Lord-Q
    • Los Angeles
    • Posts 34
    • Points 350
     It just seems strange that sometimes it works and other times it doesn't. If it was a conversion issue, wouldn't it just not work at all?.It's got me stumped.
    • Project Runway
    • Top Chef
    • Top Chef Masters
  • Fri, Jul 25 2008 4:19 PM In reply to
    • stevejones
    • Joined on Tue, Feb 14 2006
    • Toronto
    • Posts 58
    • Points 760
     in my case it was all new titles created in SN 3.0, no recreating of titles from offline.
    1.8 used to run out of memory doing titles but only about once a day in my case,
    and just restarting SN used to take care of it.
    this issue in 3.0 is MUCH more frequent
    Symphony Nitris 3.0 [view my complete system specs]
  • Tue, Jul 29 2008 7:33 PM In reply to
    • Adam Cravens
    • Joined on Thu, May 1 2008
    • Burbank, CA
    • Posts 10
    • Points 110
     I have had this problem as well in 1080p 23.98 projects with both newly created titles and titles that were created in 1080p 23.98 projects in SN 1.8.3.  None of my titles are recreated from offline and the problem in SN 3.0 is "much more frequent."
    Symphony Nitris Classic 3.1.1 on 2.33 quad core XW8400/12GB RAM Quadro FX 3500 (Vista 64 Bizl) [view my complete system specs]
    Adam Cravens Online Editor Big Boss Creative
  • Fri, Aug 1 2008 6:56 PM In reply to
    • Lord-Q
    • Los Angeles
    • Posts 34
    • Points 350
    • I'm wondering if you switch to vista if this would solve the problem as I think it is a memory issue.
    Avid?
    • Project Runway
    • Top Chef
    • Top Chef Masters
  • Fri, Aug 1 2008 7:55 PM In reply to
    • rdeditor
    • Los Angeles
    • Posts 63
    • Points 860
     Yes, it's a memory issue and Avid knows about it. About a week after v3.0 was released I had the problem, sent the sequence to Avid, they were able to recreate it so it's a documented bug. I have a bin in a project I've called title creation. I now make all my titles in it before going into my main sequence and dropping them in.
    The issue comes up with titles created in the Symphony and with ones recreated from other Avid products. On our system, whenever the memory gets above about 55% this issue pops up. Unfortunately several of our sequences alone cause the memory to be far above this. In that case I have to make sub sequences of the area, open them in my title creation project, recreate the title then go back into my original sequence and cut the title back in.
    Hopefully this and a few other problems will be fixed in 3.1, whenever that will be.
    Freelance. Symphony, Symphony Nitris, DS Nitris [view my complete system specs]
    "Whenever you find yourself on the side of the majority, it is time to pause and reflect."
  • Fri, Aug 1 2008 11:16 PM In reply to
    • dlynch
    • West Hartford, CT
    • Posts 3
    • Points 55
    Earlier, I think you had posed the question, "Can I go back to 1.8?"  I had some of these similar issues after I upgraded, and also wanted to go back to 1.8.  Avid told me it was possible, so I tried to do it, and guess what?  Couldn't launch it.  Not sure what the heck happened, but I was able to re-load 3.0...which sucks ass.  I have no confidence in it....wished I didn't upgrade....
  • Fri, Aug 1 2008 11:31 PM In reply to
    dlynch:
    If you re-install the OS you can go back.  It's not a painless move if you have a ghost image of your system with 1.8 on it.
