Latest post Wed, Aug 13 2008 4:36 PM by Larry Rubin. 15 replies.
  • Mon, Jul 7 2008 9:01 PM
    • deditster
    • toronto, ontario
    • Posts 5
    • Points 90
    media composer version 3.0.1 segment mode sync lock not working
    Can someone please give this a try. I have turned on segment drag sync lock in the timeline settings tab but when I move a clip in the timeline in splice-in mode it doesn't add black to maintain sync. I know this worked up to the previous version. Any thoughts? I have tried new user settings...trashed mc states...hmmm. It will swap edits but that is not what I want. I need to leave filler.
    thanks, deditster
    media composer 3.0.1 macbook pro intel core 2 duo [view my complete system specs]
  • Mon, Jul 7 2008 9:06 PM In reply to
    • camoscato
    • Posts 4,683
    • Points 55,805
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: media composer version 3.0.1 segment mode sync lock not working
    Maybe I'm not understanding, but isn't that what's supposed to happen with Segment Splice-In?  Segment Overwrite would leave filler.
    Can you post before and after screenshots to show what's happening?
    good luck,
    Carl
  • Mon, Jul 7 2008 11:16 PM In reply to
    • deditster
    • toronto, ontario
    • Posts 5
    • Points 90
    The problem is that it is not leaving filler or the hole where say clip 1 was. it is closing the gap and all clips down the timeline are slipping out of sync. I select clip A and want to move it four clips down. older version I move it leaves filler and then pushes all clips after clip A down maintaining sync. Now it doesn't leave the filler closes the gap and all clips after clip A get slipped.and it is almost like the sync lock track selector is not responding. Are you on the latest version 3.0.1 mac? If not you might not be experiencing this. it might be a bug. How do you reprt bugs to avid?
  • Wed, Jul 9 2008 3:26 AM In reply to
    • steelborn
    • Studio City
    • Posts 116
    • Points 1,660
    My friend was just asking me about this. Does anyone have an answer yet?
    Power Mac G5 Dual 2 GHz 2 Gigs Ram ATI 9800 Pro [view my complete system specs]
  • Wed, Jul 9 2008 11:16 AM In reply to
    I never use sync locks but I just tried the following:
    - Activate Sync lock in the Timeline
    - In the Timeline Settings, under Edit, activate "Segment Drag Sync Locks"
    - In an existing sequence, with Yellow segment mode, move a clip from V2 to V1
    I've tried this on both an SN 1.8 and on MC 3.0 (both PC versions), and on the SN 1.8, it works as expected (it adds filler to the other tracks to maintain sync), whereas on MC 3.0, it appears to ignore the Segment Drag Sync Locks option, and it causes V1 to go out of sync.
    So I'd definitely say something's wrong here, and not just on the Mac.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Wed, Jul 9 2008 12:19 PM In reply to
    • camoscato
    • Posts 4,683
    • Points 55,805
      Moderator: Meridien
    I've sent this thread to escalation to see if they can reproduce the problem and figure out what's going on.  I'm going on vacation later today, but I let BLKDOG know what's going on.  If we hear anything, we'll post it back on this thread.
    Job, thanks for testing it out.
    adios,
    Carl
  • Wed, Jul 9 2008 8:54 PM In reply to
    • deditster
    • toronto, ontario
    • Posts 5
    • Points 90
    thanks for the posts. so it's not me. Will have to wait.
    dedit
  • Thu, Jul 10 2008 8:28 AM In reply to
    • pipelli
    • Posts 97
    • Points 1,250
    Segment mode sync lock not working!!!!
    IT IS TRUE!
    I use this command a lot, and for some reason now "vanished"
    POWERPC G4 DUAL 1.25 - OSX 10.4.11 - MC 3.0.1 - AXP 5.7 EDU - 2 GB RAM - MOJO COMPONENT - HD RAID INTERNAL 500GB - BETA UVW1800P I USE PAL [view my complete system specs]
  • Tue, Jul 29 2008 8:24 PM In reply to
    • videoed
    • Posts 2
    • Points 20
    It's really a bug!
    I used MC 3.0 on a MAC System and was surprised, what happened with my timeline....Bloody hell!
    The same error exists also on Windows systems, from which I made the following sreenshots:
    Timeline Settings:
    Timeline Settings
    Before Drag & Drop:
    Before Dragging
    After Drag and Drop:
     After dragging
    I hope that Avid will fix the bug shortly ... Please, Please, Please !!!!!!
    Greatings from Leipzig, Germany
    Karsten
  • Wed, Jul 30 2008 4:31 PM In reply to
    • videoed
    • Posts 2
    • Points 20
    A temporary solution of the problem is the following approach:
    1. In the timeline settings deactivate "Segment Drag Sync Locks"
    timeline settings
    2. In contrast to the usual approach mark all segments (also the empty) before shifting, which are to remain synchronous.
    3. Now shift the segments to the final position. Pay attention to the music track. He is not marked and although the tracks are coupled the new position of the segments only depends on what is marked.
    karsten
  • Thu, Jul 31 2008 9:11 PM In reply to
    • jdw
    • Posts 127
    • Points 1,580
    This is a bug in 2.8.4 as well.
    MC (2.7.3, 2.7.7) OS (10.4.9, 10.4.11) Dual (2.7 G5, Intel) Unity (4.1.6, 4.2.4) [view my complete system specs]
  • Tue, Aug 12 2008 11:18 AM In reply to
     I have the same problem. Seems really odd and very frustrating as I have just upgraded from Avid Xpress Pro and it was one of the features I was hoping to use. Also, I cant seem to be able to zoom/expand into the timeline using the up and down arrow keys on Media compoer 3.0. Can anyone help?
    thanks
  • Tue, Aug 12 2008 12:00 PM In reply to
    Richardtownsend:
    Yes, open your Keyboard settings and your Command Pallette. Choose to map menus to buttons. Click on th up arrow, then click on the hamburger menu in the lowe left corner of the timeline and find the zoom in option (also known as CTRL+[  ), then do the same for the down arrow and choose zoom out ( CTRL-] )
    Also I think MC3 comes with an XpressPro Keyboard configuration which you can activate.
  • Tue, Aug 12 2008 12:28 PM In reply to
    thanks! It worked
  • Wed, Aug 13 2008 4:28 PM In reply to
    • pierreh
    • Paris, London
    • Posts 598
    • Points 7,245
    Whilst we're on that subject, can we have a different color for Splice Mode? It currently uses the same color as "Show marked region" and it was much better to see it clearly with the vivid fushia in pre 3.0.
    Also, some folks coming from XPress (not me though) don't like the fact that you exit the Splice mode by clicking on the TC track. Maybe a new Timeline option could be added to please all of us?
    At home: MacBookPro 2.5Ghz, 4Gig Mem, Mojo At work: MacPro 2.6Ghz, 3.5Gig mem, Mojo SDi [view my complete system specs]
