Latest post Tue, Jul 8 2008 4:03 PM by tobyjt. 11 replies.
Page 1 of 1 (12 items)
  • Mon, Jul 7 2008 2:27 PM
    • tobyjt
    • Joined on Sun, Sep 2 2007
    • England
    • Posts 158
    • Points 1,915
    Losing renders when moving clip even using trim mode
    Hello, is this normal?
    When I move a clip (even using trim mode with the trim 'handles' on the outside edges of the clip) in the timeline, which has an effect applied and rendered, I need to re-render the effect.....
    WHY ? ..the precompute is still there and I haven't changed the length or the effect.
    Is this normal and if so, is it still like this in MC3 ?
    HP Dual Xeon XP Pro Workstation 'turnkey' Nitris Symphony / DS workstation / MacBook Pro Media Composer 2.8 OS X Tiger 4GB RAM/ Unity Lanshare... [view my complete system specs]
  • Mon, Jul 7 2008 2:32 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,440
    Re: Losing renders when moving clip even using trim mode
    Well, think about it. If you move the transition point, you have changed the viewable frames within the transition so, of course, the transition has to be re-rendered to reflect the new frames within it. So, this is completely normal and is that way in any NLE.
  • Tue, Jul 8 2008 10:09 AM In reply to
    • tobyjt
    • England
    • Posts 158
    • Points 1,915
    Well, duh ....but I wasn't talking about transitions, I'm talking about EFFECTS (clips with effect(s) applied)
    Moving in overwrite or insert mode usually loses the render, but I swear moving the clip/effect using trim tools used to keep the effect rendered.
  • Tue, Jul 8 2008 1:14 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,440
    Ok but same "DUH" applies. Whenever you are using the Trim tool you are, by definition, changing the displayed frames within the segment. The only exception to that would be when you are using the slide mode to move the entire segment. In all other cases, the frames within the segment are changed necessitating a new render.
  • Tue, Jul 8 2008 1:22 PM In reply to
    • tobyjt
    • England
    • Posts 158
    • Points 1,915
    well duh Stick out tongue but I WAS talking about slide mode (I described it as "using trim mode with the trim 'handles' on the outside edges of the clip"). I swear I didnt use to lose renders when doing this (but did with overwrite/insert tool). This is happening on a BCC effect..maybe that's the problem.
  • Tue, Jul 8 2008 1:51 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,140
    • Points 73,275
     Tobyit, BLKDOG is right. I often do the same slip slide trimming you refer to and re-rendering IS necessary, because you are, even if only slipping a single frame, changing the entire structure of the pre-computed file. I hope this helps you to understand what we're talking about.
  • Tue, Jul 8 2008 1:57 PM In reply to
    • tobyjt
    • England
    • Posts 158
    • Points 1,915
    Hmm.. I'm not talking about slipping, just moving the clip (with the effect) (not changing the in or out point of the clip...only moving it in the timeline)...so why cant I move a clip and retain the link to the render generated precompute!?
    EDIT: I should have said....this is for a clip on an empty (top) track.
  • Tue, Jul 8 2008 2:04 PM In reply to
    • camoscato
    • Posts 4,683
    • Points 55,805
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    tobyjt:
    What effect is on the clip?  What is on the track below?  If you're blending them in any way (superimpose, PiP, matte, etc) that'd cause the render to break if you move the clip on top.
    good luck,
    Carl
  • Tue, Jul 8 2008 2:08 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,140
    • Points 73,275
    tobyjt:
    It becomes unrendered because of it's relationship to the layers and their content underneath the layer you're working on. By moving the clip to a different position in the timeline, there is now different content under that clip then there was in it's original position. Keep in mind that the order of rendering is V1 first, segment effects, then transition effects, then up to V2 and so on to the last video layer, and then audio effects. So a pre-compute rendered on V3 for example, will also contain the video information on V2 and V1 as a part of its file.
  • Tue, Jul 8 2008 3:28 PM In reply to
    • tobyjt
    • England
    • Posts 158
    • Points 1,915
    But this effect shouldn't affect the video track below.....I have a BCC Temporal Blur effect on the clip and a color correction. I am essentially trimming/extending filler to move the clip, so why am I losing that render? All I want to do is move it.
    attached is a screen-grab of my timeline and the segment in question
  • Tue, Jul 8 2008 3:34 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,440
    Because it's on V2. The only time the render will be maintained is if you are on V1. The Avid assumes a relationship between upper and lower racks, even if no actual composite is present.
  • Tue, Jul 8 2008 4:03 PM In reply to
    • tobyjt
    • England
    • Posts 158
    • Points 1,915
    Ah...so that's why it's not working!
    silly Avid.....assuming there's relationships there.......imagine if Avid was a person....would they be paranoid? Big Smile
    thanks for clearing this up, I've moved it to V1 and all is peachy.
