Latest post Sun, Jul 6 2008 2:54 PM by MikePoglitsch. 4 replies.
  • Sun, Jul 6 2008 3:18 AM
    • MikePoglitsch
    • Naperville, IL
    • Posts 86
    • Points 1,120
    Avid Mojo and client ntsc monitor
    I just bought a used XPress Pro 5.7 [pc] with mojo (older analaog version) to go along with my Media Composer Adrenaline system.
    I assumed there was going to be a monitor out, like my Adrenaline.  Now that I have it, I realize that I can get Component out of mojo (y/c + composite out) for a beta sp deck, but now Im tapped out of connectors for an NTSC monitor that only has Composite & Y/C inputs.
    How do others connect your NTSC monitors when connecting Mojo to a component deck?  [For reference the beta sp deck is all the way in a machine room, running out of the MONITOR video output of the Deck is a possiblity but a last resort]
    Thanks for your help.
    PC MCA on an 8200, 4GB Ram, MCA 2.8 [view my complete system specs]
  • Sun, Jul 6 2008 3:23 AM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 390
    • Points 4,695
    Re: Avid Mojo and client ntsc monitor
    You could get  a router and send the signal to both the deck and the monitor, or you could go into the monitor first, and pass through to the deck.
    Good luck
    I have 10 Avid systems, DX, Meridian and DNA. 1 MCA 1.8 on 2.5 quad G5 w/ 5 Gigs of Ram, 1 Symphony Nitris DX on eight core mac pro with 4 gig ram, 1 MC... [view my complete system specs]
    Andy
  • Sun, Jul 6 2008 3:35 AM In reply to
    • MikePoglitsch
    • Naperville, IL
    • Posts 86
    • Points 1,120
    To clarify, I am putting both Avids on a 4x4 router which will also give me rs-422 control.  I will also put onto the sytem a uvw-1800 deck & ajd-455 deck.
    So both Avids will be able to feed & pull from both the dvcpro deck & beta sp [everything connected so I will never need to pull cables and 2 edit bays that can digitize or record to either deck].  But that ties up all 4 i/o's.
    I think I could hook up the Component output of MOJO to a component Distribution amp send one feed to the router and convert one to y/c and run it to the local client monitor.  Is that logical, what type of unit would convert component to y/c?  Is there a way to go firewire out and break it into y/c (for the monitor)?  Is this logical, what unit are peiple using for this?
  • Sun, Jul 6 2008 1:28 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 984
    • Points 11,640
    We have the component signal coming out of the mojo into a video DA for each channel.  One output of the DA's feeds our router, another out of the DA's feeds our component monitors.
    You can convert component to S-Video with devices like these:
    http://www.svideo.com/ypbpr2svideo.html
    http://www.hdtvsupply.com/codoco1.html?gclid=CKSCh6efq5QCFQOjFQodjiSPtA
    System #1 -Tyan i7525 MB, dual 3.2 Xeon, 4 GB Ram, Mojo, Quadro 3500, Pyro 64 FireWire, 6 TB Unity System #2 - Intel 7505VB2 MB, Dual 2.8 Xeon, 2 MB... [view my complete system specs]
  • Sun, Jul 6 2008 2:54 PM In reply to
    • MikePoglitsch
    • Naperville, IL
    • Posts 86
    • Points 1,120
     Great, thanks for the confirmation
