Latest post Sun, Jul 6 2008 6:09 AM by DC66STEPS. 6 replies.
Page 1 of 1 (7 items)
  • Sat, Jul 5 2008 6:47 AM
    • DC66STEPS
    • Los Angeles
    • Posts 71
    • Points 940
    Corrupted playback with MCv3.0 on HP Compaq nx9600 laptop
    Ok, I realize this is no longer a qualified laptop. And it may be a bit underpowered.
    I recently upgraded from Xpress Pro v5.8 to MC v3.0. I figured I'd try it on my laptop and see what happens. Everything seems to be stable and fine EXCEPT that the playback looks really weird. It scrubs through fine. But as soon as I play it, the bottom half of the picture turns into "squiggly waves." Hard to describe.
    Anybody run into this problem or have any suggestions?
    WORKSTATION 1: Avid Media Composer v3.0 --- Windows XP Pro SP2 (32-BIT) --- QuickTime Pro v7.4.5.67 --- Tyan i7525 (s2676) with dual 3.6Ghz Xeons ---... [view my complete system specs]
    D~C
  • Sat, Jul 5 2008 8:41 AM In reply to
    • camoscato
    • Posts 4,523
    • Points 54,040
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Corrupted playback with MCv3.0 on HP Compaq nx9600 laptop
    I'd start looking at the ATI video card, as this sounds like what people get when there are video card problems (it's fine on a still frame, but blank/white/wrong on playback).  Check the ReadMe for what video card drivers you should be running.
    good luck,
    Carl
  • Sat, Jul 5 2008 7:56 PM In reply to
    • DC66STEPS
    • Los Angeles
    • Posts 71
    • Points 940
    Thanks, though that is exactly where I started looking. I have the latest driver installed for the ATI x600 grafx card. But it seems that Avid is optimized for nVidia (even though my nx9600 laptop was qualified not long ago).
    I looked at the README file with no pertinent info for my ATI x600 card. I'll try running it in the Legacy Overlay mode by holding down the "L" and "O" keys at the program startup.
    The other thing I was wondering is that maybe the usable address space is the issue? I used the included "Install3GB.exe" utility to change my system to "2700."
    D~C
  • Sat, Jul 5 2008 8:05 PM In reply to
    • DC66STEPS
    • Los Angeles
    • Posts 71
    • Points 940
    OK, well the Legacy Overlay mode seems to have solved the problem; I just can't use the full-screen playback feature. :( I suppose this is better than buying a whole new laptop right now. I need to figure out the command that tells Avid to always start in Legacy Overlay mode.
    I'll continue to test things and report any other problems I may encounter with this setup.
    D~C
  • Sat, Jul 5 2008 9:05 PM In reply to
    • DC66STEPS
    • Los Angeles
    • Posts 71
    • Points 940
    I figured out that to enable the Legacy Overlay mode as always on, you should open up the console window and type: legacyoverlay on"
    I also noticed that the ATI settings allow for OpenGL and other settings. I'll experiment with that too.
    So, I get an error message at startup now (even though the program functions fine). Here's the error report I get everytime I start Avid now:
    ________ Exception Report ________________________
    Exception Code: C0000005 ACCESS_VIOLATION
    Fault Module:   01:00015E0F C:\Program Files\Avid\Avid Media Composer\ilgpu.dll
    Fault Address:  0F236E0F siILGPUHalImpl::~siILGPUHalImpl+43F
    ________ Stack Dump _________________________________________
    0F236E0F  0012F0C4  siILGPUHalImpl::~siILGPUHalImpl+43F
    0F223BD6  0012F108  CanILGPURun+76
    0F1C65AC  0012F148  ACFRegisterPlugin+4C
    003A5282  0012F24C
    003A42D5  0012F6A8
    003A2229  0012F6DC
    00978842  0012F72C  AApplicationBase::operator=+5705F2
    00978BF9  0012F764  AApplicationBase::operator=+5709A9
    0084CF98  0012FDB0  AApplicationBase::operator=+444D48
    0302969F  026B1230  AApplication::IApplication+25F
    75C08502  6D7E54A1
    AVID SYSTEM DUMP - Sat Jul 05 12:52:12 2008
    ________ Memory ________________________________________________________
    numPtrs:      00663
    numHdls:      00076
    totalPtr:     0x0003f0da (258266)
    totalHdl:     0x00000c53 (3155)
    ________ Current Program Stack _________________________________________
    7C90EB94  0012E1E8  KiFastSystemCallRet+0
    7C802532  0012E1FC  WaitForSingleObject+12
    6038F822  0012E210  PSPrintStack+82
    6031289B  0012E2A0  DmpDump+9B
    60312D39  0012E558  DmpDumpToFile+389
    60318B0D  0012EB10  SetARONotifySatinExceptionCallBack+1B1D
    6031B248  0012EB78  SetARONotifySatinExceptionCallBack+4258
    7C359C97  0012EBC0  _CxxLongjmpUnwind+EA
    7C359629  0012EBF0  _CxxExceptionFilter+1C4
    7C3598AD  0012EC48  _CxxExceptionFilter+448
    7C35994A  0012EC78  _CxxExceptionFilter+4E5
    7C359B9D  0012ECB0  _CxxFrameHandler+26
    7C9037BF  0012ECD4  RtlConvertUlongToLargeInteger+7A
    7C90378B  0012ED84  RtlConvertUlongToLargeInteger+46
    7C90EAFA  0012F0C4  KiUserExceptionDispatcher+E
    003A5282  0012F24C
    003A42D5  0012F6A8
    003A2229  0012F6DC
    75C08502  6D7E54A1
    ________ System Configuration __________________________________________
    System software: Windows NT Version 5.1 Build 2600 Service Pack 2
    Processor type: Unknown Platform
    Physical Memory: 2046 MBytes; Virtual Memory: 2699 MBytes
    User name: SysOp
    Application info: DeMille_A_Release_R56850
    ________ Processes Currently Running ___________________________________
    ________ WindowList ____________________________________________________
    ________ Binary Modules Loaded _________________________________________
    ________ Device Drivers Loaded _________________________________________
    D~C
  • Sun, Jul 6 2008 2:11 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,338
    • Points 38,415
    By all means experiment with your OpenGL settings, but the particular subset that has been implemented by ATI may not meet Avid's requirements.
    DC66STEPS:
    Without knowing for sure, an educated guess tells me that ilGPU.dll is a program module designed to access the Graphics Processor Unit on your display card.  The error message and subsequent debug dump tells you that it's failing when Avid attempts to initialise it.
  • Sun, Jul 6 2008 6:09 AM In reply to
    • DC66STEPS
    • Los Angeles
    • Posts 71
    • Points 940
    I believe you are correct.
    I experimented further with ATI's OpenGL - no luck.
    Also, I checked the Console log after re-enabling Legacy Overlay mode (for future startups) and it said this:
    I MCBootstrap::gwhoami = 30
    AVX Library V1.5
    OpenGL implementation found:
        vendor   = Brian Paul
        renderer = Mesa OffScreen16
        version  = 1.5 Mesa 6.4
        This OpenGL implementation does not support hardware texture render
        maximum render dimensions: = 1920 x 1080 at 8 bits per pixel channel
    AAF DLL loaded from : C:\Program Files\Avid\Avid Media Composer\AAFCOAPI.dll
    AAF DLL version     : 1.1.4 (45950) [0]
    AvidQTURLManager - Checking version info for LoadLibrary AvidQTUpdaterVC7
    AvidQTURLManager - AvidQTUpdaterVC7 Version (1.0) loading
    AvidQTURLManager - loaded AvidQTUpdaterVC7 successfully
    AWin32Mixer::Open inputMixerID = 0
    Win32 Mixer is using Conexant AMC Audio, Version = 5.10
    AlertableTimer Win32 constructor, default system clock resolution min = 1, max = 1000000
    Media Drives:
    (C:), OSVolID = 67, 39608224 totalKB, 11747492 freeKB, 11724548 realFreeKB
    Media Drive (E:), OSVolID = 69, 58074940 totalKB, 35572652 freeKB, 35503175 realFreeKB
    Video Drive (F:), OSVolID = 70, 732572000 totalKB, 376478920 freeKB, 375743610 realFreeKB
    COM1: error (2) The system cannot find the file specified.
    COM2: error (2) The system cannot find the file specified.
    Dongle ID: [super secret]
    System ID: [ain't tellin']
    Avid Media Composer
    In Init ARO Cmds
    The single frame player will be built for a length of 3600 frames
    The default render wait time is 50
    AudioPunchInWindow:
        Had to dump the user's previous Input Chl to Track mappings
        due to differences in configuration.
    legacyoverlay on
    Legacy Overlay Forcing turned on for future runs of the application
    D~C
