Latest post Tue, Jul 15 2008 2:25 AM by Mondo. 34 replies.
Page 1 of 3 (35 items) 1 2 3 Next >
  • Fri, Jul 4 2008 4:27 PM
    • Nik_Nak
    • Joined on Fri, Apr 25 2008
    • Posts 10
    • Points 130
    No [N] Avid Deleated My Warning over MC 3
    I spend a good amount of time creating a effective post to warn fellow editors that pro tools can't  exist on the same system as MC 3.0, I lost 8 hours because I did not now this fact. Sure this fact is buried in the 3.0 notes in the .pdf they supplied. But who would expect that Avids own products can not work togeather. It is better to inform editors before they puchase and become frustrated ex Avid editors. Be aware freedom of speech is not a feature of this forum.
  • Fri, Jul 4 2008 4:43 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,820
    • Points 175,195
    Re: Avid Deleated My Warning over MC 3
    What was the title of your Post Nik?
    Avid doesn't delete anything here. Only the moderators do. If one of us did, we had a good reason.
  • Fri, Jul 4 2008 4:48 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,820
    • Points 175,195
    Ok, I see it now. If you re-read that post, I think you can see the reason it was deleted. So, keep your tone as professional as you have in this post and things should be fine.
    On a side note, the fact that Avid NLEs and Pro Tools do not work on the same system is very well known. It has been discussed to death in all sorts of Avid communities for years. One could say that, because it is such common knowledge, it's placement in the read me is justified. So, no big announcement is really required. I's nothing new.
  • Fri, Jul 4 2008 11:28 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 951
    • Points 12,395
     Nik Nak,
    I happened to see the post you were referring to and I must say I read it and thought, "This post will probably be deleted"
    From day 1, when I began to participate in this Forum, I could see that it was a place filled with very knowledgeable people who were more than willing to share their knowledge with others.
    That is, as long as the questions were written in a civil manner.
    I have seen questions that raised negative vibes about Avid being answered in a very enlightening and level-headed manner, because the question had been asked in a civil way.
    It is not about what you want to bring up - it is about how you present it.
    Usually, if you get very hot under the collar about something, it is best to wait a little until you cool down and can post your question in a more subdued tone.
    I am sure you can see the point of this posting and will continue to use MC and Pro Tools - and get good advice from the community here.
    Regards,
    Douglas Geeked
    Avid Avid Media Composer 3/ Mojo DX,ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)4GB Kingston PC2-8500 DDR2 SDRAM,NVidia Quadro FX... [view my complete system specs]
    Douglas, Kumamoto, Japan - Avid Media Composer 3/ Mojo DX, (+Avid Liquid 7.2), http://www.gaijin-eyes.com
  • Sat, Jul 5 2008 2:41 AM In reply to
    • brutus75
    • Joined on Wed, Nov 23 2005
    • Los Angeles
    • Posts 158
    • Points 2,015
     This is a warning that I don't think is so well known regarding the new 3.0 and pro tools. Even if you put them on separate, independently bootable partitions, you run into trouble if you try to use your mojo, because protools 7.4 wants a different firmware version than MC 3.0 does.  So, until that is addressed, be prepared to not use your mojo; changing firmware each time is asking for serious hardware trouble.
    Three systems:1) Media Composer Soft with SDI Mojo, HP xw8400 with dual 2.6 ghz quad-cores and 4gig ram with 1500 graphics card. Internal SATA for boot... [view my complete system specs]
    Children are our future...unless we stop them now!
  • Sat, Jul 5 2008 12:39 PM In reply to
    • evansmalley
    • Kansas City, MO (USA)
    • Posts 265
    • Points 3,360
    Just as a side note solution to your problem, try Cakewalk Sonar Producer. Works on the same system as Avid and is really a superb audio app.
    There are some methods of editing in it that would very much improve Avid's methods too. Of course, what audio app wouldn't be improved by J-K-L as well!?
    P4 XPsp2, 2.8 GHz, 2 gig RAM, 120 gig, 2x160 gig and 80 gig drives, much other external drive'n, dual-monitor mode, 2x MOTU 2408 mk2 ASIO, Tascam US... [view my complete system specs]
  • Sat, Jul 5 2008 12:58 PM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,232
    • Points 13,760
    Why not roll back to a version of Protool;s that has the same firmware as MC3.0 or vice versa
    MC 3.0 QTime 7.4.5 win xp pro service pak 3 Core 2 Duo Quad core 2.4 4 gig ram 667mhz pci x nvidia 512mb geforce 7600 162.50 driver 1 x 7200rpm... [view my complete system specs]
  • Sun, Jul 6 2008 12:19 AM In reply to
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 476
    • Points 5,170
     i have to aggree with evan sonar producer edition is the bomb  it makes pro tools seem like a bundled program oh wait it was !!!    i do all my post on sonar pro tools is clunky and cumbersome compaired to it
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Sun, Jul 6 2008 11:23 AM In reply to
    Sounds pretty absurd to me that Pro Tools and Avid can't even exist on the same system. Is that really true?
    Maybe it's well known, but I guess I was out of the loop until now.
    P4 3.0. 2 Gig RAM, CAS 2.5. Intel 865PERL mobo. Two WD 7,200 IDE drives and two WD Raptor 10,000 SATA drives--no RAID. nVIDIA Quadro FX 1100. Two EIZO... [view my complete system specs]
  • Sun, Jul 6 2008 11:44 AM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,523
    • Points 18,325
     It is well know since ages. It is also one of the priorities the new Avid CEO mention at the release of MC3, Protools and Avid must function better together.
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows xp sp3, MC3.05 [view my complete system specs]
  • Sun, Jul 6 2008 1:59 PM In reply to
    • tompearson
    • Wayzata MN
    • Posts 476
    • Points 5,170
    im done with pro tools. sonar works so well alongside and on top of  avid  that i would never look back  avids priorities should of been 3 years ago  not trying to force us to buy another sound machine to use with protools i may be wrong but the time has come where there  just might  be more of us 1 man band edit suites that do our own sound post  than big edit  houses  i know that in minneapolis all the big dogs have left the houses and set up shop on there own leaving the big houses to use interns and contract back to the  real editors  when they need to. whats that say about the industry
    ps  sonar will use the same sound card  as avid  at the same time
    "sound blaster" what a name  for a sound card
    it's like calling a "mojo" a video explosion
  • Sun, Jul 6 2008 3:04 PM In reply to
    • evansmalley
    • Posts 265
    • Points 3,360
    funny... but Tom, but whatever explosion ya got- it'd be just in ho-hum SD
    I think even the most video-centric editor would benefit from a nice audio sweetening app, if it was quick to go in and out of it back to Avid- at least to draw volume automations on your main dialog tracks. I notice that one of the most glaring flaws in program is basic dropped dialog- when you can't make out what the actors are saying it's a big mistake to your audience- and it's so easy to fix.
    Actually you'd think The World's Best Editor would HAVE a simpler volume automation draw as an essential part of the app! Maybe even the ability to *gasp* interact with some basic 3rd party control surfaces with *gasp* FADERS that every other cheapo app in the world has figured out how to interface with!
    I can't imagine not considering that it's essential to polish the balance of your audio tracks in the final mix room with faders... and playback that's higher quality than what you can get out of a computer soundcard!
    For what it's worth as info to those of you who are hindered by the ProTools problems already- Sonar will also let you use many 3rd party hardware solutions for your audio- both control surfaces and pro hardware for audio I/O. Really makes a difference to hear the program on a truly great playback.
    I think not being able to use something better than a soundcard (without spending large) is still a huge glaring oversight in the design of Media Composer. It's inconcievable to me as an old studio guy to listen to Main Program using a soundcard! with mini-pins... oh, my...
    Did I mention that I'm really happy to upgrade from XPro?
  • Sun, Jul 6 2008 5:05 PM In reply to
    • tompearson
    • Wayzata MN
    • Posts 476
    • Points 5,170
    ho hum sd  maybe  but it still makes  me money
  • Mon, Jul 7 2008 2:15 AM In reply to
    berga:
    This must not be the case for Protools LE, correct? I mean that's part of Xpress Studio; I imagine you don't need two machines to run that.
    Anyway, it's comforting that the CEO recognizes the absurd.
  • Mon, Jul 7 2008 2:57 AM In reply to
    BobbyMurcerFan:
    Absurd is it has been like this for over a decade.
