Latest post Thu, Jul 3 2008 12:23 PM by camoscato. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jul 3 2008 8:52 AM
    • OSTrust
    • North Wales, UK
    • Posts 81
    • Points 1,020
    Exporting Avid files as Quicktime PhotoJPEG or DV or MotionJPEG
    I'm trying to export my Avid clips to a firm called Revostock who require the files to be encoded as Quicktime PhotoJPEG or Quicktime DV or Quicktime MotionJPEG, preferably the former.
    Avid has a wealth of export options and I've been unable to navigate through them to achieve my goal as above.  Any suggestions would be much appreciated.
    Avid Xpress Pro PC v 4.6 QuickTime v 6.5.1 Custom built 1Gb RAM XP Pro SP2 (Service Pack 2) Disk 0: C:\ (30 Gb) D:\ (80Gb) Disk 1... [view my complete system specs]
  • Thu, Jul 3 2008 9:01 AM In reply to
    • camoscato
    • Posts 4,393
    • Points 52,445
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Exporting Avid files as Quicktime PhotoJPEG or DV or MotionJPEG
    I'm not in front of a machine at the moment, but once you've got the export dialog box up click Options and then inside that dialog box change your export type to Quicktime Movie, and then select Custom to bring up the dialog box that allows you to change the codec.  I'm not sure about PhotoJPEG or MotionJPEG, but I'm certain that DV is a choice.
    Sorry that's a bit vague, but it's from memory.
    good luck,
    Carl
    MC 3.0, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 2 GB RAM, nVidia GeForce 7150M, Conexant HD Audio [view my complete system specs]
  • Thu, Jul 3 2008 9:56 AM In reply to
    • OSTrust
    • North Wales, UK
    • Posts 81
    • Points 1,020
     Thank you Carl for trying to help.  I've already tried your suggestion and all seems to go well until I play the resulting .mov file.  The movement is jerky for some reason, which I do not understand
  • Thu, Jul 3 2008 10:01 AM In reply to
    • camoscato
    • Posts 4,393
    • Points 52,445
      Moderator: Meridien
    How big is the resulting file?  It may be that the file is fine, but it's too big to play smoothly on your machine.  Could you try sending a small clip to your client for them to test to make sure it works?
    good luck,
    Carl
  • Thu, Jul 3 2008 11:55 AM In reply to
    • OSTrust
    • North Wales, UK
    • Posts 81
    • Points 1,020
    Yes - I'll try that.  Anyway, thanks to your original suggestion, I've explored the Avid Export options a lot more and have succeeded in getting a file accepted by Revostock - so all seems to now be well - and I've got a lot more Avid Export options to explore as well.
    Thank you again - you've made my day and solved a problem for me that has been driving me round the bend for several days - Michael
  • Thu, Jul 3 2008 12:23 PM In reply to
    • camoscato
    • Posts 4,393
    • Points 52,445
      Moderator: Meridien
    You're welcome, Michael.  I'm glad you got it sorted out.
    adios,
    Carl
