Latest post Thu, Jul 3 2008 12:17 PM by BarkinMadd. 3 replies.
  • Thu, Jul 3 2008 6:26 AM
    • BarkinMadd
    • Ontario, Canada
    • Posts 1,817
    • Points 24,215
    SonicFire Pro 4.5 Integration with MC 3.0?
    Can anyone suggest the best workflow between MC 3.0 and SonicFire Pro 4.5? Is there a way to 'Send to...' - I see in the SonicFire Pro help mention of MetaSync Publisher - as a newbe I don't fully understand the reference (I don't even know what MetaSync Publisher is used for, but I intend to read the help for it once I get a good night's sleep :)
    Camera(s) Sony HDR-FX1 \n System1: P5W-DH Deluxe Core 2 QUAD QX6700 (2.66GHz clocked to 3.17GHz), 4GB RAM (800MHz), 150Gb SATA-1 10000RPM Raptor system... [view my complete system specs]
    Steve
  • Thu, Jul 3 2008 6:46 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 821
    • Points 10,885
    Re: SonicFire Pro 4.5 Integration with MC 3.0?
     Coincidence, Steve?
    I was just sitting here preparing a SonicFire clip for MC3.
    You will not find the integration that you had between Liquid and Smartsound. (I don't remember how it was between Liquid and SonicFire - I have a feeling that the Smartsound plugin was integrated but not SonicFirePro.)
    This may not be the best workflow, but I do the following:
    Mark the in/out points on your MC audiotracks.
    Check the length of the segment you get. (Tools/timecode Window)
    Open SonicFirePro
    Open "Maestro"
    Set your Maestro length to the correct length for your MC segment.
    Find the music you want
    Choose "Insert"
    Then from your SonicFirePro timeline choose File/Export soundtrack-video
    Save to a known location on your harddrives. (I found that having a "Media for Import" folder is very useful.
    Go back to MC
    Import your SonicFirePro track to a bin of your choice.
    Double click on your track to open it in the source monitor.
    Mark an inpoint.
    Then click the Red Overwrite arrow and it should be inserted where you want it.
    It takes only a few seconds to go through all of this when you have had a bit of practice.
    Regards,
    Douglas
    Avid Avid Media Composer 3/ Mojo DX. (+ Avid Liquid 7.2),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)4GB Kingston PC2-8500 DDR2 SDRAM... [view my complete system specs]
    Douglas, Kumamoto, Japan - Avid Media Composer 3/ Mojo DX, (+Avid Liquid 7.2), http://www.gaijin-eyes.com
  • Thu, Jul 3 2008 12:03 PM In reply to
    • editzz01
    • Joined on Wed, Nov 23 2005
    • Montreal
    • Posts 728
    • Points 8,695
     Don't forget that you can also bring video into Sonicfire Pro to work with your music, so you can export a reference file or a QT to work with.
    As douglas said, the integration is not the same as with Liquid and smartsound, but Sonicfire is much more powerful than smartsound....try using the moodmapping along with oyur video, using the dialog setting sure can make mixing easier and quicker.
    Good to see another Liquid user on here.
    Regards
    Mark
    Dual 3.2 Xeon 2.0MB L2 Cache Tyan Thunder i7525 800 FSB 2 gig DDR II PNY QUADROFX 3450 74 gig, 10 000 SATA WD Raptor OS Drive 4 x 300 gig SATA Seagate... [view my complete system specs]
  • Thu, Jul 3 2008 12:17 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 1,817
    • Points 24,215
    Thank you both. I'll give both approaches a try. Also, I'll dig deeper into the whole Metasync issue. If you search through the SonicFire Pro help, you'll see that they discuss some sort of integration between MC and SFP - I just don't understand it (yet), but the approaches you've both suggested will also work just fine...
    Cheers
    Steve
