Latest post Fri, Jul 4 2008 3:43 PM by Scott Carnegie. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Jul 3 2008 4:22 AM
    • elbowroom
    • Joined on Tue, Apr 1 2008
    • Posts 11
    • Points 175
    Losing projects when upgrading to MC
     Hello,
    I am currently upgrading to MC from Xpress pro.  I have a few projects I am saving in my Xpress pro that I don't want to lose.  How can I make sure I don't delete them when I upgrade to MC?  I understand that it is best to uninstall Xpress Pro, before installing MC.  Won't I lose those projects then?  Any advice would be much appreciated.
  • Thu, Jul 3 2008 4:47 AM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 386
    • Points 4,635
    Re: Losing projects when upgrading to MC
    Save your projects on an external device - like a thumb drive or hard drive or even a CD. Once you upgrade, you can copy the bins from those projects into new projects you create on MC. Everything will work fine.
    Good Luck
    I have 10 Avid systems, DX, Meridian and DNA. 1 MCA 1.8 on 2.5 quad G5 w/ 5 Gigs of Ram, 1 Symphony Nitris DX on eight core mac pro with 4 gig ram, 1 MC... [view my complete system specs]
    Andy
  • Thu, Jul 3 2008 7:31 AM In reply to
    The creation of new projects is merely for safety. I've moved back and forth project between different versions of AXP and MC and Symphony for years.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Thu, Jul 3 2008 12:41 PM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Rankweil | Austria | Europe
    • Posts 128
    • Points 1,595
    and what about the media files on a RAID? will they get lost? (actually, I believe not, but I want to know Wink )
    regards moses
    Avid Adrenaline DNxcel | HP xw8400 - Xeon CPU @ 2.66 GHz - 3GB RAM | easyRAID 4TB | MC 3.0.5 | PDW-U1 (Firmware 2.0) | DVW-M2000P [view my complete system specs]
  • Thu, Jul 3 2008 12:57 PM In reply to
    • camoscato
    • Posts 4,520
    • Points 53,985
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Hi Moses,
    Your media files will not be lost during an upgrade.  Follow the instructions in the ReadMe file and any other instructions that came with your download or in the box, and you'll be fine.
    good luck,
    Carl
    • jwrl
    • Melbourne, Australia
    • Posts 3,333
    • Points 38,325
    No they won't, since the Avid install isn't writing to your media drives.
  • Thu, Jul 3 2008 12:58 PM In reply to
    • jwrl
    • Posts 3,333
    • Points 38,325
    SNAP, Carl!
  • Thu, Jul 3 2008 1:10 PM In reply to
    • camoscato
    • Posts 4,520
    • Points 53,985
      Moderator: Meridien
    Two separate threads we've posted simultaneously on in the last 10 minutes or so.  I'm going to lunch! Big Smile
    adios,
    Carl
  • Thu, Jul 3 2008 1:12 PM In reply to
    • jwrl
    • Posts 3,333
    • Points 38,325
    And I'm going to bed.
  • Thu, Jul 3 2008 10:55 PM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 386
    • Points 4,635
    Job ter Burg:
    Job is right. Now that I think about it, I did replace the projects during a recent upgrade. No problems at all. But I definitely would copy the projects off before doing the upgrade, and remove them and all other avid files from your system drive before upgrading
    Good Luck
    Andy
  • Fri, Jul 4 2008 3:43 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 950
    • Points 11,530
    • Moderator: Avid Symphony Nitris
    I do regular back-ups of my Avid projects folder to a seperate physical drive. Before doing anything with upgrading I always make a back-up of my Avid projects and Avid users folders, just in case. Uninstalling and installing Avid usually leaves these files alone.
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
