Latest post Tue, Jul 8 2008 3:38 PM by Scott Carnegie. 34 replies.
Page 2 of 3 (35 items) < Previous 1 2 3 Next >
  • Thu, Jul 3 2008 8:04 PM In reply to
    • Just Edit
    • Posts 22
    • Points 250
    Re: How to copy master clips into a new project and link them to that new project
    Oh, so I change the clip's tape name using the "modify source" method and THEN redigitize?   I'll give that a try.  Thanks.
  • Thu, Jul 3 2008 9:34 PM In reply to
    • Just Edit
    • Posts 22
    • Points 250
    It didn't work.  I copied a master clip from my old project into my new project, changed the tape name by selecting modify set source.  I created a new tape name and this new tape listed my new project in the project name dialog box.  Then I hit yes "set source" and "OK" I am sure I want to change it.  Then I batch captured the clip but unfortunately it remained linked to the old project.
  • Thu, Jul 3 2008 9:54 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,502
    • Points 65,685
    Kevin Klimek:
    If your clips are online, then consolidating is the only way to go.
    This is absolutely correct, if changing project linkage is your goal. If you discover another easier way to permanently and reliably change project linkage, I'd sure like to know about it.
  • Fri, Jul 4 2008 4:19 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 950
    • Points 11,530
    • Moderator: Avid Symphony Nitris
     I just confirmed this on a Nitris, not in front the of MC right now, but should still work.
    In project A, open a bin from project B, alt > drag the master clip to copy over to project A bin. Right click > modify > set source. Made a new tape name, hit OK to all of the dialogues that come up and the project association with that clip was modified to project A. This worked with both offline and online clips. In your bin heading, turn on "project" so you can see what project it is being associated with.
    No consolidating required.
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Fri, Jul 4 2008 4:55 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,502
    • Points 65,685
     Scott, I'm going to try this on Monday and I'll let you know what happens.
  • Sat, Jul 5 2008 2:26 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,337
    • Points 38,395
    I used to do this on MC in the past (about ten years ago), but I thought that it was no longer possible.  I'll be interested to see the results too.
  • Sun, Jul 6 2008 2:03 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 1,841
    • Points 24,515
     I just tried Scott's approach - it appears to work - not sure if there are any side-effects to this approach - I'm new to MC so it would probably be safer to hear from someone with more experience...
    Camera(s) Sony HDR-FX1 \n System1: P5W-DH Deluxe Core 2 QUAD QX6700 (2.66GHz clocked to 3.17GHz), 4GB RAM (800MHz), 150Gb SATA-1 10000RPM Raptor system... [view my complete system specs]
    Steve
  • Sun, Jul 6 2008 2:25 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,502
    • Points 65,685
     This is beginning to look encouraging. I'll report back what happens tomorrow.
  • Mon, Jul 7 2008 1:04 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,502
    • Points 65,685
     I have just tried Scott's procedure and it does indeed work. Project linkage changed. Thanks, Scott!
  • Mon, Jul 7 2008 1:38 PM In reply to
    • Sasquatch
    • Nottingham England
    • Posts 521
    • Points 6,240
     Is that another one to add to 'the things I've learnt' (from Scott Carnegie)
    Yes
    HPXW8400 4gb ram Nvidia FX 1500 MC 3 Adrenaline, HP XW8200 3gb ram Nvidia FX1400 MC 2.7 with SDI mojo, Avid express DV. [view my complete system specs]
    Mike Kruft. Nottingham, UK
  • Mon, Jul 7 2008 3:46 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,502
    • Points 65,685
     Scott, one additional question because I'm too busy at the moment to try this myself. What happens to the associated media file in Project B when you modify a copy of the clip into project A when you delete project A? Does the media remain on line in Project B or not?
  • Mon, Jul 7 2008 4:08 PM In reply to
    • Scott Carnegie
    • Posts 950
    • Points 11,530
    Sasquatch:
    Yes
     LOL.
    The side effect of doing this is that the project association changes not only for the clip you dupliacte but also for the original, since there is only one peice of media for it to reference. If you need both clips in both projects and want to make sure one doesn't get deleted by mistake, then that would be an appropriate time to consolidate it.
  • Mon, Jul 7 2008 4:14 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,502
    • Points 65,685
     That's what I suspected Scott. Thanks.
  • Mon, Jul 7 2008 4:32 PM In reply to
    • Just Edit
    • Posts 22
    • Points 250
    This doesn't work for me, I'm not sure what I'm doing wrong.  I copy a clip from my old project (B) into a bin in my new project (A).  I modify the clip's source and change it's tape name.  I hit OK to all of the dialogues that come up.  But nothing changes (except the tape name) the project name listed for the clip in my bin in project  A is still B.
  • Mon, Jul 7 2008 5:37 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,502
    • Points 65,685
     That's really strange, because the exact same procedure on my platform does indeed change the project name linkage as shown in the bin heading.
