Latest post Tue, Aug 5 2008 2:28 AM by Michael16oz. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Jul 2 2008 5:51 PM
    • dhudson
    • Posts 7
    • Points 125
    Phantom camera
    working with Phantom cam again.  using CINE viewer to convert the CINE files to QTs for offline  in symphony.  Does anyone have past experience with these files?  I'm looking for a "best Practice" m.o.  It looks like the "CINE viewer" makes MXF as well, but I couldn't get the avid to see those.  I have also in the past made tiff or targa stacks and imported those, but it is was neither faster or slower.
    David
  • Thu, Jul 3 2008 9:46 AM In reply to
    Re: Phantom camera
    I would probably consider cineviewer to DPX... and then on a spare fast machine use meta-fuze to MXF.. Meta-fuze creates and ALE and the MXF so there is no 'importing' and you keep trackability. You don't want to use TGA as there is simply too much data and using an Avid to create the mxf files is inefficient.
    Good luck
    M
  • Tue, Jul 15 2008 2:52 PM In reply to
    • dhudson
    • Posts 7
    • Points 125
    Re: Phantom camera
    great! I would like to try this option. looking around a I am not finding meta-fuze, do you have any info on it, where I can get it, etc.
  • Tue, Jul 15 2008 2:55 PM In reply to
    • TCurren
    • Posts 1,135
    • Points 14,665
    Re: Phantom camera
    It's part of the current system install. You might be able to download it by itself, but I'm not sure. Look in the download center under Symphony 3. (You have to have a log in)
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
  • Thu, Jul 17 2008 3:10 PM In reply to
    • dhudson
    • Posts 7
    • Points 125
    Re: Phantom camera
    I can't find anywhere any info on the use of MetaFuze.  Haven't put in new version yet ( tech staff-Yes I have  a tech/eng. staff!!- is waiting for a window of opportunity) I have searched the new software for any thing and only found install directions as well as Avid.com.
    DH
  • Wed, Jul 23 2008 6:06 PM In reply to
    • pianoman72
    • Joined on Thu, Feb 9 2006
    • Dallas, TX
    • Posts 110
    • Points 1,280
    Re: Phantom camera
    Regarding cineviewer to DPX...
    What settings?  I tried the defaults and the colorist is saying that all he can see is digital garbage.
    Here are the options:
    BYTE ORDER
    MSBF
    LSBF (default)
    DATA PACKAGING METHOD
    Filled to 32-bit Method A (default)
    Filled to 32-bit Method B
    Packed into 32-bit words
    CONVERT TO 10-bits per sample?
    YES
    NO (default)
    Convert to 10-bit log?
    YES
    NO (default)
    MC Adrenaline v3.1 OSX Leopard 10.5.5 Mac Pro 2x3 Ghz Quad-Core Intel Xeon 4GB RAM, NVIDIA Graphics Card 5TB VideoRAID [view my complete system specs]
  • Fri, Jul 25 2008 5:02 PM In reply to
    • pianoman72
    • Dallas, TX
    • Posts 110
    • Points 1,280
    Re: Phantom camera
    Well, the settings that worked were MSBF, Method A, and Convert to 10 bits-YES.
    Then, I guess for fun, I imported the DPX sequences into Apple COLOR, and rendered them as uncompressed quicktimes.  I had a problem with COLOR crashing on drives with less than 100GB free space (isn't this asking a little much?).
    In the "render" directory were my clips as quicktimes - which could then be brought into AVID, but for some reason all the quicktimes were 29.97fps, not 24fps.
    I'm disappointed that COLOR did this.  My project settings stated 23.98fps and the timeline 24fps. Actually one of my clips rendered at 60fps for no apparent reason, then I rendered again and 29.97 was the result.
    I don't get it.  Any ideas?  Metafuze sounds like a great tool, too, but I'm limited to MAC here.
  • Mon, Aug 4 2008 6:23 PM In reply to
    • pianoman72
    • Dallas, TX
    • Posts 110
    • Points 1,280
    Re: Phantom camera
    Ah, it just occurred to me that perhaps the Quicktimes contain 3:2 pulldown...Is there a way I can test this theory?
  • Mon, Aug 4 2008 10:27 PM In reply to
    • pianoman72
    • Dallas, TX
    • Posts 110
    • Points 1,280
    Re: Phantom camera
    This is interesting:
    The producer on this job just put me on with an "expert" on the Phantom camera.
    He recommended against using the VisionResearch software and said that by converting .cine files to DPX I had "locked in" to color choices and therefore not given the colorist sufficient data to work with.
    This project is such a disaster right now.  If anyone can help me, I would really appreciate it.
  • Tue, Aug 5 2008 2:28 AM In reply to
    Re: Phantom camera
    Metafuze can run on a PC without your mac avid dongle... so don't worry about being on MAC.
    The expert had a point. If you do go DPX you will end up with a 8bit syphony 422 image. If the shots are flat you could easily run into problem pushing the 'look'... if you still go this way consider trying to get the image into the right place either with the VR software (I have zero experience with this) or using some of the Metafuze controls..
    If you want best quality consider using Iridas Speedgrade XR... This is a bit of a Raw master..
    Patrick at Iridas may be able to point you to sombody in your area..
    regards
    Michael Lindsay
