Latest post Thu, Jul 24 2008 3:02 PM by Soblick. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Jul 2 2008 11:33 AM
    • Soblick
    • Joined on Mon, Nov 28 2005
    • London, UK
    • Posts 14
    • Points 170
    Symphony Nitris - multicam playback
    We have a studio show in at the moment which has a main and 8 iso's.  We want to use a 9-way-split and, as it is a quick turnaround show, we are ingesting the material at 2:1.  However, when we playback the 9-split in the source monitor, about half of the streams keep stopping and starting.  I thought that 9 streams of 2:1 may be pushing the system, so we started using quad split.... but the same thing happened.  I have tried changing the video playback quality to draft, but this also didn't help...
    Incidentally, the old favourite, "CORE_UNABLE_TO_DO", is also appearing every so often when trying to playback the 9-split.
    Anyone else had simialr issues?
    We are running Symphony Nitris (DNA based) v1.8.3 on ISIS v1.4.
    Unity ISIS v1.4 (64TB, 45 client) Symphony Nitris v1.8.3 - XW8200 and XW8400 Media Composer Adrenaline v2.8.3 - XW8200 and XW8400 DS Nitris v 1.6 [view my complete system specs]
  • Wed, Jul 2 2008 1:55 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,215
    • Points 180,120
    Re: Symphony Nitris - multicam playback
    Even though you are only viewing 4 streams, the system is processing all 9 in the group. 2:1 is one of the most difficult resolutions to use for the system because of the high quality compression needed.
    Is it any better if you make a group containing only 4 cams?
    "We do not wash our pits in the sacred pool of tears..."
  • Wed, Jul 2 2008 2:59 PM In reply to
    • Soblick
    • London, UK
    • Posts 14
    • Points 170
    Thanks BLKDOG
    You are right.  I was running a quad split from a group of 9.... duh!!  I created a new group of four (2:1 res), and the quad split worked fine.
    I've just done a few tests regarding 9-splits.
    A 9-split with 3:1 footage works fine.... no stuttering at all.  I then tried 1:1.... not a chance!!
    It looks like we may have to work at 3:1 as a compromise for these sort of shows.
    Thanks again for your input.
  • Wed, Jul 2 2008 4:23 PM In reply to
    • TCurren
    • Posts 1,135
    • Points 14,665
    Soblick:
    That is probably a result of the throughput of your drives. Symphony itself should have less trouble playing multiple streams of 1:1 as it doesn't have to handle any decompression before playback.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
  • Fri, Jul 4 2008 5:35 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 971
    • Points 11,765
    • Moderator: Avid Symphony Nitris
    Just tested 9 clips in a grouped clip at 1:1 and played back fine. Did some multi-cam cutting with it, no problems.
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Sat, Jul 5 2008 8:20 AM In reply to
    • bogie
    • Posts 199
    • Points 2,390
    Resolutions higher than 14:1(JFIF progressive) or 10:1(JFIF interlaced) are not supported for 9way Multicam on ISIS.
    Also, the 4way split is guaranteed only up to 2:1.
    cheers,
    bogie
  • Thu, Jul 24 2008 2:46 PM In reply to
    • Soblick
    • London, UK
    • Posts 14
    • Points 170
     Hi Scott
    Were you running on ISIS??
    Cheers
  • Thu, Jul 24 2008 2:58 PM In reply to
    • Scott Carnegie
    • Posts 971
    • Points 11,765
     Nope, local drives.
  • Thu, Jul 24 2008 3:02 PM In reply to
    • Soblick
    • London, UK
    • Posts 14
    • Points 170
     Cool.  Thought that didn't add up!!!
