Latest post Tue, Jul 8 2008 12:08 AM by jwrl. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Jul 1 2008 8:45 PM
    • adam-t
    • Posts 10
    • Points 140
    Problems Importing QT with Alpha
    I was trying to cleanup my drives and ended up deleting all my precompute clips by accident (still not exactly sure how). Now as I'm try to reimport some clips, the alpa channels won't import correctly. I've gone back and tried importing them fresh, but nothing seems to work. I'm just getting a solid black channel.
    AvidDV 4.6
    Thanks.
  • Tue, Jul 1 2008 8:57 PM In reply to
    Re: Problems Importing QT with Alpha
    Check your import settings.... set to "Ignore"?
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Wed, Jul 2 2008 9:00 PM In reply to
    • adam-t
    • Posts 10
    • Points 140
    No. It's set to Use Existing. And it's importing with the matte key on it. The matte's just solid black. Plus, when I started I was reimporting it so (I assume) it was usings the settings I used to import it originally.
  • Wed, Jul 2 2008 9:02 PM In reply to
    • mattman
    • Fort Myers, Florida
    • Posts 98
    • Points 1,260
     Depending on where your imports are originating from, you may need to invert existing.  This would be the case for files from After Effects etc...
    Xpress Pro 5.6.4 - Mojo, Tyan S2676 Motherboard, dual Xeon 3.2, 4 gig ddr2 ram, 4 300 gig Sata drives, raid 5, 3ware 9550SX Sata II controller, 500... [view my complete system specs]
    Mattman Life is good, eternal life is better.
  • Mon, Jul 7 2008 4:14 PM In reply to
    • adam-t
    • Posts 10
    • Points 140
    I'm pretty sure I've always used Use existing for this type of clip and I have gone back and tried it inverted. But even if it is imported backwards, I should still be getting some sort of matte besides solid black.
  • Mon, Jul 7 2008 4:54 PM In reply to
    • adam-t
    • Posts 10
    • Points 140
    SOLUTION:
    In order to reimport the files into Avid, I had to re-export the files from Juicer. This time around, I exported them with the AvidDV codec. And there lie in the problem. Apparently, I had originally exported them with another codec. With the Animation codec, the clips do import correctly.
    This is not to say that exporting them with a different codec was the problem, but exporting them with the AvidDV codec was the problem.
    And as a note, clips exported from Juicer 2 do need to be imported with the alpha inverted.
    Cheers.
  • Tue, Jul 8 2008 12:08 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,462
    • Points 40,030
    As you've just discovered, no DV codec supports an alpha channel.  Animation and uncompressed do and if you're working HD Avid's DNxHD codecs do too.
