Latest post Tue, Jul 1 2008 6:55 PM by linus210. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Jul 1 2008 2:42 AM
    • linus210
    • Joined on Tue, Jul 1 2008
    • Nelson
    • Posts 6
    • Points 65
    24p audio sync issues
    OK, so I just started a job that was shot at 24 frames a second using the RED camera.  I am using a online house to transcode the files to standard DV QT's that I have then used metacheater to create the ALE file.  Everything imported great into my 24p NTSC project, except for the audio, which is incredibly out of sync.  And at the end of the clip the audio starts looping on itself with a distinct digital blip that starts the looping.  I tried importing the quicktimes into a 30i project and the audio was just fine, and also, the quicktimes themselves are fine...so obviously it is something happening on the import of th qts in the 24p, or the 23.976 project.  Does ANYONE have any idea what could be happening?  I have tried all the different import settings in the audio tab and it is still out of sync and looping.
    Thanks in advance for any advice...
    Avid Media Composer PC Version 2.5 [view my complete system specs]
  • Tue, Jul 1 2008 2:53 PM In reply to
    Re: 24p audio sync issues
    You have to ask what is the sample rate in which the audio was recorded. Audio might have been recorded at 48.048 kHz (vs 48 kHz flat).
  • Tue, Jul 1 2008 3:14 PM In reply to
    • linus210
    • Nelson
    • Posts 6
    • Points 65
    And if it was recorded at 48.048, how do I adjust that on my import to have it come in correctly?
  • Tue, Jul 1 2008 3:22 PM In reply to
    • linus210
    • Nelson
    • Posts 6
    • Points 65
    and just for the record, checking this one clip, the audio is a full six seconds ahead of picture.
    More info here.
  • Tue, Jul 1 2008 5:09 PM In reply to
    • linus210
    • Nelson
    • Posts 6
    • Points 65
    Thanks for the link...unfortunately that doesn't seem to be working either.  Any other ideas?
  • Tue, Jul 1 2008 5:20 PM In reply to
    Well right now, it may be related to sample rates and fps. It may not. Hard to tell. Can you provide more technical info on both the RED/QT files and the audio files (frame rate, codec, sample rate, etc). Your system specs would be of great benefit also.
  • Tue, Jul 1 2008 6:25 PM In reply to
    • linus210
    • Nelson
    • Posts 6
    • Points 65
    Well, the RED files were converted at an online house to standard DV-DVC Pro NTSC.  They are at 24 fps.  The audio is an "Integer (Big Endian) codec.  I used metacheater to then create the ALE file, then did a batch import on the files.  I think it has something to do with Metacheater, as if i import them straight from the file itself, and not use metacheater, the sync is fine.  The only issue there is that the TC from the RED quicktime is non existent as it defaults to one hour.  I am assuming the audio was captured at 48k.  My system specs are Avid Media Composer v.2.5.2 on a HP xw8000.  Thanks again for your info.
  • Tue, Jul 1 2008 6:34 PM In reply to
    Open the file in QT and press Control + I. The info window will give you details about sample rate and etc.
    Do the same for the QT files. Are you sure those QT files are 24p and not 23.976p?
    Was the camera running at 24 or 23.976?
  • Tue, Jul 1 2008 6:55 PM In reply to
    • linus210
    • Nelson
    • Posts 6
    • Points 65
    FPS is 24, and the audio format is 48
