Latest post Thu, Jul 17 2008 8:42 PM by davewruck. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Jun 30 2008 7:18 PM
    • davewruck
    • Denver, CO
    • Posts 10
    • Points 150
    RS232 control on a laptop
    In the near future I'll need my nw9440 with MC3.0 and Mojo SDI to control a D-Beta deck. To do this I need RS422 for deck control. Since the laptop does not have a 232serial port, I'm looking at either a PCMCIA card with 232 serial port or a USB to Serial converter cable. Anyone have any luck, good or bad, with either of these to get deck control? Any suggestions? Thanks.
    AVID MC Soft 3.0 HP XW8600 3.25GB RAM 3.16GHz dual Xeon X5460 nVIDIA Quadro FX 4600 Internal 15k SAS drives Windows XP32 Service Pack2 Quicktime... [view my complete system specs]
    *** END TRANSMISSION ***
  • Mon, Jun 30 2008 9:51 PM In reply to
    Re: RS232 control on a laptop
    USB is better. Save your PCMCIA for storage controller or other high bandwidth devices. Keyspan is brand commonly used in the Avid world.
  • Mon, Jun 30 2008 9:54 PM In reply to
    • Rignold
    • Cape Town
    • Posts 75
    • Points 1,080
    I have used a USB to Serial converter which worked well. Used it on my desktop but should work with your laptop. Converters are dirt cheap so no harm just trying.
    If it works in Africa it'll work anywhere.
    Asus P5K3 Deluxe Motherboard, Intel Core 2 Duo E6600 Conroe 2.4GHz, 4gig DDR3 1333mhz RAM, PNY Quadro FX1700(Driver 169.47), XFX GeForce 7900GT, QT 7.45... [view my complete system specs]
    Before you judge a man walk a mile in his shoes. After that who cares, you're a mile away and you've got his shoes.
  • Mon, Jun 30 2008 10:20 PM In reply to
    "If it works in Africa it'll work anywhere ..."
    Amen to that.  I've shipped four Avid systems to Lusaka, and I'm amazed how how well they've done, and how well they've held up.
    Dave ... to answer your PM, I've never actually used the Addneda USB-Rosetta.  However, the Addenda RS232-RS422 Rosetta Stome has been the gold standard for decades for PC-based Avids.  I'm maiking an educated assumption that their USB version is equally good.
  • Mon, Jun 30 2008 10:28 PM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    davewruck:
     ....Yeah. Use the HP advanced or standard docking station. Docking Station has a COM port. You can use an RS 232 to RS 422 converter and all is well. We use our nw 9440 with base station COM port to a generic RS 422 converter and plug that into our Panasonic AG 7750's RS -422 port and all is well with Drop and Non-Drop frame VHS cassettes. Also works perfectly with Sony BetaCam SP machines.
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0.5, but had to roll back to 3.0.0. Also added Avid Studio Toolkit 5.7 running on.....HP... [view my complete system specs]
  • Mon, Jun 30 2008 10:54 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 977
    • Points 11,555
    My Dell Precision M90 does not have any serial ports, so I use an Addenda USB to 422 adapter.  It works exactly as advertised.  No problems to date.
    System #1 -Tyan i7525 MB, dual 3.2 Xeon, 4 GB Ram, Mojo, Quadro 3500, Pyro 64 FireWire, 6 TB Unity System #2 - Intel 7505VB2 MB, Dual 2.8 Xeon, 2 MB... [view my complete system specs]
  • Thu, Jul 17 2008 8:42 PM In reply to
    • davewruck
    • Denver, CO
    • Posts 10
    • Points 150
    Hey guys, a late followup here but thought it would be nice to throw this out there for anyone curious enough. Thank you all for the good suggestions - in the end I went with the Addenda RS-USB/4 for my nw9440 laptop. For $68, it seemed like the best deal around since it involved only one cable. Using the other USB to 422 connectors mentioned here required a few different plugs and cables to achieve the same goal. They may have ended up being cheaper but it was more connections to deal with on the road.  And as it turned out, installation of the Addenda was simple and nearly instantaneous! However, as told to me by the salesperson at Addenda, this is all great for XP32bit but their drivers are having comaptibility issues with Vista. So, in conclusion, the Addenda is a most exellent choice for USB to 422 control if you're on XP.
