Latest post Wed, Jul 2 2008 1:29 PM by nicozica. 8 replies.
Page 1 of 1 (9 items)
  • Mon, Jun 30 2008 4:46 AM
    • nicozica
    • Joined on Mon, Jun 30 2008
    • Ciudad de Buenos Aires, Argentina
    • Posts 10
    • Points 130
    How to make volume interpolations?
    Hey dudes! I'm a newbie in the world of Avid, the proffesional video editing sofware. My question is very simple: How can I make customizable points for audio levels?
    I've asked some of my friends but didn't come out with a clear answer.
    This is my first time in the forum, i hope you'll help me!
    Thanks in advance.
    Nicolás
    AMD Athlon 64 X2 4600+ - Asus M2N-SLI Deluxe - 2GB DDR2 667 MHz. - 320GB Western Digital SATA - eSATA Vizo 250 GB Hitachi - Sound Blaster X-Fi (Xtreme... [view my complete system specs]
  • Mon, Jun 30 2008 5:17 AM In reply to
    Re: How to make volume interpolations?
    You want to look up "Automation Gain" in the Help/Manual.  That will get you started.
    Or the old "tried and true" method, make an Add Edit on the audio track, change the volume on one side of the cut with the Audio Mixer and then dissolve between the two clips.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Mon, Jun 30 2008 10:49 PM In reply to
    • claubel
    • Joined on Thu, Dec 21 2006
    • Posts 4
    • Points 60
     From the timelines fast menu: Select Audio - Automation gain.
    After that you can use the N button on the keyboard to make keyframes on the timeline to the selected tracks. You can drag the keyframes up and down (and sidewards) to change the audio level.
  • Tue, Jul 1 2008 1:42 AM In reply to
    • nicozica
    • Posts 10
    • Points 130
    Thanks buddies! This works fine, but the problem is that all the points are moved together. It's like if they were chained. Does anybody knows how can I move keyframe points separately to change the audio levels?
    Thanks for all!
    Nico
  • Tue, Jul 1 2008 2:35 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,602
    • Points 41,660
    Magnify your timeline.  You have to be precisely on the keyframe to drag it.
  • Tue, Jul 1 2008 2:41 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,571
    • Points 78,510
     To move a keyframe left or right ALT + drag it. Marking an in and out on specific keyframes allows for global adjustment of all keyframes within the marked region.
  • Tue, Jul 1 2008 3:42 AM In reply to
    • nicozica
    • Posts 10
    • Points 130
    I'd like to thank all of you guys! This advice has my problem solved. The thing was to add in/out marks on specific keyframes.
    Thanks for all.
    God bless you,
    Nico
  • Wed, Jul 2 2008 10:21 AM In reply to
    • camoscato
    • Posts 4,788
    • Points 57,110
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Hi Nico,
    Just to clarify, if there are no in/out marks at all, you can move individual keyframes as described earlier in this thread.
    If you set in/out marks and then try to move a keyframe that is between the in and out points, all the other keyframes that are between the in and out points will move as well.
    good luck,
    Carl
  • Wed, Jul 2 2008 1:29 PM In reply to
    • nicozica
    • Posts 10
    • Points 130
    Thanks Carl, I've been watching your demos. Excellent job man! You're an Avid expert.
    I appreciate you for sharing your wisdom.
    I'm glad for being member of this community.
    Have a good day!
    Nico
