Latest post Mon, Jul 28 2008 6:51 PM by glasgoweditor. 62 replies.
Page 4 of 5 (63 items) < Previous 1 2 3 4 5 Next >
  • Tue, Jul 1 2008 8:17 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,244
    • Points 180,495
    Re: Frustrated...
    Wow a Post from LE without emoticons....!
    How'd it feel? Lighter?
    Remember, one day at a time brother, one day at a a time.....
  • Tue, Jul 1 2008 8:18 PM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    Re: Frustrated...
    BLKDOG:
     ......IdeaBig Smile
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0.5, but had to roll back to 3.0.0. Also added Avid Studio Toolkit 5.7 running on.....HP... [view my complete system specs]
  • Tue, Jul 1 2008 8:20 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,244
    • Points 180,495
    Re: Frustrated...
    Aw man...off the wagon already.
    No 30 day chip for you.....
  • Tue, Jul 1 2008 8:31 PM In reply to
    • macjaeger
    • Joined on Mon, Jun 16 2008
    • Coburg, Germany
    • Posts 211
    • Points 2,505
    Re: Frustrated...
    I'm pretty sure you can't remove sp3 if it came slipstreamed to the install disc, at least not without breaking a dozen things on the way - and that's what you wanted to avoid, right?
    I'm amazed you bought a new copy of xp although you still had your original licence keys? I don't think it'd have been illegal or immoral to borrow a friends installation disc or  download from whatever source you're able to find, as long as you have your own, genuine licence. Actually I'd still advise to install from a sp3-less install disc...
    MC 3.0 (soft) on 2.4Ghz Intel Core2Quad, 4GB, XP Pro, 2+1 Screens hooked to Nvidia GF7900GTO & Matrox DualHead2Go, 1 TB striping RAID [view my complete system specs]
    not a pro, just a teacher...
  • Tue, Jul 1 2008 8:33 PM In reply to
    Re: Frustrated...
    macjaeger:
    Yes I want this to work easily! I'll do anything to fix this...
    - SYSTEM: Mac Pro, 8 Core, MC Soft V3, Mojo SDI [view my complete system specs]
  • Tue, Jul 1 2008 8:43 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,244
    • Points 180,495
    Re: Frustrated...
    Go ahead and try SP 3 with MC 3.0. Avid is testing it now so you may have good luck with it. I'm hoping it's just the ATTO drivers that were giving you fits.
  • Tue, Jul 1 2008 8:46 PM In reply to
    Re: Frustrated...
    BLKDOG:
    OK I'll update on here as I'm doing this! Formatting the IDE drive at the moment, flashed the atto with the newest firmware then im going to install the most recent version of the driver, however there is two ? Version 3.10 and an older one, Version 3.00 - which says it (3.00) is windows certified, the other is not however.
  • Tue, Jul 1 2008 8:53 PM In reply to
    • lalittle
    • Posts 179
    • Points 2,550
    Re: Frustrated...
    Randall L Rike:
    "Why is there still no software that automatically checks your system and makes sure drivers and things ..."
    I agree.  Avid DS Nitris uses VIE (Version Info Extractor) to determine if the system meets specs, and can even output a CAB File (summary) for evaluation if necessry.  The older Meridien & ABVB systems had Avid System Test Pro.
    The first choice in the installer should be, "Run System Analysis".
     As long as the Avid installer does NOT actually "stop" you from installing the software if it detects something that it determines is not right.  That would be a disaster given that there is a LOT of hardware that runs perfectly fine with Avid even though it is not "officially" supported.  If it's just a program that gives you a "report," I'm all for it.
    Larry
  • Wed, Jul 2 2008 4:59 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,600
    • Points 41,650
    Re: Frustrated...
    BLKDOG:
    As you'll see from my configuration, I'm currently running SP3 and have been for over three weeks now.  So far I've encountered absolutely no problems.  I suspect that, as is usual with MS service packs, that it's the same as SP2 with all subsequent updates but without the conflicts between them.
  • Wed, Jul 2 2008 5:15 AM In reply to
    Re: Frustrated...
    "... Avid DS Nitris uses VIE (Version Info Extractor) ..."
    (Correcting myself) Actually, there IS a Symphony Nitris version of the VIE.  I'm not even sure where I got it, but it's dated August of 2007.  I can't seem to find anything like it on the DLC or in the KB.
  • Wed, Jul 2 2008 5:24 AM In reply to
    • dreaux
    • Joined on Mon, Mar 6 2006
    • Washington DC
    • Posts 40
    • Points 540
    Re: Frustrated...
    BLKDOG
    For some reason I am getting everyones post's sent to me my email.  Not just replies to me but all posts.
    Jim
  • Wed, Jul 2 2008 1:29 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,244
    • Points 180,495
    Re: Frustrated...
    If you mean replies in a topic to which you've posted, that is normal. You can regulate what the forum sends to you in your profile settings.
  • Wed, Jul 2 2008 2:54 PM In reply to
    • dreaux
    • Washington DC
    • Posts 40
    • Points 540
    Re: Frustrated...
    BLKDOG:
     No for some reason I am getting all posts, even the ones I have not posted.
  • Wed, Jul 2 2008 3:18 PM In reply to
    • dreaux
    • Washington DC
    • Posts 40
    • Points 540
    Re: Frustrated...
     No not just the ones I have posted. I am getting all posts.  Last night I got every post on page 3 of this thread.
    Maybe it was just a glitch.  I will see how it goes today.
  • Wed, Jul 2 2008 3:23 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,244
    • Points 180,495
    Re: Frustrated...
    Well, you would get every post from this thread because you have posted to it. The "Enable Email Subscription" button at the top of the page means that, whenever someone posts here, it will be sent to you.
