Latest post Mon, Jun 30 2008 12:25 AM by macjaeger. 8 replies.
Page 1 of 1 (9 items)
  • Sun, Jun 29 2008 12:02 AM
    • GeorgeD
    • Posts 86
    • Points 1,015
    Avid DVD troubles
     Is there a place to get tech support for Avid DVD?
    Tried hard and tried many things but it won't write a DVD volume. The simulation works OK, then I go to write a DVD volume, at the end I'm getting an error "Found PG with no video". From then on the project is corrupted.
    At first I imported QT reference files - but gave up after getting many crashes and extremely sluggish performance. Then I encoded m2v and ac3 files with Sorensen and was able to construct a project, but no luck in writing the DVD volume.
    This is a basic NTSC DVD with 4 movies and a single menu.
     Avid 3 - Vista 64
  • Sun, Jun 29 2008 12:27 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 821
    • Points 10,875
    Re: Avid DVD troubles
     GeorgeD,
    I was using DVDitPro from Sonic before I bought MC, so my experience is not directly with Avid DVD - but there should not be so much difference.
    The only times I had trouble with DVDitPro were solved by defragging the hard drive I was using for the DVD project!
    Otherwise I have a tutorial that actually describes using a QT reference file out to DVDitPro (for final burning on a Blu-ray disc).
    However it would be the same procedure for a DVD - just choose DVD instead of Blu-Ray on Page 9 of the tutorial.
    The tutorial is HERE
    Regards,
    Douglas
    Avid Avid Media Composer 3/ Mojo DX. (+ Avid Liquid 7.2),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)4GB Kingston PC2-8500 DDR2 SDRAM... [view my complete system specs]
    Douglas, Kumamoto, Japan - Avid Media Composer 3/ Mojo DX, (+Avid Liquid 7.2), http://www.gaijin-eyes.com
  • Sun, Jun 29 2008 3:46 AM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 765
    • Points 9,425
    GeorgeD:
    Avid 3 - Vista 64
    ...Uuuhhh, I don't think Avid DVD is supported in Vista 64 my friend Wink
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0. Also added Avid Studio Toolkit 5.7 running on.....HP Compaq nw 9440 Laptop PC w/2 x... [view my complete system specs]
  • Sun, Jun 29 2008 4:02 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 821
    • Points 10,875
     Good point, Laptopeditor
    However I looked over in the DVDitPro forums and found that the resident guru said that DVDitPro was working well for some people. He did not say if it was 32 or 64 bit Vista.
    Another said that there were no problems with Vista32 but Vista64 might have problems.Yet another said he was running it with Vista64 without problems!
    Of course, I am assuming that Avid DVD and DVDitPro are the same machine under the bonnet (hood).
    One difference can be in the version number. I am running DVDitPro version13A.
    I have a feeling that Avid DVD may be based on version 11A.
    There is talk about a new version of DVDitPro being released later this summer......
    In other words..... as with most software questions...... it's a jungle out there. [:'(]
    I am still leaning towards a defrag of the harddrive..... that has fixed many problems for other users who post on the DVDitPro forum.
    Regards,
    Douglas
  • Sun, Jun 29 2008 7:40 AM In reply to
    • GeorgeD
    • Posts 86
    • Points 1,015
      I switched to XP, reinstalled Avid DVD on XP, moved to a different harddrive, rebuilt the project, but get the same error at the end of building DVD Volume:
    Found PG with no Video.
  • Sun, Jun 29 2008 1:15 PM In reply to
    • macjaeger
    • Joined on Mon, Jun 16 2008
    • Coburg, Germany
    • Posts 167
    • Points 1,945
    Have you checked all related videos? ProgrammGroup without Video might indicate that one your clips (qt reference, i assume?) references a non existing source.
    MC 3.0 (soft) on 2.4Ghz Intel Core2Quad, 4GB, XP Pro, 2+1 Screens hooked to Nvidia GF7900GTO & Matrox DualHead2Go, 1 TB striping RAID [view my complete system specs]
    not a pro, just a teacher...
  • Sun, Jun 29 2008 1:28 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 821
    • Points 10,875
     As a follow up to macjaeger take a look at the screen shot to the right in my tutorial HERE
    You can see how your QT Reference file should look in DVDitPro's Imported Media window.
    There should be a thumbnail of the Video plus a speaker icon for the soundtrack.
    When you create a QT reference file you get 2 files. 1 MOV file and 1 WAV file.
    Do not import the WAV file, only the MOV file.
    The WAV file will follow along automatically.
    Regards,
    Douglas
  • Sun, Jun 29 2008 9:23 PM In reply to
    • GeorgeD
    • Posts 86
    • Points 1,015
     I didn't use QT Reference files, I used m2v and ac3 files. I ended up using TMPEG author with the same media files and it worked without a hitch.
  • Mon, Jun 30 2008 12:25 AM In reply to
    • macjaeger
    • Coburg, Germany
    • Posts 167
    • Points 1,945
    Glad to hear you found a way around your problems, but it's still mysterious that your elementary streams should cause errors with your DVD.
    As TMPEG didn't complain the culprit seems to be Avid DVD (or the way you treated it *g*). At least this narrows down your search radius...
