Latest post Fri, Oct 24 2008 11:01 PM by Vince. 11 replies.
Page 1 of 1 (12 items)
  • Sat, Jun 28 2008 7:53 PM
    • Vin
    • Joined on Fri, Jun 13 2008
    • Posts 10
    • Points 140
    MC3, Mojo/002r on Vista 64: Exception ADM_ASIO_SEMA_DECREMENT_FAILED
    I went forward with a Vista 64/MC 3 test Geeked ... – disconnected my WinXP drive and installed vista on a new drive, just encase I needed to go back to XP.
    On Vista Business 64 bit, MC 3 test system I have video and audio with no problems via mojo.  However, when I start MC3 with the 002r and attempt to play a clip with sound, I receive this error: “Exception ADM_ASIO_SEMA_DECREMENT_FAILED. Now, if I mute the audio tracks, the video plays back fine. ..any thoughts?
    This is the same system that MC3 runs on via Win XP with no problems – Mojo with 002r.  …good thing I installed Vista on a different drive.
    Test System has 4 gigs of RAM.
    Thanks in advance...
    Vince
  • Tue, Jul 29 2008 1:23 PM In reply to
    • InBeeld
    • Joined on Tue, Nov 28 2006
    • Lier Belgium
    • Posts 4
    • Points 30
    Re: MC3, Mojo/002r on Vista 64: Exception ADM_ASIO_SEMA_DECREMENT_FAILED
     Hello,
    I had the same problem. Reconnecting Mojo Word Clock out  to D002 word clock in solved this problem.
    XW8200 - Avid XpressPro HD 5.6 - DSR-11 - J-3 [view my complete system specs]
  • Tue, Jul 29 2008 11:04 PM In reply to
    • Vin
    • Posts 10
    • Points 140
    InBeeld,
    I have the mojo clk connected to the 002r.  It has always been connected, otherwise it would not sync.  Did you do something different?   The mojo clk to 002r works fine on xp … just problems on vista64.
    Vince
  • Thu, Oct 23 2008 9:20 AM In reply to
    • anthas
    • Hemer, Germany
    • Posts 37
    • Points 455
    Hello Vince,
    I am suffering the same problem. Could you ever find a solution to it?
    While my avid software and hardware configuration works perfectly under Vista-32 Business, I do not get MC3.0.5, DIGI002 and Mojo working under Vista-64 Business on the same hardware.
    1. With Vista-64 the Digi002 controller is not active, although it is shown in controller setting. Connected to DAE-plugin-startup is okay ("Run as Administrator" option)
    2. sequence with audio activated:
    Attempted to playback, an "Exception: Adm_Asio_Sema_Decrement_Failed" error, no playback
    I have tried different cables connected from clk out on my Mojo to sp/dif in on the Digi002. Each cable works on Vista 32 but not on Vista 64.
    sequence with audio mute:
    Attempted to playback. Video playback on Mojo okay, no audio signal
    Ernst
    Tyan S5396 Dual Quad Core 8Gb RAM 2.5GHz, QuadroFX 3700,Vista32, System Raid 1 1TB Dual Boot V32/V64, SCSI320U Backup 4TB, Sata2 Video Raid10 4TB, Audio... [view my complete system specs]
  • Thu, Oct 23 2008 12:37 PM In reply to
    • carlgmi
    • Western Australia
    • Posts 367
    • Points 4,510
     From the knowledge base:
    "Vista - No support for the Digi 002 and MediaComposer software on Vista at this time."
    Appears to be OK on XP with MC3x according to article:
    http://www.avid.com/cgi/kbase-redir.aspx?p_faqid=76817&p_created=1224271926&p_sid=zUGLv2hj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQ6MSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjY0MSwyNjQxJnBfcHJvZHM9Mjc2JnBfY2F0cz0wJnBfcHY9MS4yNzYmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9Mg**&p_li=&p_topview=1
    Would love to hear when this is sorted out by Avid - currently looking at either having a dual boot or having to keep a separate machine just to use ProTools and my Digi002 if I go the Vista64 path - which seems a tad ridiculous for 2 closely related products???
    MC4 with Dongle, 2xQC Xeon, Tyan 5400XT, Quadro FX3500, Adaptec RAID 0-4x1TB, 8G RAM, Creative Audigy, Vista 64 SP1, Matrox Triplehead Digital. Protools... [view my complete system specs]
    Vote 1 - Dongles.
  • Thu, Oct 23 2008 6:07 PM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
     search the digidesign site. There is a new version coming up (PT8) That can use Vista 32 bit NO support for Windows 64 bit!
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 2x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC 3.5.1, Mojo... [view my complete system specs]
  • Fri, Oct 24 2008 12:41 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 367
    • Points 4,510
     You would think they could sort this out easily being part of the same organisation....
    Vote 1 - Dongles.
  • Fri, Oct 24 2008 7:21 PM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
     thinking that for a few years now, there is s improvement though... I have PT and MC running installed on one machine now for some time (before 3.0 actually). It will keep improving Wink
  • Fri, Oct 24 2008 8:01 PM In reply to
    • DC66STEPS
    • Los Angeles
    • Posts 88
    • Points 1,170
    I'm about to jump into the fun and install Vista 64-bit Business on my machine. I'll be running the latest Media Composer software with the original Mojo (no DIGI002). Does anyone have any knowledge if the original Mojo should work?
    WORKSTATION 1: Avid Media Composer v4.0.2 --- Windows 7 Ultimate (64-BIT) --- QuickTime Pro --- Tyan i7525 (S2676) with dual 3.6Ghz Xeons --- 8GB (ECC... [view my complete system specs]
    D~C
  • Fri, Oct 24 2008 8:34 PM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
     well read the system requierements, read the first post of this thread and you know at least one person is running this combination.
    BTW... as digidesign says it doesnot support 002 on Vista B. 64, than it does not surprise me that this combination is giving problems.
  • Fri, Oct 24 2008 9:38 PM In reply to
    • DC66STEPS
    • Los Angeles
    • Posts 88
    • Points 1,170
    Thanks, I did read that post but it is not clear to me if it is the original Mojo the poster was referring to. I realize AMC v3+ runs on Vista Business 64-bit according to the system requirements and testimonial here, but again, I was trying to get clarification if the original model Mojo would work.
    The DIGI002 is not something I'm concerned with as I do not have one.
    D~C
  • Fri, Oct 24 2008 11:01 PM In reply to
    • Vince
    • Posts 7
    • Points 75
    Sorry for the late reply all.  With the exception of rendering the 002r's digital connection useless, MC-3 works well with Vista 64 Business.  I've since upgraded to 8 gigs of RAM.  ...no big difference in Avid, but the extra RAM helps a great deal with large 3D maps when modeling in 3ds Max.
    I now have the Mojo's analog I/O running  via my Mackie D8B (yes the Mackie is old, but is still quiet as a ghost, one of the best studio investments I've made).  I just can't take advantage of the digital I/O now that my 002r is not working in Vista64.  Otherwise the analog audio I/O works fine.  ...no noticeable quality loss in sound.  I'm just reduced to using only two mixer channels instead of the eight provided via 002r digital I/O.  I've also upgrade the other machines in my studio to Vista business 64.  Overall, it' actually a workflow improvement in terms of networking.
    If you are using other apps besides avid and plan to go to Vista 64, be aware of your plug-ins and whether or not there is a vista compatible version in 64 or (32 bit capable of working in Vista 64). lesson learnd from my 002r  : )
    Hope this helps. Oh, D-C I'm using the mojo with the "clk" option.
    Vince
