Latest post Tue, Jul 28 2009 4:54 PM by Randall L Rike. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Jun 27 2008 11:28 PM
    Useful Console Commands - Media Composer, NewsCutter or Symphony.
    A subset of console commands (P) = Persistent, (NP) = Non-Persistent.
    A detailed description of some useful console commands is available below.  Help Commands - List all console commands.
    1. To write the full list out to a file, use:
      Log <filename>
      Help Commands
      Log
    AcplGpuEffects true - displays current state of ACPL GPU effects processing and if installed graphics card is qualified to do so.
    BackRevCC - Allows Nitris and Adrenaline (ver 2.x) Color Correction effects in the currently
    loaded sequence to be saved in a format compatible with Meridien (NP)
    CheckSequences - Checks all sequences for internal inconsistencies
    DumpFXSummary - Effects contained in a sequence are printed to the Console, new in MC3
    DumpSourceSummary - Sources contained in a sequence are printed to the Console, new in
    MC v3  Edo any/acplcpu/acplgpu/hw/sw - "Effect Domain Override" forces effects processing to
    occur in the specified domain.  Any = default. (NP)
    RepairSequences - Attempts to repair sequences with internal inconsistencies
    Subsys monpane debug - Allows precomputes to be loaded into source window (NP)
    ToggleHWDecode - Disables the hardware codecs (NP)
    WatchSequence - Continually check the sequence in the timeline for internal inconsistencies,
    popping up a message the moment one is detected.
  • Fri, Jun 27 2008 11:59 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    Re: Useful Console Commands - Media Composer, NewsCutter or Symphony.
    Very nice list. Thank you 'O mystery evangelist! Wink
  • Sat, Jun 28 2008 12:33 AM In reply to
    One more ...
    DumpClipSummary - a list of all the clips in the loaded sequence in Numeric and then Alphabetic order.
    And, iIf you drag a clip from the bin to the console, it will show you clip info; tracks, if a sub clip, etc.
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Sat, Jun 28 2008 12:37 AM In reply to
    How about adding
    setresizetype
    To change the quality of 2D resizing
    1.   Press Ctrl+6 (Windows) or ⌘+6 (Macintosh) to open the Console.
    2.   Enter the following command into the Console and press return:
    setresizetype 9
    This Command changes the resize rendering method to polyphase interpolation. This is a high-quality rendering method that dramatically increases the quality of all 2D resizes (including the Picture-in-Picture effect, all the 2D keyers, and the “letterbox” Reformat effects). As this scaling algorithm takes slightly longer to process you will notice a reduction in the number of simultaneous real-time effects that are possible.
    3.   To change back to anti-aliased bilinear interpolation, enter the following command into the Console:
    setresizetype 8
    The quality will also reset to anti-aliased bilinear interpolation when you quit and relaunch the application.
    AND    TCBreakTolerance
    The console is opened via the Tools menu or by doing a CMD-6 on Mac or CTRL-6 on a PC. Once the console is open:
    • type: TCBreakTolerance 3
      • Where 3 is the value of the frame detection (2-12)
    • Then the user hits:  ENTER
    This should be entered each time the application is started up as it does not stick. The supported values are 2-12. Users who have tested this feature have found that “3” provided excellent results.
    “1” is not allowed as it will return timecode breaks where there are none as it is too sensitive a setting. Users may find that “2” or “4” will work better for their tapes, but the user now has control over that setting.
    AND IgnoreQTRate
    Type 'IgnoreQTRate true' into the console. Avid then ignores the frame rate of the Quicktime file on import, and brings it in frame-for-frame.  This setting resets to False on a restart of Avid.
    Thanks for the continued dongle support
  • Sat, Jun 28 2008 12:53 AM In reply to
     Cool.  Keep your favorites coming, and they can be added to the list.
  • Tue, Jul 15 2008 11:18 PM In reply to
    • editz
    • Eugene, Oregon
    • Posts 127
    • Points 1,620
    Um...define "internal inconsistencies".  I have no idea what that term means.
    MCA 2.2.10 XW8000 dual 3.0GHz, 2GB RAM, NVIDIA 980 [view my complete system specs]
  • Tue, Jul 15 2008 11:24 PM In reply to
    "... define "internal inconsistencies" ..."
    One example would be taking a sequence backward, to an older system.  Some elements of the newer sequence might be nonsense to teh older system.  RepairSequences will strip those out, or make them workable.
  • Mon, Jul 27 2009 8:11 PM In reply to
    • Mike Fay
    • NYC
    • Posts 20
    • Points 260
    I've been trying to save a text file of the full list of console commands, but the top of the list always gets truncated in the console window. Thus, when I save the log, I'm always missing commands A-F. I tried typing the following into the console, but couldn't get it to work:
    Log <filename>
    Help Commands
    Log
    Can anyone explain how to do this? Thanks!
    Mac Pro 2 x 3 GHz Dual-Core Intel Xeon; 4 GB RAM; OS 10.5.5; Media Composer Adrenaline v3.1.3 [view my complete system specs]
  • Mon, Jul 27 2009 8:19 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,015
      Moderator: Meridien
    Randall L Rike:
    One example would be taking a sequence backward, to an older system.  Some elements of the newer sequence might be nonsense to the older system.
    I've noticed that Newscutter 7.1.3.2 when right clicking on a sequence, has a new option "Create compatible copy..." which is intended to make sequences fully compatible with older versions of the application.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Tue, Jul 28 2009 4:51 PM In reply to
    From the Avid Knowledge Base
    How could I list all console commands?[243109]
    http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=243109
    Media Composer 3.0.1, MacBook Pro 15", OS X 10.5.5 [view my complete system specs]
    Adam Kranitz
    Social Media Strategist | Online Marketing & User Experience
    t 978-640-5446  |  skype adamkranitz
    We're Avid.  Learn more at Avid.com/Facebook
  • Tue, Jul 28 2009 4:54 PM In reply to
    "... Create compatible copy ..."
    Finally, a formal version of "repairsequences"
