Latest post Mon, Jun 30 2008 2:58 PM by ceffoavid. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Jun 27 2008 10:31 PM
    • dsdude
    • Joined on Fri, Jun 27 2008
    • Posts 4
    • Points 70
    DS 2k problems
    Trying to finish a short film tomorrow in 2k on ver 8.4 ds. One problem i cam across is that anytime i used the scratch removal tool or graphics tool, i have found that it clips the luma!! Big problem when working at 2k. Has anyone come across this and maybe found a way turn the clipping off. Any help would be great , need to finish tomorrow. Thanks
  • Sat, Jun 28 2008 3:59 PM In reply to
    • slam
    • Sylvain
    • Posts 26
    • Points 330
    Re: DS 2k problems
     I think it's dead....
    The graphics effect clip the signal .....end of the story .....
    What kind of sequence are u using ???
    Nitris Editor V7.6 QFE 3 [view my complete system specs]
    Slam from Paris
  • Sat, Jun 28 2008 6:12 PM In reply to
    • dsdude
    • Posts 4
    • Points 70
    Re: DS 2k problems
    Its a full aperture 2k 4:3 sequence.
    Thats a major fault for working in 2k! Hope they sort it out.
  • Sun, Jun 29 2008 5:37 PM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 238
    • Points 2,615
    • Moderator: Avid DS
    Re: DS 2k problems
    I've not seen this on any 2K conforms I've done. However, maybe my workflow is different from yours. Are you rasterizing the strokes or leaving them vector? Are you rendering 8, 16 or 32 float?
    Michael
    Beta Tester, DS V10, DS Nitris, Symphony Nitris, Composer [view my complete system specs]
    "There are no rules for the brave". Albert Einstein
  • Mon, Jun 30 2008 12:35 PM In reply to
    • dsdude
    • Posts 4
    • Points 70
    Re: DS 2k problems
     I dont think its a render issue, I can see the clipping as soon as a place a brush stroke on the image.
    What kind of lut do you use? I was told that the ds does not support 3d luts, is this the case?
    I had to use a 1d lut, so my pictures did not reflect the graded files.
  • Mon, Jun 30 2008 2:58 PM In reply to
    • ceffoavid
    • Joined on Thu, Jan 17 2008
    • Posts 107
    • Points 1,215
    Re: DS 2k problems
    Have you tried to render?  Maybe that would remove the clipping.
    ACSR
    Media Composer, Symphony, DS, Unity
