Latest post Mon, Apr 9 2018 2:31 PM by Kevin Klimek. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Jun 27 2008 6:53 AM
    • paul b
    • Los Angeles
    • Posts 183
    • Points 2,325
    Strange Unity Mac (Error Code -36)
    I've encountered a strange problem when archiving a project.  I can't copy any files if they've lived on the Unity at any point in the workflow.
    Much of the archive consists of uncompressed QTs of stock footage--actually there are a few hundred files. Additionally  I output all video tracks in the final project to Photo JPG.  At one point, all of these files were on Unity 5 volumes--even though they were not all OMF or MXF files.  The entire project (MXF, QTs, Composer Project,etc) was copied to an Iomega firewire drive a few months ago--the CPU for that system was an Intel Mac.  Now I'm trying to copy the contents of that Iomega to my own FW drives--my CPU is an PPC G5.
    With a few exceptions, the vast majority of any of the files, regardless of file format, cannot be copied.  I get (Error Code -36).  I simply cannot get these files off of this borrowed Iomega FW drive onto my own drives.
    At one point a few months ago, I reinstalled the project from the borrowed Iomega back onto the Unity.  There was no problem whatsoever copying off of the FW drive BACK TO the Unity during that time.  I made changes to the project and re-archived back onto the same Iomega drive.  I have bits and pieces from both times I archived to the Iomega.  No luck in any event.  Nothing can be copied off that Iomega Drive.
    Is this a Mac question or a Unity question?   Of course I tried messing around with the permissions, but I can't even see the drive in Disk Utility. Please help, this is really messed up.
    Best WIshes and Thanks,
    paul b.
    MC 5.5.3 & MC 6.5 MacPro Nehalem 8-core Avid Nitris DX Sonic Fusion 8TB E-Sata Raid 5 [view my complete system specs]
  • Fri, Jun 27 2008 11:16 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,723
    • Points 226,270
      Moderator: MCA Mac
    Re: Strange Unity Mac (Error Code -36)
     A -36 error means that there is an interruption in the data flow between the source drive and the host computer. That can be caused by a failing drive, a bad cable ore even a bad bridge board. Something in the drive chain is preventing data from being read from that drive.
  • Fri, Jun 27 2008 2:04 PM In reply to
    I've also seen corrupted files cause the issue and I myself experienced a bad power supply causing this error message just yesterday when trying to copy files.
    MC 8.6.1, Mojo DX, 12-Core MacPro, 64 GB RAM, 24 TB Thunderbolt Storage [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc
  • Fri, Jun 27 2008 2:06 PM In reply to
    http://community.avid.com/forums/t/59932.aspx
    Here's another recent thread dealing with the same error message.
  • Fri, Jun 27 2008 5:16 PM In reply to
    • paul b
    • Los Angeles
    • Posts 183
    • Points 2,325
    As always, thanks.  I overlooked something obvious.  This is a new configuration of my edit console.  I'm using a 15 foot cable between the CPU and the first FW drive, and then 2 footers to link the other two FW drives.  I don't typically use these FW drives--this the first time they've been turned on with this long cable
    However, there's a very good reason I'm attempting to use a 15' cable and life would be simpler if that worked.  Any suggestions?  How some kind of booser at the 7' mark?  The G-Raid drives appear to work.
    Anyway . . . I connected the drive in question with a shorter cable and it appears to have copied everything.  Thanks again people,  please let me know if you have any idea how I can make this 15' work.
  • Sat, Apr 7 2018 2:16 AM In reply to
    You should try to move your files with the aid of other mediums leaving finder. Copying files in the finder, which is a very simple way. While copying files to the finder there are numbers or permission and checks asked to ensure that the process is being correctly done.
    Maybe you'll find some help here.
    https://www.errorsolutions.tech/error/mac-error-code-36/
  • Mon, Apr 9 2018 2:31 PM In reply to
    Julia, you just resurrected a 10-year old post.
