Latest post Tue, Jul 1 2008 2:51 PM by grata. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Jun 27 2008 5:25 AM
    • texmax1
    • Joined on Wed, Apr 16 2008
    • Plano
    • Posts 21
    • Points 275
    esata11 cards on MBP
    I have a Siig esata 2-port express card and 2 seagates drives (2X200 gig), it work 85% of the time under tiger but it is stinking up the place now on loepard.  at least 2 KP an hour. Which means it doens't work.  Is their anyone out trying this approch and haviing it work?  What I am trying to do put the entire edit package into one case for travel.  So small and lean are good.  Any Ideas from the Gods out in Avid land?
    PS  3.0 is working wonderfully for me, only one proble and you see that above
    Thanks for the help!
    Max
    mbp 2.4 santa rosa, 4 gigs. Avid MC 3.0. Mojo analog. [view my complete system specs]
  • Sat, Jun 28 2008 8:08 AM In reply to
    • texmax1
    • Plano
    • Posts 21
    • Points 275
    Re: esata11 cards on MBP
    I cant be that cutting edge,,,, some had to be doing this... any help?  please
    Max Stacy
  • Sat, Jun 28 2008 2:36 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    Hi Max,
    I don't know if this helps, but I've got a MacBook Pro, attached via an eSATA card (in my ExpressCard slot) to five Seagate drives, in a Firmtek SATA enclosure.  I'm running Leopard; Media Composer v.3.
    It all seems to work fine.  You need to be more portable than I am, I think.  But I don't see why that should affect the workings of your hard drive(s).
    Malcolm (a mere mortal in the Avid world; you'll have to wait for one of the gods to pronounce on this)
    MBP 2.5GHz, 4GB RAM, OSX 10.5.4; Media Composer v.3 [view my complete system specs]
  • Sat, Jun 28 2008 3:12 PM In reply to
    • texmax1
    • Plano
    • Posts 21
    • Points 275
    Malcolm,  You have now become a God for being the 1st one to awnser!  Thank you O'great one ;--)  I am trying to trouble shoot if it is the Siig card or the Seagate drives or the enclosures.  One of the three are causing the kernnel panics.  What card are you using?  I am beginning to think it might be me enclosures.  Thanks for your help!
    max
  • Sat, Jun 28 2008 3:19 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,729
    • Points 161,575
      Moderator: MCA Mac
    A lot of drive problems have shown up in Leopard. Most of the problems have been with FW but, your problems may be related.
    When FW drives show this behavior, swapping out the power supply for a new one has solved it.
  • Sat, Jun 28 2008 5:02 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    texmax1:
    Hi Max,  I certainly hope the ';--' after the 'O great one' doesn't mean 'wink wink nudge nudge, I'm being sarcastic' (I've never really known what some of these keyboard emoticons mean; of course ;-- might stand for something like an exclamation mark, but then, why not just use an exclamation mark?!)
    Anyway, the card I'm using is s SeriTek 2SM2-E card (made by the same people who make the enclosure I'm using).  I'd suggest you try what BLKDOG mentions, though; he's has a somewhat higher status on Mt. Olympus than I am.  Good luck with it.
    Malcolm
  • Sun, Jun 29 2008 3:35 AM In reply to
    • texmax1
    • Plano
    • Posts 21
    • Points 275
    Solved!  A $5.00 power supply seems to have fixed the problem. TY Blkdog and Malcolm.  As for the ;--), sorry, I have a stuttering finger, funny though it doens't happen when I sing, wink wink nudge nudge, say no more....
    Max
  • Mon, Jun 30 2008 10:10 PM In reply to
    • grata
    • Joined on Thu, Jun 19 2008
    • PA
    • Posts 24
    • Points 285
    texmax1,
    My ship has sailed the same course as yours- can you give me a specific part/model number of the power supply you purchased please?
    Best,
    >MC v3.0 /mojo(does not work yet)>Mac Pro- dual 2.8 Quadcore/10GB Ram >OSX 10.5.3>ATI 2600XT>(2)22"WS LCD Displays> [view my complete system specs]
  • Tue, Jul 1 2008 3:02 AM In reply to
    • texmax1
    • Plano
    • Posts 21
    • Points 275
    Hi Grata,
    I used another power supply from a long expired enclosure.  I had looked online at owc (where I bought the HD enclosure) and fry's and they were are priced between $4. and $9.usd.  The one i am using labeled "switching power adapter" and the output matched what the drive housing requested  +5v 2.6a.  Not one kernel panic since I switched the power supply.  BD is a wizard, I would of never thought to try a different power supply.  Good luck, I hope this fixes your problem!
    Max
  • Tue, Jul 1 2008 2:51 PM In reply to
    • grata
    • PA
    • Posts 24
    • Points 285
    Thanks texmax, i'll give it a go!
