Latest post Fri, Sep 5 2008 5:26 AM by jwrl. 12 replies.
Page 1 of 1 (13 items)
  • Thu, Jun 26 2008 6:43 PM
    • Rignold
    • Cape Town
    • Posts 75
    • Points 1,080
    New Quadro FX1700 Slower then FX 7900GT
    Help!!! I just upgraded to a PNY Quadro FX1700 and my renders are slower then with my old unapproved 7900GT. (About twice as long). What could I be doing wrong?[:'(]
    Asus P5K3 Deluxe Motherboard, Intel Core 2 Duo E6600 Conroe 2.4GHz, 4gig DDR3 1333mhz RAM, PNY Quadro FX1700(Driver 169.47), XFX GeForce 7900GT, QT 7.45... [view my complete system specs]
    Before you judge a man walk a mile in his shoes. After that who cares, you're a mile away and you've got his shoes.
  • Thu, Jun 26 2008 8:21 PM In reply to
    • FunkyDragon
    • Boston MA
    • Posts 438
    • Points 5,160
    Re: New Quadro FX1700 Slower then FX 7900GT
    maybe the wrong NVidia Driver?
    MC 3.0! HP nw9440 Laptop Mojo SDI Camera: DVX100A Deck: DSR 1500a [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Fri, Jun 27 2008 7:14 AM In reply to
    • Rignold
    • Cape Town
    • Posts 75
    • Points 1,080
    bump
  • Fri, Jun 27 2008 12:27 PM In reply to
    • FunkyDragon
    • Boston MA
    • Posts 438
    • Points 5,160
    So you have your system specs lined up - but no software or driver versions listed.
    like i said, maybe you have the wrong driver?  and maybe you'll get different results with different cards.  Avid can't test them all....
     The FunkyDragon
    Happy Editing!
  • Sat, Jun 28 2008 11:37 AM In reply to
    • Rignold
    • Cape Town
    • Posts 75
    • Points 1,080
    FunkyDragon:
    First of all my system specs are all there under my profile. The driver I'm using is the one specified by AVID. As to AVID not being able to test them all this is an AVID recommended card!
    I have reformatted my system drive and re-installed Win XP SP2 and MC 3.0 but the problem persists. If anyone can offer any further advice I'd be happy to hear from you.
    Regards
    Rignold
  • Mon, Jul 14 2008 2:18 AM In reply to
    • devjt2
    • Joined on Fri, Mar 21 2008
    • Posts 6
    • Points 90
    I know I'm reviving this old thread...
    Just curious, did you happen to solve the problem?
    I'm not yet completely sold on the Quadro cards. Yes - they are Avid certified, but are they actually any better?  I've not seen one benchmark that can prove it.  Supposedly the Quadro cards do wonders when working in After Effects. Again, I haven't seen one benchmark to prove it.
    Once Nvidia can prove these things to me, they will have another customer.
  • Mon, Jul 14 2008 2:57 AM In reply to
    Rignold:
    I'll assume you're using MC 3.0 (which now utilises GPU performance)
    It's a good starting point to compare the two cards you've mentioned. (Ignore the Quadro vs GeForce debate for now).
    Quadro FX1700:
    Core GPU: G84GL
    Core GPU clock: 460Mhz
    Memory Speed: 800Mhz
    Memory Size: 512MB
    Memory Bus: 128-bit DDR-2
    GeForce 7900GT:
    Core GPU: G71
    Core GPU clock: 450Mhz
    Memory Speed: 1320Mhz
    Memory Size: 256MB
    Memory Bus: 256-bit DDR-3
    Side-by-side it's quite easy to see some noticable differences in the raw hardware. Note that the 7900GT's core memory is one DDR generation beyond the Quadro, and twice the available bandwidth due to being 256-bit (not 128-bit)
    Then you have to notice that the memory is operating at a significantly faster rate: 1320Mhz vs 800Mhz.
    Whilst the Quadro can score a point by having twice the available memory (512MB), that really won't help very much as it's gonna hit that 128-bit memory bus bottleneck.
    In my experience there really isn't much to be gained by a Quadro over a Geforce except in the quality-control of certified workstation drivers and the fact that Quadros mostly make their presence known through intense 3D/CAD-related work. Hence why After Effects and programs such as 3dsMAX and Maya tend to benefit more from them.
    Quadros (which folk should remember) are basically just GeForce cards underneath. They operate on exactly the same GPU units and architecture. It is the Nvidia driver (often in combination with some hard-wired switches to prevent hacking) which effectively "switches" on the embedded features which make Quadros cost so much. (Mostly related to 3D work such as clipping planes, full-screen anti-aliasing, buffers, hw-accelerated overlapping dialog boxes and so forth).
    There are some hardware differences which usually relate to the DVI outputs almost always being Dual-Link on Quadros, to permit distortion free signal transmission to super-high-def screens (Beyond 1920x1080)
    In this case I think it's a simple case of good drivers and the fact that all totalled, if your 7900GT is working flawlessly in Avid, I'd suspect it probably will assist the render process far more than the FX1700.
    Just my 2p. Wink
    MSI Neo-2 Platinum Nforce3 Ultra (Bios Rev 1.0D) Athlon64 X2 4200+ (Overclocked to 2 x 2.4GHz) AMD Cool'N'Quiet CPU Throttling 2GB Corsair PC3200... [view my complete system specs]
  • Tue, Jul 15 2008 7:50 AM In reply to
    • Rignold
    • Cape Town
    • Posts 75
    • Points 1,080
    devjt2:
    I have "solved" the problem. I replaced my Intel motherboard with an ASUS board. I basically went with the DIY build machine on the Videoguys website. Extremely fast now with DDR3 ram etc. Also running 2 video cards with 3 displays, 1 in permanent Full Screen Playback for HD monitoring.Stick out tongue
  • Tue, Jul 15 2008 10:12 PM In reply to
    • lalittle
    • Posts 172
    • Points 2,435
    Rignold:
    Could you give the details of your two graphics card setup?  I "thought" that you could only display Full Screen Playback on the monitor that displayed the main Avid desktop.  How do you have it configured so that you have FSP on one monitor all the time?  Which cards drive which monitors, what do you have displayed on each monitor, and what did you do to set up Avid to work correctly in this manner?
    Thanks for any details on this,
    Larry
  • Tue, Sep 2 2008 9:40 PM In reply to
    • -mp
    • NYC
    • Posts 114
    • Points 1,325
    The Mcfly method?
    Just speculating,
    /mp
    Dell Precision 670 recommended system 2x 3.6 Ghz Xeon CPU 4 GB RAM 1x 160 GB SATA HD boot 1x 400 GB SATA HD data assorted Seagate external... [view my complete system specs]
  • Tue, Sep 2 2008 11:51 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,326
    • Points 38,250
    lalittle:
    If you use two nVidia cards, connect your intended FSP monitor to the second port on the primary card.  Since the second card will only be used for non-video functions it can be a lower performance device as long as it uses the same driver as the primary.  Configure the displays in Windows so that you have display 1:primary card output 1, display 2:secondary card output 1, and display 3 (intended FSP): primary card output 2.
    Boot up Avid and from the Toolset menu select Source/Record editing.  Layout your displays so that you have your source and record monitors and your timeline on display 1 and your bins and other tools on display 2.  Click on the Settings tab and double click on Full Screen Playback.  Drag the window that appears to display 3, make any settings adjustments you require, and click on Set Monitor.  Click OK, then press Ctrl-Shift-F.  Your full screen display should now be working.
    Finally, in the Toolset menu, click on Save Current.  From now on, everytime you launch Avid your fullscreen display should be active by default. (This has been done from memory, so if there is any variation in menu names or dialog box labels I'm sorry.  It should be near enough for you to work out though).
  • Fri, Sep 5 2008 4:25 AM In reply to
    • Graeme Fullick
    • Newcastle Australia
    • Posts 36
    • Points 445
    Thanks John - this is very helpful. What I don't get in the case above is how a Gforce card and a Quadro worked together. Don't they use different drivers?
    MC V3.05, Avid Liquid 7.2, Intel Quad 9550@3.1GHz, ASUS P5QDeluxe, Quadro 3700 and Quadro 570 Graphics, 4Gb OCR ram, WD Raptor 300GB system drive, storage... [view my complete system specs]
    Graeme
  • Fri, Sep 5 2008 5:26 AM In reply to
    • jwrl
    • Posts 3,326
    • Points 38,250
    Yes they do - normally.  It was all thanks to the magic of Riva tuner.  And no, I don't still have it that way.  This was done when I was building my new MC 3 system.  I borrowed the GeForce from one of my sons in the spirit of enquiry, since I had two PCI-e slots that could be run simultaneously as x16.
    One of these days, though...
