Latest post Thu, Jun 26 2008 6:57 PM by mhamilton. 14 replies.
Page 1 of 1 (15 items)
  • Thu, Jun 26 2008 4:40 PM
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    before I update to v.3... last-minute advice requested
    Hi there,
    Just before I update to version 3...
    As I recall, there are a couple little Avid files I should save, before uninstalling 2.8.3 and installing v.3.  Would someone remind me what they are, and where they are?
    Once I've saved these files, I uninstall 2.8.3 and then install version 3. Right?  Anything else?
    I won't update QuickTime.
    Cheers, Malcolm
    MBP 2.5GHz, 4GB RAM, OSX 10.5.4; Media Composer v.3 [view my complete system specs]
  • Thu, Jun 26 2008 4:55 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,093
    • Points 60,860
    Re: before I update to v.3... last-minute advice requested
     Malcolm:
    From the knowledge base regarding upgrading. Start with "before you install the editing application".
    Media Composer Adrenaline PC v 2.7.7 * Newscutter Adrenaline PC v 6.7.7 * XDCAM PDW-1500 & PDW1 * PDZ-1 XDCAM Browser * Pixelan SpiceMaster 2.0 plug... [view my complete system specs]
  • Thu, Jun 26 2008 5:11 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    Thanks Larry... I'd looked in the FAQs and Announcements above; I will go through the Knowledge Base article carefully now.
    Cheers, malcolm
  • Thu, Jun 26 2008 5:30 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    Hi again Larry,
    I read through the document (it seems so much of it is dedicated to Windows users, which I skipped), and didn't see anything about saving some key preference files... which I recall from past BLKDOG postings, you need to do.
    Are these the Site Settings.avs type files?  If not, which ones should I save?
    Thanks again, Malcolm
  • Thu, Jun 26 2008 5:32 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    I don' think I've ever recommended saving any preference files. The only things I have protected are any AVX plugs I have installed.
    Other than that, the install will not touch your user settings (Though I recommend making new ones with ay Major upgrade) so I can't think of anything else to protect.
  • Thu, Jun 26 2008 5:35 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    That's it, BLKDOG, the user settings - - that's what I was hoping to save... but I now realize I don't need to save those specifically.  And I've now saved my AVX Plug-ins.  Cheers, Malcolm
  • Thu, Jun 26 2008 5:39 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,093
    • Points 60,860
     I have to echo BLKDOG's recommendation. Whenever going to a full X. new version, I always create my user profile over again from scratch.
  • Thu, Jun 26 2008 6:23 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    Hey guys,
    I just tried to launch MC3 and I get a message saying my system isn't licensed to run this verion of the software.  Where did I go wrong?
    Malcolm
  • Thu, Jun 26 2008 6:24 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    You didn't update the dongle
  • Thu, Jun 26 2008 6:26 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    Yes... (I don't know why this is printing bold; I guess it's reading my mood)... I forgot to update the dongle.  I'll go and read about this now.  thanks, Malcolm
  • Thu, Jun 26 2008 6:36 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    O.K., back to normal font.  That's a start.
    I guess I need to update my dongle.  But this is confusing:  on the advice of the help article mentioned, I think I'm supposed to register MC3 and "attain a DBHelper.exf File".  But when I go to the page I'm directed to, it thinks I'm updating to 2.8.3 (which I already did a month or so ago; which means I've already used my key).
    What should I do now?
    thanks, Malcolm
  • Thu, Jun 26 2008 6:39 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    If you have already registered your software, just go to avid.com/protect and follow the prompts to get a dongle updater file.
  • Thu, Jun 26 2008 6:45 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    BLKDOG, thanks for your help with this.  I'm on the avid page... do I choose Versioner for Mac?
    I've tried this, but can't figure out what app to use to open the two files that get downloaded (Updater.avd and versioner.avd).
    Malcolm
  • Thu, Jun 26 2008 6:47 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    It should be the versioner and it is used by the Dongle manager app you can download @ avid.com/dongle.
  • Thu, Jun 26 2008 6:57 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 480
    • Points 5,560
    Thanks so much... it all worked, and I'm now up and running in version 3.
    Much appreciated... Malcolm
