Latest post Fri, Jun 27 2008 2:06 PM by luca.mg. 4 replies.
  • Thu, Jun 26 2008 1:15 PM
    • soren
    • Joined on Mon, Jan 9 2006
    • Vasa, Finland
    • Posts 5
    • Points 55
    DAE Interface NOT Available (Stubbed) on MC 3.0
    I have searched thru the Community about this problem but have not found a really solution on the problem. Some says that it depends on Admin rights some on reinstalling Avid Composer 3. And some saids you need to format the machine. What I have tried to do is reinstalling Avid composer och I upgraded MC2.8 -> 3.0. But  I still get this message when I run Audio Suite. Can someone explain what DAE is and why can´t it not be found? Is it a solution WHy it can´t be found.
    How is the Audio Suite built up on Avid? Is it bases on Pro Tools and is the embedde PRo Tools the problem? This is annoying problm when we cant use Audio Suite.....
  • Thu, Jun 26 2008 1:19 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,710
    • Points 161,440
      Moderator: MCA Mac
    Re: DAE Interface NOT Available (Stubbed) on MC 3.0
    Do you have Pro tools installed on the same system? If so, that's the problem as Pro tools' DAE drivers and Avid's conflict.
  • Thu, Jun 26 2008 3:09 PM In reply to
    • TerryO
    • Joined on Mon, Oct 24 2005
    • Oslo, Norway
    • Posts 72
    • Points 810
     We just had this issue on our machines at work.
    Not on 3.0 but on our 2.8.3 when reinstalled and connected to interplay.
    The tech guys sais it was a problem with rights. If you dont find the anwser, I can ask what those guys did to solve the problem.
    Work machines: 5 Avid Media Composer Adrenaline version 2.8.3 / 3.0 Avid built HP machines 3 GB RAM, Dual Xeon processor 3,2 GB 1 Avid Symphony Nitris... [view my complete system specs]
  • Fri, Jun 27 2008 2:04 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 109
    • Points 1,265
    I had the same problem and the Digidesign driver was missing, I have had to manually install it.
    MC 3.0/Mojo, XP pro sp2, Asus Formula maximus, Intel 6550, 4gb ram, Pyro card, Quadro 560, 2 1TB drives (raid 0) for mediafiles + G4 MacBook 17" [view my complete system specs]
    peace luca
  • Fri, Jun 27 2008 2:06 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 109
    • Points 1,265
    I've just seen this: http://community.avid.com/forums/t/60203.aspx
    peace luca
