Latest post Mon, Aug 11 2008 8:44 AM by smaxnelson. 44 replies.
Page 3 of 3 (45 items) < Previous 1 2 3
  • Tue, Jul 8 2008 5:11 PM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Rankweil | Austria | Europe
    • Posts 121
    • Points 1,500
    Re: XDCAM HD 422 / MC 3.0 / MC 2.7.x
    O.k. - so MC 3.0 doesn't do the job.
    Question:
    - Has anyone an idea, when Avid will show up with support of XDCAM HD 422 50 Mb/s ?
    - Is there a workaround to use the high resolution media in the meantime?
      (as importing the media, just using the "Import" function doesn't work...)
    - Is this a reason to use FCP?
    Avid Adrenaline DNxcel | HP xw8400 - Xeon CPU @ 2.66 GHz - 3GB RAM | easyRAID 4TB | MC 3.0.5 | PDW-U1 (Firmware 2.0) | DVW-M2000P [view my complete system specs]
  • Tue, Jul 8 2008 9:57 PM In reply to
    • Haze
    • Posts 327
    • Points 4,355
    Support for 50Mb?  Given the long wait for 35Mb support I wouldn't hold my breath waiting for 50Mb support anytime soon.  I heard 'later this year', that could mean the end of December or a year from now.  Who knows?  Like I said, don't hold your breath unless you can hold your breath for a really long time.
    You could use the XDCAM deck and digitize the footage via HD SDI, but I also heard that the decks (PDW 1500) are currently in short supply.
    Regarding FCP, are you sure FCP supports 50Mb XDCAM import?  I haven't checked lately , but the last time I checked the only NLE app that supported 50 Mb was Vegas (also a Sony product).
  • Tue, Jul 8 2008 11:02 PM In reply to
    • Moses.M
    • Posts 121
    • Points 1,500
    we already have a pdw-u1 drive. and now after spending money for a useless update for our media composer, I should buy another drive? no thanks.
    I'ld be glad, if I had the possibility to convert the sony MXF files to anything avid could import. 'til now I have found nothing.
    sony ships a software called "PDZK-P1" for transfering the files to a FCP system:
    XDCAM Transfer is a software solution that enables you to use media captured using Sony’s XDCAM system in Apple’s Final Cut Pro video editing software.
    right now, I'm quite disappointed. another avid "new thinking" thing.
    after trying to get the system working in any way for hours, I'll go to bed now.
  • Tue, Jul 8 2008 11:10 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,252
    • Points 168,085
      Moderator: MCA Mac
    Moses.M:
    Yeah but, I think, that's not the 50 MBS files. Pretty sure that FCP still can't do those either.
    Have you tried Raylight as a conversion tool?
  • Wed, Jul 9 2008 12:38 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,311
    • Points 38,030
    Moses.M:
    How is this an issue for Avid?  Sony have a codec which only Sony-supplied edit equipment can handle.  Where do Avid figure in this?
    At the moment the HD codec market is very volatile.  It will probably remain that way until equipment standardises.  In the meantime third party suppliers like Avid will be forever running as hard as they can to stay in one place.
    Until we get some form of international standardisation it's going to be hard for all of us.
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
  • Thu, Jul 10 2008 3:20 PM In reply to
    • Moses.M
    • Posts 121
    • Points 1,500
    @Haze: here's the link to the software, that enables FCP to work with HD422:
    LINK
  • Thu, Jul 10 2008 5:04 PM In reply to
    • Haze
    • Posts 327
    • Points 4,355
     Sure enough FCP 6.0.3 works with 50 Mb XDCAM HD 422.
    I'm willing to cut Avid some slack because the 700 camera's still have that new car smell.  Meaning it will take some time for Avid to implement the new codec.  If they don't release an update to accomodate 50 Mb by the end of December I'll be disappointed.   While there are a lot of new formats out there (Red, AVCHD, etc.) the XDCAM format has a strong foothold in the marketplace.  It's obvious that Avid has embraced the XDCAM format.  That should mean that 422 50Mb import will become available in the near term.
    Your options now are to buy a FCP setup or buy the Sony PDW-1500 and digitize via HD SDI using the DNxHD codec.  The price would be about the same.  Of course you could rent the deck for a lot less if it's available for rental.
  • Thu, Jul 10 2008 10:37 PM In reply to
    • Moses.M
    • Posts 121
    • Points 1,500
    my option is to use the HD-SDI output of our camera to capture my videos. then I'll "escape" to Bejing for a month and hope 'till late August we have a working update for MC 3.0!
  • Sat, Jul 12 2008 12:48 PM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,490
    • Points 17,870
    Moses.M:
    This is perfectly part in a good new thinking. "Do not release a buggy process", and ofcourse, "Do not release a codec before You have a chance to test them with delivered equipments".
    The reality is that Avid hade struggle with lots of buggs in the 5.x/2.x serie of AXP/MC software. Not more than other NLEs, but to much for a NLE which You will trust time critial projects. Therefore, I think it is better to be the second NLE with support for new codecs than the first with a buggy software.
    In most professional situations, You do not invest in the first round of equipments. You will wait until you understand and know the pros and cons of these new things. At the end, this strategy will save You time, money and quality.
    I do not have the ad here, but Avids promise is that there software will take care of the technical part and we can take care of our business and creativity. To deliver that, Avid must be shure that there software is working without problems and difficul external hardware recodings. Therefore, Avid will not and shall not, be first with support the latest and most hyped cameras/codeds. The support will come, but it will take time until they can deliver the rigth thing.
    There will alway be a second way. Use a software which can capture the files and convert them to quicktime. Recode them to DNxHD and it will work, but maybe without meta data, but You can edit.
    Dell 360, 3.2Mhz, 2 Gb RAM, Mojo. 80GB Sata bootdrive, 200GB SATA videodrive. Windows XP SP2, swedish version. MC 3.0 [view my complete system specs]
  • Fri, Jul 18 2008 11:14 AM In reply to
    • Moses.M
    • Posts 121
    • Points 1,500
    I'm willed to be a beta-tester to get this thing working. As we are in production for a big event next week right now, it was very important for us to optimize the workflow. So on our own risk we tested a little piece of sony-software and:
    It's working! Big Smile
    We are now able to handle the xdcam hd 422 media in our MC 3.0 as like the other resolutions (35,...)!
    Regards M.
  • Fri, Jul 18 2008 10:52 PM In reply to
    Moses.M:
    Do you mind sharing what the little piece of Sony software was?
  • Sat, Jul 19 2008 8:32 AM In reply to
    • Moses.M
    • Posts 121
    • Points 1,500
    @Andrew: You've got a mail.
  • Fri, Aug 8 2008 4:47 PM In reply to
    • smaxnelson
    • Joined on Wed, Aug 2 2006
    • England
    • Posts 6
    • Points 90
    Dearly love to know what work-around you found to this problem - any chance you could share it with the rest of us?
    Dell 380 Workstation, 4 Gig RAM, Nvidia Quadro FX1400, 4 1TB SATA drives (RAID 0), MC 3.0, Sapphire 2.07, Boris FX, Adobe CS2, etc, etc... [view my complete system specs]
  • Sun, Aug 10 2008 1:14 PM In reply to
    • Moses.M
    • Posts 121
    • Points 1,500
    As I got the information, that the software is still Beta, I didn't want to spread it. Maybe, there is a update together with the new PDW-U1 software, which seems to be available:
    http://community.avid.com/forums/t/61726.aspx
    If not, please write me a email.
    Regards - Moses
    (P.S.: Sorry, I don't have access to the forum every day right now, as I'm working in Beijing. So maybe answers might have a little delay ;) )
  • Mon, Aug 11 2008 8:44 AM In reply to
    • smaxnelson
    • England
    • Posts 6
    • Points 90
    So, if I understand you correctly, it's simply the updated PDW-U1 version 2 software that did it for you then?  Only, we have a series of lengthy and rather involved projects about to kick in and I just wanted to ease the work-flow.
    Cheers Smax
