Latest post Sat, Jun 28 2008 3:30 AM by jwrl. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jun 26 2008 11:06 AM
    • benweasel
    • Posts 5
    • Points 55
    Can't open Avid Xpress Pro (Open GL Effects)
     Hi!
    My PC crashed, and I had to format C:
    I've installed my Avid Xpress Pro HD 5.2.3, (my Quicktime version is 7.3.1.) but it doesn't work.
    It crashes while Opening GL Effects.
    My computer is:
    Intel Pentium 4 CPU 3.20GHz 1,0 GB RAM Radeon X300/X550/X1050 Series
    MS Windows XP SP2
    Please, help!!!!
  • Thu, Jun 26 2008 11:32 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,047
    • Points 11,960
    Re: Can't open Avid Xpress Pro (Open GL Effects)
    Not surprised - your video card is completely unsupported. Best bet is to hope someone uses a similair card and can offer anything.
    XW8200 2x3.2Ghz Xeon nVidia 3450 3Gb Ram Media Composer 3.0 w/Mojo 2Tb storage (mixed SCSI/SATA/1394)---------------Mac Pro 2xQuad-Core Intel 3Ghz 9Gb... [view my complete system specs]
    My Two Cents .02
    Kent Brockman
  • Thu, Jun 26 2008 11:55 AM In reply to
    • benweasel
    • Posts 5
    • Points 55
    Thanks!
    But the Avid used to work before... do you know which are the best video cards to work with Avid? (I hope not to have to buy another one, but...)
  • Thu, Jun 26 2008 12:12 PM In reply to
    • benweasel
    • Posts 5
    • Points 55
    Ok, I've solved it:
    Yes, it was the video card. I've installed the ATI Radeon X550 (RV370) drivers, and now it works!
    Thanks Solopost!
  • Fri, Jun 27 2008 3:43 PM In reply to
    • Solopost
    • New Jersey
    • Posts 1,047
    • Points 11,960
     Post which specific drivers you used that way - for those who may be using a similair card - this thread could prove useful for them if they find themselves in the same boat as you.
    Also, I don't deserve any thanks - I really did not do anything but direct you to a supported video card. You fixed this all on your own...
    ** GOING OT **
    This really does exemplify what the editor of the now needs to be. They have to know their way around a computer. Especially those who wish to build their own system.
    Don't just hit the boards and moan about "Avid does not work, but windows movie maker does. Why is Avid so crap?" - if you use unsupported, you are your best expert. The boards can prove useful for those who home-grow their systems... there are many a folk on here who have home-grown and have Avid running on some 'way off spec' configurations.... but as there can be so many configurations for a home-grown, the response of what I, initially, gave is usually the one you can get most of.
    I oppose home-growns, but if you have the know-how and can do it successfully - I have nothing but respect for that knowledge... I have no respect for those who home-grow then moan about Avid being at fault. The specs are listed for approved systems. If you 'think' you can do it and find out it does not work - back away and go get another editing system that you 'rave' about. If you are like this user who has a bit of home-grown and have the 'want' to get your system working with Avid (not the other way around).. then the respect is due and this user get's my respect for not moaning, but fixing his systems inability to work with Avid.
    My Two Cents .02
    Kent Brockman
  • Sat, Jun 28 2008 3:30 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,326
    • Points 38,225
    ** STILL OT **
    I agree totally with Solopost - and I do build my own, and always have.  You either have to have the resources (be they technical or financial or both) to be your own support team, or you should just stick with Avid approved.  This is especially true if your livelihood depends on it, as mine does.  If you don't stick to Avid approved you can't blame Avid for anything that ensues.
    ** END OT **
    Thanks for posting your solution.  It will help others.
