Latest post Wed, Jun 25 2008 11:31 PM by Bloersch. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Jun 25 2008 4:43 PM
    • Bloersch
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 140
    • Points 1,705
    Mute clip in audio track
    Is there a way to mute a clip in an audio track so if I undo the mute all volume settings remain?
    For example, I have the original sound of a dialogue which I adjusted with volume and than I have some synchronized audio takes which I adjusted also with different volume settings. I want to let both tracks in my sequence and work with them so that I can decide later which track I want to hear and give both to the sound mix.
    I could pull the volume down with audio mixer but than I have to do all the adjustments again.
    I could park the clip on a different track an mute that track but than I have too many tracks to work with (I already have 16).
    There is a mute button in the audio mixer but it only mutes the hole track.
    Can I select a clip and say "mute that" ?
    If not, put it in the feature request forum, please.
    MC 3.01, OSX 10.4.11, MacBook Pro 17'', 2.33 GHZ Inter Core 2 [view my complete system specs]
  • Wed, Jun 25 2008 4:45 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    Re: Mute clip in audio track
    Just click the speaker icon next to the track to turn it off or click the "m" button above the slider in the Audio Mix tool.
  • Wed, Jun 25 2008 4:46 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    O..sorry, mute just a clip. Not that I know of.
  • Wed, Jun 25 2008 5:44 PM In reply to
    • NP
    • Edmonton
    • Posts 47
    • Points 540
     If you want to mute individual clips and not effect your audio mixer settings you could use the "Auto gain" rubberbanding to quickly put the volume to zero.  Then it's easy to remove later - just select the clip and hit delete - it will remove any audio keyframes you had added.
    Essentially to mute a clip - you hit add key frame then drag the arrow head down
    to unmute - select clip then hit delete
  • Wed, Jun 25 2008 6:15 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,095
    • Points 60,880
    NP:
    I believe you meant to say, to unmute, select the keyframe and hit delete. You don't want to delete the entire clip.
    Media Composer Adrenaline PC v 2.7.7 * Newscutter Adrenaline PC v 6.7.7 * XDCAM PDW-1500 & PDW1 * PDZ-1 XDCAM Browser * Pixelan SpiceMaster 2.0 plug... [view my complete system specs]
  • Wed, Jun 25 2008 6:22 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    Actually, the poster means to select the clip with segment editing mode and hit delete. This will remove the auto gain settings without deleting the clip.
    It also removes any volumes set in the Audio Mix tools though I don't know in what order the Auto Gain/Audio Mix settings are removed.
  • Wed, Jun 25 2008 7:36 PM In reply to
    • NP
    • Edmonton
    • Posts 47
    • Points 540
     Blkdog has it right
  • Wed, Jun 25 2008 8:14 PM In reply to
    • Yasch
    • Joined on Tue, Sep 19 2006
    • New York
    • Posts 37
    • Points 480
    An alternative work-around:
    Create new tracks for the second audio take and just mute the entire track.
    You can even hide the track if you want to keep things tidy. (Select the track and press Shift+Ctrl+H)
    Media Composer v2.8.3 (PC) HP xw8200, Xeon 3.40GHz, 3GB RAM, 4TB Unity MediaNetwork Server (connected via 4Gb Fiber) [view my complete system specs]
    Yanky Ascher
    Jewish Educational Media | Avid Editor
  • Wed, Jun 25 2008 11:31 PM In reply to
    • Bloersch
    • Berlin, Germany
    • Posts 140
    • Points 1,705
    Thank you.
    Auto Gain could be a good solution if I didn't use it on that clip before.
    I never thought about working with hidden tracks but it sounds interesting.
    cheers
