Latest post Fri, Jun 27 2008 3:42 PM by Solopost. 7 replies.
  • Wed, Jun 25 2008 9:39 AM
    • sedated
    • Joined on Wed, Jun 25 2008
    • Posts 2
    • Points 40
    No Audio MC 3.0/1394
    Hey fellow Avid addicts.  Just installed the software only version of Media Composer on a secondary edit box that we are using for Log/Capture.  There is a problem though.  We have a Sony DSR45A connected via Firewire and a Sony Betacam deck routed into the DSR45A.  Now the issue is that when I bring the Log/Capture window up to capture media playing on the Betacam deck, I get video but no audio.  I know that it is working properly because I get both audio and video when I bring up the capture window in Premiere CS3.  Am I missing something here?
    Any help would be greatly appreciated.
  • Wed, Jun 25 2008 10:16 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,022
    • Points 11,715
    Re: No Audio MC 3.0/1394
    Try inserting a bust tape into the DSR45 and hitting record.
    Using a deck as a pass through device is only possible if the deck is recording from the input signal to it.
    XW8200 2x3.2Ghz Xeon nVidia 3450 3Gb Ram Media Composer 3.0 w/Mojo 2Tb storage (mixed SCSI/SATA/1394)---------------Mac Pro 2xQuad-Core Intel 3Ghz 9Gb... [view my complete system specs]
    My Two Cents .02
    Kent Brockman
  • Thu, Jun 26 2008 1:23 AM In reply to
    • sedated
    • Posts 2
    • Points 40
    Is this only the case with Media Composer?  I am able to successfully get pass through to work with Premiere.  We don't want to use Premiere.
  • Thu, Jun 26 2008 1:31 AM In reply to
    • dexter2999
    • Posts 7
    • Points 75
     In MC is your capture set to control deck or no deck? If you select no deck, it may record. If you have the Sony Deck selected it may be looking for a running time code or to control the deck.
    Good Luck
  • Thu, Jun 26 2008 11:38 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,022
    • Points 11,715
     "Is this only the case with Media Composer?  I am able to successfully get pass through to work with Premiere.  We don't want to use Premiere."
    Negative. This was across the product board as of, I want to say, 5.5.x (but could be wrong).
    My Two Cents .02
    Kent Brockman
  • Thu, Jun 26 2008 9:24 PM In reply to
    • MIkeFilm
    • Joined on Mon, Apr 24 2006
    • Posts 202
    • Points 2,700
    I CAN"T BELIEVE AVID HASN"T FIXED THIS
    Do we have to go back to 5.2.4??
    come on Avid
    Mike
  • Thu, Jun 26 2008 9:31 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,696
    • Points 161,335
      Moderator: MCA Mac
    I know. and don't think we haven't been hammerin' on em. For some reason they refuse.
    Ok Avid, you say you are listening.. so start listening. We want this fixed. You broke it it in x.5 so please fix it.
  • Fri, Jun 27 2008 3:42 PM In reply to
    • Solopost
    • New Jersey
    • Posts 1,022
    • Points 11,715
    Whilst in some way I agree - I don't see this as a bug that need's fixing. Using a deck as a transcoder was not a feature of the software, but merely something that just happened.
    From a selling standpoint I could see 'removing' this as a push for folks to get the Mojo (afterall - isn't that what it's for.. transcoding analogue to digital?). But from an 'editor-on-the-street' position, especially as everyone else allows this, it was a bit of a blow that it was pulled. But when has Avid ever done what everyone else allows?
    My Two Cents .02
    Kent Brockman
