Does anyone know if you can connect to two separate servers with the ATTO Dual Fibre Channel Cards? We have two servers and I would like to be able to access them both simutaneously.
MacPro, Unity 5.1 and Unity 4.X servers.
No, it is not possible.
DQS
www.mpenyc.com
Thanks Dom.
Its not Posible using the Fiber Manager (Application only looks at a single Channel), But it can be done.
I have a Backup Machine that has a FC-42XS connected to both Unity Server and with SAS Drives and Unix scripting to Auto Mount Partition for backup and umount when its done.
Ted Simbajon
Head Janitor
It is possible to connect to two servers at the same time, but not quite the way you are thinking about doing it.
If you have Port Server going on one of those servers, use Ethernet to connect to that server and use Fibre to connect to the other server.
I have been trying to set up two servers with simultaneous Fibre connection from one client, but it's not been happening for me logistically. But it should be totally possible if you run the same FM version on both servers.
I was able to connect 2 Unity Server on a single machine at the same time via Fiber Optics.
If you guys are interested, ill be willing to help.
briMestone
Yes, please share.
Thanks!!
Install like you normally install an FC-42XS, then install Fiber Manager 5.1 (Better since it can connect to Older version of Server).
Plug in both Fiber Cable (Server1 and Server2) to each port of the Fiber Card, Confirm all Drives from both Server are connected using the Atto Config Tool, (there should also be 2 FakeCom....)
Now the Unix Part of it all
#This is how you connect to the server without using the Fiber Manager Tool
Mount_Avidfs -U <account> -g GID VirtualName:$MOUNT /Volumes/$MOUNT
#Note, even if you dont use the Fiber Manager, Connected Unity Drives will Work just like Fiber Manager, All the Featues will work including Bin Locking etc etc etc. Also, once both Server are connected to the Machine, you CANT use both Fiber Manager and Administrator Tool, since both of those application would only look at a single Fiber Channel.
Now im not great in GUI coding nor an Xcode GURU, so here is something geeky that works for me.
##### 2 Unity Backup System Via Fiber By Ted Simbajon: t3ddy94123@yahoo.com #####
#!/bin/shSPACE1="Partition1"SPACE2="Partition2"SPACE3="Partition3"LOOP=3COUNT=0rm STATUS.logwhile [ $COUNT != $LOOP ] do COUNT=$((COUNT+1)) MOUNT=$( eval echo \$SPACE${COUNT}) MOUNT2=$MOUNT"_" mkdir /Volumes/$MOUNT mkdir /Volumes/$MOUNT2 mount_Avidfs -U <account> -g GID VirtualName1:$MOUNT /Volumes/$MOUNT mount_Avidfs -U <account> -g GID VirtualName2:$MOUNT /Volumes/$MOUNT2 chflags nouchg /Volumes/$MOUNT2/"Avid MediaFiles" rsync -avru --delete --progress /Volumes/$MOUNT/ /Volumes/$MOUNT2 chflags uchg /Volumes/$MOUNT2/"Avid MediaFiles" du -hsx /Volumes/$MOUNT >> STATUS.log du -hsx /Volumes/$MOUNT2 >> STATUS.log umount /Volumes/$MOUNT umount /Volumes/$MOUNT2 rmdir /Volumes/$MOUNT rmdir /Volumes/$MOUNT2 Sleep 5donemailx -s "STATUS REPORT" t3ddy94123@yahoo.com < STATUS.log
Feel Free to ask questions
Thanks much Ted!
I'll give it a try.
Just to confirm, we were able to do this as well, with Ted's help of course.
We did have to use a 42XS because as far as I know there are no drivers for the 3321 on a Mac.
We're still in the process of getting it done on the PC--I'm sure we'll get there (now, with Ted's help), but just didn't have enough time to work it out today.
It's actually quite groundbreaking for us. Thanks, Ted.
~Hammer
[EDIT: We were able to mount both workspaces (from seperate unity's) on Tiger when both unity's were 4.1.5. When testing with 5.1 and 4.1.6, we weren't able to (quickly) get Tiger to work. Although it may have worked with more fiddling, we just upgraded to Leopard and attempted both successfully. Now this is so old-hat(), we want to do the ultimate test, which is actually what our client needs: Two existing unity's going into one brand new. ...a 42 XS and a 41 XS...connecting 3 at a time. ]
Hahahahaha... and? how did it go?
i think, you have to beef up the memory on the bridge machine.
Ted
