Latest post Fri, Jun 27 2008 11:23 AM by scocklin. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Jun 24 2008 2:48 PM
    • scocklin
    • Maryland
    • Posts 308
    • Points 3,815
    Can't install Digi Drivers without XP Updates
     Trying to install digi drivers after MC 3 install, I keep getting a windows message saying:
    Your computer is missing a Windows XP update required by protools. Please install all available critical updates before installing Pro tools.
    My updates are off, should I turn them on?
    HP xw8200 Dual 3.6GHz Xeon processor 2MB L2 ea. 4GB Ram Avid Mojo REV 3 Nvidia Quadro FX 3500 video card driver v.169.46 Avid MC 3.0 Sonnet Tempo SATA... [view my complete system specs]
  • Thu, Jun 26 2008 3:17 PM In reply to
    • scocklin
    • Maryland
    • Posts 308
    • Points 3,815
    Re: Can't install Digi Drivers without XP Updates
    Just thought I'd bump this up one more time with a little more information.  After deleting Pro Tools from my system I tried to get my 002 to work with Avid, when MC 3.0 didn’t recognize the digi 002 I tried to delete the 7.4 drivers and got the Windows critical updates message. If I try to install the digi drivers I get the same message.
    BTW I just got back from a one moth shoot overseas with a little more than 30 hours of HD tapes.  After installing 3.0 I started  capturing the footage, 15 hours into the capture process and all has been flawless.  No problems with time code breaks and the machine control has worked perfectly using only a firewire connection into a Panasonic 1400 deck without the usual Rosetta cable hookup.
  • Thu, Jun 26 2008 3:19 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    3.0 Supports service pack 3. Did you install that yet?
    Great to hear about your success!
  • Thu, Jun 26 2008 3:25 PM In reply to
    • scocklin
    • Maryland
    • Posts 308
    • Points 3,815
     No I didn't, I read the readme file but I guess I missed that part
    Thanks for your reply!
    Steve
  • Thu, Jun 26 2008 3:30 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    Good luck and let us know how it goes...
  • Thu, Jun 26 2008 3:41 PM In reply to
    • fiendish
    • Posts 204
    • Points 2,470
    SP3 is supported now BLKDOG? An article in the Knowlege Base seems to suggest it isn't.
    MC 3.0 / QT 7.4.5 on xw9400 with Mojo SDI - 4gb / quadro 3500 and 3ware 9650SE Raid 5 (and flamethrowers!) [view my complete system specs]
  • Thu, Jun 26 2008 3:51 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    My Bad. We were told SP 3 would be supported when 3.0 was released but, apparently it didn't make it out of SQA.
    I'm checking with them now to see what the status is. Hold tight.
  • Thu, Jun 26 2008 3:57 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    Ok, so, apparently there was an issue that kept it from being approved for 3.0 but it should be included in a future release.
    Sorry to jump the gun.
  • Thu, Jun 26 2008 4:02 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,641
    • Points 160,550
      Moderator: MCA Mac
    The error message you are getting is due to a missing Hot fix.
    This page may help you get going.
  • Thu, Jun 26 2008 4:03 PM In reply to
    • scocklin
    • Maryland
    • Posts 308
    • Points 3,815
     Thanks again Blkdog,
  • Fri, Jun 27 2008 1:58 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,185
    • Points 36,540
    For what it's worth on the assumption that SP3 is SP2 with all updates up to the SP3 release date, I went ahead and installed it on my new, purpose built MC3 system.  So far I've encountered no issues, and its been given a pretty fair punishing this past weekend..
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
  • Fri, Jun 27 2008 11:23 AM In reply to
    • scocklin
    • Maryland
    • Posts 308
    • Points 3,815
     I should have followed up on this last night, but didn't get around to making the changes until late. Anyway I installed the Windows critical update patch KB926255 (thanks BLKDOG) rebooted and was finally able to uninstall the digi 7.4 drivers and then reinstall them. My digi 002 then started working with MC 3.0. I believe I corrupted the 7.4 drivers after uninstalling PT which I did after the MC 3.0 install.
    A suggestion might be, if you have Pro tools on your system, uninstall it along with MC 2.8 before installing 3.0.
    I'm not sure what to say about the missing critical update. I have had updates turned off on my system which has been a standing recommendation by Avid for a long as I can remember.
