Latest post Tue, Jun 24 2008 1:18 AM by jwrl. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Jun 23 2008 3:03 PM
    • dariv
    • Joined on Tue, Dec 5 2006
    • Posts 151
    • Points 2,260
    captured footage gone missing, can I retrieve?
    This morning I left my deck running and Avid capturing into a new project. I only have one bin in the project. I consolidated and moved some earlier captured footage from that bin to another project, so now the bin is empty.
    My problem is that when I came back to check on the progress, my camera had run out of batteries, I got the usual keep/discard error message, along with a couple of others. Usually this is no problem as the footage is just sitting there in the bin albeit incomplete.
    However there was no footage there, I went to my other project where i moved the original clips from that bin to, thinking that maybe somehow it had captured to that project; to no avail.
    I'm wondering if I can retreive this footage somehow or whether it is lost and I have to capture again?
    Avid xpress pro v5.5.3 Dell Inspiron 6400 (videoguys tweaked) 80gb hard drive 2gb RAM E:drive 300 gb Deck Varies [view my complete system specs]
    AKA Newbie Wan Kanewbi
  • Mon, Jun 23 2008 3:19 PM In reply to
    • bsuttie
    • Edinburgh, Scotland
    • Posts 591
    • Points 7,470
    Re: captured footage gone missing, can I retrieve?
    Hi, open the Media Tool, select the drive you were capturing to and "All Projects".  See if the clips are in there, identifying them by creation date and time.   If so just drag them to a bin.  If not I think you'll have to recapture.
    regards
    Brian
    Symphony, Adrenaline, Xpress Pro [view my complete system specs]
    "We'll fix it in post"
    "This is post"
    "aaaahh"
  • Mon, Jun 23 2008 3:22 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,168
    • Points 61,775
     Go into your Avid Attic files and find the appropriate bins for each project. You can copy these bins to the desktop, change the extensions to .avb and use the open bins command to open them inside a project. Just do not have an original bin with the same name as the Attic bin open at the same time.
  • Mon, Jun 23 2008 8:37 PM In reply to
    • dariv
    • Posts 151
    • Points 2,260
    cool thanks guys, I'll give those a try
  • Mon, Jun 23 2008 10:16 PM In reply to
    • dariv
    • Posts 151
    • Points 2,260
    I tried the media tools solution and couldn't see the files, I wanted to try the 'Avid Attic' as well but I don't know how to access this.
    How do I get into avid attic?
    cheers
  • Mon, Jun 23 2008 10:24 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,168
    • Points 61,775
     I believe the path is C:\program files\Avid\Avid Attic. If that's not correct, just do a search for "Avid Attic" and the system will define the path for you.
  • Tue, Jun 24 2008 1:18 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,213
    • Points 36,860
    If you didn't see them in the media tool it's unlikely bringing in bins from the Attic will help.
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
