Latest post Mon, Jun 23 2008 1:42 AM by Tugger. 3 replies.
  • Sun, Jun 22 2008 12:33 PM
    Pocket external drive fast enough for editing?
    im thinking about buying a pocket mini external drive for example Iomega Silver Line
    or TrekStor DataStation Pocket x.u
    Those drives are handier, small and easy to transport.
    Im thinking of using it as a musiclibrary, but also as a drive where my OMFI MediaFiles are on. That means it should be fast enough to edit on Avid with this drive.
    Now my question: are those pocket drives fast enough? I already have the experience to edit on normal-sized drives and it works fine. Only problem is that they are so big to carry around.
    So what do you think?
  • Sun, Jun 22 2008 4:48 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 977
    • Points 11,555
    Re: Pocket external drive fast enough for editing?
    Make sure that the drive is 7200rpm.  I wouldn't think about editing on a slower drive.
    System #1 -Tyan i7525 MB, dual 3.2 Xeon, 4 GB Ram, Mojo, Quadro 3500, Pyro 64 FireWire, 6 TB Unity System #2 - Intel 7505VB2 MB, Dual 2.8 Xeon, 2 MB... [view my complete system specs]
  • Mon, Jun 23 2008 12:19 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,461
    • Points 40,025
    The spindle speed doesn't have a lot of bearing in this case.  Port powered drives may be just fast enough for DV25 or HDV, but I wouldn't be too surprised if the playback was choppy.
  • Mon, Jun 23 2008 1:42 AM In reply to
    • Tugger
    • Champaign Illinois USA
    • Posts 390
    • Points 4,855
     I've successfully used lacie, iomega, and seagate pocket drives over the last couple of years. Occasional stutter when scrubbing through a timeline, but nothing that ever compromised an edit. These where just :30 TV spot projects, and SD (at DV resolution). I once pressed them into service for an HD edit (720p P2 material) when it was all I had handy: Occasional stutters on playback, general lag in accessing (I could hear the poor things spinning like crazy as they seeked files) Definately wouldn't suggest them for an HD/HDV work. Not sure what hardware you run, but you'll want to make sure the usb/firewire ports provide a sufficient amperage (all ports will kick out a 5v current, but not all provide enough amps behind the volts to run the drives-macbooks for example, don't)
    good luck
    MediaComposer 3 on HP nw9440 (2.17ghz dual proc-nVidia 1500m-4gig RAM) / AXP 5.8 on HP 8710 (2.1ghz dual proc-nVidia n320m quadro-4gig RAM) USB or eSATA... [view my complete system specs]
