Latest post Mon, Jun 23 2008 1:18 PM by jwrl. 14 replies.
Page 1 of 1 (15 items)
  • Sun, Jun 22 2008 11:51 AM
    • Maguire
    • Joined on Mon, Aug 13 2007
    • Posts 11
    • Points 165
    Capture across timecode breaks
     Having a bit of hassle with my system, on some shoots I lock the TC on the cameras to the same TC. I've selected "Capture across timecode breaks" in the preferences menu, but still when the timecode breaks to the next shot the system stops digitizing and pre-rolls again making a seperate clip. What I want to do is capture the entire tape, broken timecode and all to one clip how do I do this?
  • Sun, Jun 22 2008 12:13 PM In reply to
    • camoscato
    • Posts 4,783
    • Points 57,025
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Capture across timecode breaks
    Maguire:
    You can't.  When the system hits a timecode break, it will stop and then make a new clip starting with the new timecode, as you've described.  It's working like it's designed to.
    If you want to capture the tape as one long clip, you might be able to do it by turning off the timecode track on the capture tool, but then you won't have timecode that matches what's on the tape, so I'd advise against doing this.
    good luck,
    Carl
  • Sun, Jun 22 2008 1:26 PM In reply to
    • Maguire
    • Posts 11
    • Points 165
     Thanks Carl,
    I shot a film on turbine transport last week and used 2 DVCPRO cameras locked together, I'm trying to cut the sequence using the timecodes. Camera 1 was in the cab of the lorry and camera 2 was out on the road. The driver talks through his task of moving around traffic islands and roundabouts. but the pre-roll is cutting off the first few seconds of his audio. I might try adjusting the pre-roll time.
    Garret
  • Sun, Jun 22 2008 1:39 PM In reply to
    • camoscato
    • Posts 4,783
    • Points 57,025
      Moderator: Meridien
    Hi Garret,
    That sucks.  Depending on how tight it is, you might be able to get away with a 1 second preroll.
    good luck,
    Carl
  • Sun, Jun 22 2008 3:04 PM In reply to
    • Maguire
    • Posts 11
    • Points 165
     So what does "capture accross timecode breaks" actually do? Strange
    Garret
  • Sun, Jun 22 2008 3:26 PM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Rankweil | Austria | Europe
    • Posts 228
    • Points 2,900
    you might use the function called "Use control track instead of timecode track" in addition to set the preroll to 1 second. the player should switch to CTL on the breakpoint, set it to zero, preroll and start capturing directly at the inpoint.
    regards - Moses
    Avid Adrenaline DNxcel | HP xw8400 - Xeon CPU @ 2.66 GHz - 3GB RAM | easyRAID 4TB | MC 3.1 | PDW-U1 (Firmware 2.2) | DVW-M2000P [view my complete system specs]
  • Sun, Jun 22 2008 6:11 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Posts 164
    • Points 1,865
    Maguire:
    Garret
    It does what you describe, when it hits a timecode break it prerolls again and carries on capturing instead of just stopping. This is how a professional NLE should behave. You can't have timecode that jumps around in the middle of a clip, and if it 'ignored' the TC break then all TC from that point on would be wrong.
    If timecode isn't important to you you can capture with internal TC which will eliminate the problem, if you need TC for conforming etc then trying a 1 sec preroll is the only option other than getting tapes dubbed with continuous TC
    Next time make sure you shoot preroll!
    2x MC 2.6.6 with Mojo on HP xw8400 MC Adrenaline 2.6.6 on HP xw8400 MC 2.8 on MacPro dual 2.66 Editshare 4.1 [view my complete system specs]
  • Sun, Jun 22 2008 6:36 PM In reply to
    Maguire:
    Unlike the name of the feature, it stops capture and restarts capture after a recue. Without the option selected, any TC break will result in a full stop, without an automatic recapture.
    I think it would be one of the coolest thing if the Avid would actually capture across the breaks, without needing to preroll. Just keep it rolling and whever there's valid video and valid TC, capture it. Even if the result is separated master clips.
    Symphony Nitris 3.0 on 2xquad core XW8400/8GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB |... [view my complete system specs]
  • Sun, Jun 22 2008 7:32 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,568
    • Points 78,475
     But for now, if you have a critical need for the source timecode, the best option as pointed out before is to set a custom pre-roll for 1 sec and continue the capture process. Yes, you'll wind up wiith a new clip at each timecode interruption, but you will only lose 1 second of material after each broken spot when the capturing resumes.
  • Sun, Jun 22 2008 7:51 PM In reply to
    Job ter Burg:
    Great idea. I have been suggesting this to Avid for as long as I can remember and in the forums since I joined. It just falls on deaf ears for some reason. It would solve the current problem and also make a huge difference to onlining client masters from tapes that were captured the whole length.
    Maquire:
       I would suggest manual capture. Turn off deck control, roll the deck with it's play buton and hit the Avid record button when you want to start recording.  With a couple of trials over the bad area so you know the footage and timing of the break you can get your Avid capture to start within 5 to 10 frames of the break.
    Downside to this method is that you will not be able to batch capture from the same start point subsequently
  • Mon, Jun 23 2008 12:09 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,600
    • Points 41,650
    I can remember discussing this issue with an Avid rep at a local trade show in 1995 or 96.  He thought it sounded a good idea and made a note about it.  I guess that's as far as it went.
    I understand that it probably requires verifying timecode stability before capture can truly start.  If the incoming video stream is buffered while timecode is monitored for stability over say, 15 frames this should stop the problem.  An algorithm something like:
    Record media stream.  If it's frame 1, repeat.  Check timecode against previous frame(s).  If it's consistent go to normal record mode.  If we haven't reached the end of our check window repeat.  Otherwise quit.  Optionally post user response message.
    There you go Avid.  I'll leave it to you to flesh it out and develop the timecode check routines!
  • Mon, Jun 23 2008 1:16 AM In reply to
    jwrl:
    I have been suggesting for several years that they already have the basics written with DV scene detection.
    Embedding TC at capture time and then using a modified "scene detection" to split the captured master clip  into "new timecode continuous masters" at TC breaks during/immediately after capture should be achievable.
  • Mon, Jun 23 2008 7:12 AM In reply to
    AndrewAction:
    But from what I can tell will have a major impact on the current way that Avid metadata management is handled.
  • Mon, Jun 23 2008 8:06 AM In reply to
    Job ter Burg:
    Never been big on anything Meta!.
    Seems absurd you can have 6 layers of HD playing realtime and yet cannot capture offtape TC so we can work with accurate TC.  Geez I had 8F accurate TC on Linnear systems before 286's with 1MB of RAM were around so is it really to much to ask with todays procesing power.
  • Mon, Jun 23 2008 1:18 PM In reply to
    • jwrl
    • Posts 3,600
    • Points 41,650
    Job ter Burg:
    (It) will have a major impact on ... Avid metadata management
    I don't understand why that should be so.  It will have an effect on the creation of the metadata, but it shouldn't have any effect on the subsequent handling.
