i made subclips from the masterclip after TC , and now i finished my cut and need to make a EDL for scanning . i found out that the EDL can't show the labroll from subclip , it show the Tape no. instead of labroll . But it was no problem if the cut is worked on the masterclip , it is weird .
so if i want the labroll show in the EDL, then i cant work on the subclip ???
anyone can help??
i am using Avid MC 2.8
I can't follow.
What do you mean by "after TC"?
curranpang:the EDL can't show the labroll from subclip , it show the Tape no. instead of labroll
curranpang:it was no problem if the cut is worked on the masterclip
Can you see whether the labroll entry is present for those subclips in the bins in Avid?
curranpang:if i want the labroll show in the EDL, then i cant work on the subclip
It should not cause any problem.
curranpang:i am using Avid MC 2.8
PAL? NTSC? 24? 23? 25?
This was a bug in EDL Manager in the 2.8.x code. It has been fixed in v3. As a workaround, duplicate the Labroll column into the Camroll column and use that. If you have important metadata already in the Camroll, make a custom column and store it in there for the interim. Camroll will work in EDL Manager.
Michael
Thank michael!!! the problem is fixed~~ you help me alot!!!
