Latest post Sat, Jun 21 2008 8:33 PM by Larry Rubin. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Jun 21 2008 3:00 PM
    • carlguile
    • Joined on Tue, Oct 23 2007
    • Posts 14
    • Points 190
    Quicktime reference - field order?
    Hi
    I'm sure this is a basic one but I'm stumped.  I'm trying to export a QT reference but my export is coming out with the strange 'line' effect which I'm fairly sure is to do with field order.  Excuse my lack of knowledge on this one but if any could help me out I'd be very grateful!  Can I adjust QT reference settings?
    Thanks in advance!
  • Sat, Jun 21 2008 3:02 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,602
    • Points 78,200
    Re: Quicktime reference - field order?
    define "line effect" and how you are seeing this?
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Sat, Jun 21 2008 3:17 PM In reply to
    • carlguile
    • Posts 14
    • Points 190
    yeah sorry its vague.  When I check it back in QT player its around any area with motion, the movement causes the image to shift into... almost like a venetian blind effect. Is that a bit clearer?
  • Sat, Jun 21 2008 3:40 PM In reply to
    • Baklap
    • Posts 6,602
    • Points 78,200
    yeah much Wink but it is pretty common to see this.. if the QT is good as in there are no: A mixed resolutions on the timeline and B: no fillers (gaps) then you should be fine with the final encoding. QT is a horrible interlaced video playback enigine
    Menno
    Dutch AV forum
  • Sat, Jun 21 2008 5:25 PM In reply to
    • carlguile
    • Posts 14
    • Points 190
    great!  Thank you so much for your help, much appreciated!
  • Sat, Jun 21 2008 8:33 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,435
    • Points 64,980
     Just a quick note. For American NTSC, the field order for export should be even (lower) field first. This is especially true for exports destined for enhancement in After Effects and subsequent re-import back into an Avid project.
