Latest post Sun, Jun 22 2008 5:16 PM by Unpr0. 9 replies.
Page 1 of 1 (10 items)
  • Sat, Jun 21 2008 1:50 PM
    • Unpr0
    • Joined on Sat, Feb 16 2008
    • Posts 9
    • Points 120
    Another MC Initializing Audio problem
     I've tried not asking, realising just how many types of these problems you see but it seems like I've tried everything and yet still Avid is not starting up. So I hope you don't mind me offering my problem as well.
    It get's to 'Initializing Audio' and then just does nothing. When I go to 'Windows Task Manager' it says it's not responding. So after coming on here reading that I wasn't alone in this I went and baught a Soundbalster card to no avail, changed the drivers did everything that was suggested and it didn't work. So then I tried buying more RAM reading that sometimes it gives up looking for the Audio if it can't handle it, but it's still not working.
    It started about a month ago with Avid Xpress, so I upgraded it to Media Composer and after it worked once it hasn't worked since.
    Any idea's? At this point I'm up for anything....although I'm hoping I wont have to spend more money then I already have.
    I realise you may want my computer specifics so....
    Elite Inpsire SO54644-0015
    Pentium (R) D CPU
    2.80GHz, 2.00GB or RAM
    As I say, any help you can give would be greatly appreciated.
  • Sat, Jun 21 2008 2:19 PM In reply to
    • camoscato
    • Posts 4,516
    • Points 53,945
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Another MC Initializing Audio problem
    Usually the Soundblaster card fixes it.  What specific Soundblaster card did you get?
    good luck,
    Carl
  • Sat, Jun 21 2008 3:03 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,612
    • Points 78,310
    also check if there are any USB devices with audio capability connected.. mic, webcam etc etc..
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Sat, Jun 21 2008 3:38 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,326
    • Points 38,225
    Webcams in particular have been known to interfere with sound on Avid.
  • Sat, Jun 21 2008 3:46 PM In reply to
    • camoscato
    • Posts 4,516
    • Points 53,945
      Moderator: Meridien
    The list of things to try includes:
    1. Get a new card (the Soundblaster Audigy 2 and Audigy SE work; you've already done this, but with what card?)
    2. Try different audio card drivers
    3. Unplug any USB items that may be conflicting (as the others have said, this would be webcams, microphones, printers, etc)
    4. Change your Windows Mixer settings
    good luck,
    Carl
  • Sat, Jun 21 2008 9:53 PM In reply to
    • Unpr0
    • Posts 9
    • Points 120
     Thanks for getting back to me.
    The Soundblaster card that I baught was an Audigy SE 7.1
    I do not have a web cam but I tired disconnecting the USB linked to the printer and it did no good.
    I updated the drivers when I got the new card but I have not tried different ones. Are there any in particular that you would recommend?
    And, how do you mean change the Windows Mixer settings?
    Thanks again.
  • Sun, Jun 22 2008 9:27 AM In reply to
    • camoscato
    • Posts 4,516
    • Points 53,945
      Moderator: Meridien
    In Windows XP go to the Control Panel and then go to Sounds.  One of the tabs should bring up your audio card settings, where you can specify what audio device Windows uses.  Switch it to your Soundblaster card.
    good luck,
    Carl
  • Sun, Jun 22 2008 1:14 PM In reply to
    • Unpr0
    • Posts 9
    • Points 120
    Ah yes, I've already done that. Sorry, I didn't quite understand at first.
    It's still not working. Any other idea's please?
  • Sun, Jun 22 2008 1:45 PM In reply to
    • camoscato
    • Posts 4,516
    • Points 53,945
      Moderator: Meridien
    Yours is the first post I've seen where installing an Audigy SE card didn't solve the problem.  At this point I'd try reinstalling Media Composer.
    good luck,
    Carl
  • Sun, Jun 22 2008 5:16 PM In reply to
    • Unpr0
    • Posts 9
    • Points 120
     Lol, I've already tried that as well. You can see my problem. I was so hopeful when I thought it was just the soundcard. I really don't understand why it's not working.
    Do you think reinstalling Avid Xpress Pro would work instead?
