Latest post Mon, Jul 7 2008 1:01 PM by Job ter Burg. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Jun 20 2008 8:50 PM
    export to jpeg2000 mxf for DCI for DOREMI player
    Does anyone know a software way of exporting from AVID and creating a file that can play on a DOREMI DCP2000 cinema player on either a JPEG 2000 MXF format or MPEG2 MXF interop?
    It seems hardware encoding is the only way but it seems to defeat part of the purpose of these great projection systems if there's no easier/cheaper way to workflow our work onto them.
    Any suggestions?
    Filed under: , , , ,
  • Fri, Jun 20 2008 8:58 PM In reply to
    Re: export to jpeg2000 mxf for DCI for DOREMI player
    You can export directly from within Xpress Pro to a Quicktime file. Choose a custom Quicktime format and you'll be able to select JPEG 2000 compression for the video. Not sure what help (if any) that may be, but it never hurts to mention suggestions. Smile
    MSI Neo-2 Platinum Nforce3 Ultra (Bios Rev 1.0D) Athlon64 X2 4200+ (Overclocked to 2 x 2.4GHz) AMD Cool'N'Quiet CPU Throttling 2GB Corsair PC3200... [view my complete system specs]
  • Sat, Jun 21 2008 1:12 AM In reply to
     Yes a jpeg2000 can be done in quicktime but that doesn't provide the MXF wrapper needed for the Doremi. It's seems a bit overly complicated and one wonders if it is by design so that the expensive hardware encoders can be invaluable.
  • Mon, Jul 7 2008 5:30 AM In reply to
     Good Luck, Me and a couple programers figured out how to create Jpeg2000 mxf files that playback beautifully on a Doremi. There deffinatly is a Software solution but it requires linux and is all comand line. I'm Not going to give away the formula but I will say that the Jpeg2000 is only a tiny piece of the puzzle. The hard part is getting your footage into the XYZ Colorspace, If you run regular RGB Footage on a Doremi it looks VERY Red Heavy. Also the Jpeg2000 is only one out of 6 steps to making a Doremi file. I'm Not sure but I Highly doubt that there is a plugin to make a Doremi package from Avid. Oh and Even if you have an MXF file that is compatable it won't play without the xml files to tell the doremi what to do with the file. Yes this is very hard and I would bet was created that way to keep people from making movies at home and creating competition for the big studios. However if a stoner like me could figure it out I'm sure more people will eventually get it. Keep up the good work!
  • Mon, Jul 7 2008 7:01 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,185
    • Points 36,540
    It's your fisrt post, polytonepictures, and normally you'd get a welcoming response.  But since it appears that you signed up to the forum just so that you could gloat about how you could do something and you're not going to share the knowledge, I'm not so sure.
    Nice one.
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
  • Mon, Jul 7 2008 1:01 PM In reply to
    That's not much help. Why are you here if you don't intend to share yor knowledge?
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
