Latest post Sat, Jul 5 2008 6:28 PM by Brickwad. 15 replies.
  • Thu, Jun 19 2008 11:15 PM
    • s.malkie
    • Joined on Tue, Nov 1 2005
    • Richmond, VA
    • Posts 7
    • Points 115
    Feature Requests / SNDX
    1. DVE Quality. I don't care if it's blue-dot, processor-intensive , or whatever - give me better filtering on all DVE-type moves. Even changing the position (no scaling) on a Matte Key softens and chews up the text substantially. Make it a Render Setting like HQ / the Pan & Zoom effect or whatever, but having to bounce titles back and forth from Photoshop because I know I can't move them in the Symphony without them going all to hell really kinda blows. This could be a very easy way of separating the Symphony from the MC, if that's something Avid is interested in doing.... OR since the common thing seems to be letting the quality of the native effects stagnate and just bundling BCC, let me import .PSDs directly into a BCC DVE or BCC Matte, rather than having to nest or jump through hoops.
    2. Spot Color Effect - why doesn't FF/REW work to switch between shapes like it does in Paint / Animatte? Also, can we get Paint / Animatte / Spot Color to work at 10bit? Kinda defeats the purpose of working at 10bits when to do any sort of work to video it's only going to get processed at 8. Same thing with Pan & Zoom and Blur.
    3. Lastly, would it be too hard to display two fields when paused. I know the Avid has done the 'pause on field 1 only' since time immemorial but when I'm trying to Color or do Scratch Removal only seeing half the information on my outboard monitors kinda sucks. Steal a page from DS and give me the option to pause on field 1, field 2, or the whole frame.
    4. Vista64 is qualified but xp64 isn't? I'm not upgrading to Vista but would love a 64-bit OS.
    It is fast and (knock on wood) stable so far, though.
    Thanks for reading,
    -Scott
    Symphony Nitris DX v3.0 / xw8600 / XP32 [view my complete system specs]
    Scott M. Malkie | Post Production Supervisor | Richmond, Virginia
  • Fri, Jun 20 2008 12:31 AM In reply to
    • rdeditor
    • Los Angeles
    • Posts 58
    • Points 785
    Re: Feature Requests / SNDX
     Personally the thing I'd like most is a garbage matte feature in spectra matte
    Freelance. Symphony, Symphony Nitris, DS Nitris [view my complete system specs]
    "Whenever you find yourself on the side of the majority, it is time to pause and reflect."
  • Sat, Jun 21 2008 5:17 AM In reply to
    • s.malkie
    • Richmond, VA
    • Posts 7
    • Points 115
    Oh, and I just found out about the "SetResizeType 9" command.
    It's better, but if this current quality is "9" there needs to be a "SetResizeType 12" command.
    And really - Spot Color needs to work at 10-bit, with better support for multiple shapes in one effect.  It would ALSO be very nice to be able to invert a shape as well (in other words, make an oval, and fill the rest of the raster except for the oval.   A simple "Invert Alpha" or something would suffice.   Again look at DS and the "Invert" checkbox of the "Fill" / "Brush" PPG in Graphics Mode.
    Lastly, soft drop shadows in any promoted effect.
    I would be more than happy to sacrifice 4-8 of my RT streams to get better-looking, higher-quality effects.  Use my GPU if you need to, with Domain eXchange you should be able to, right?
    -Scott
  • Sat, Jun 21 2008 10:28 AM In reply to
    You do know about the HQ setting on the 3D effects, right?
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Sat, Jun 21 2008 9:07 PM In reply to
    • s.malkie
    • Richmond, VA
    • Posts 7
    • Points 115
    Oh yes, I've tried promoting and setting HQ render settings...
    Compare the quality of a scaled or repositioned Photoshop file (even with SetResizeType 9 and HQ turned on) vs. the same scaling / repositing in Combustion or AE and it's not even close.
    One looks great, one looks tolerable.
    Again, if dev resources are going to more RT streams instead of things like full-raster pause or soft drop shadows, that's totally Avid's call - just admit where the priorities are, and bundle BCC/Sapphire/Adobe CS3 with every new sale.
    Just my $.02 (which is worth less and less every day),
    -Scott
  • Sat, Jun 21 2008 9:12 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,513
    • Points 65,860
     I'm just wondering if we'll ever have a 3D engine within an Avid application that will be capable of resolution independent scaling.
  • Sat, Jun 21 2008 10:04 PM In reply to
    • Butcher
    • Joined on Mon, Apr 17 2006
    • Evansville, IN
    • Posts 1,202
    • Points 15,270
     Yes! Yes! Yes!
    Michael.
    Dell Precision 490 Dual 3.2GHz Dual Core Processors 4GBs RAM nVidia Quadro FX3450 2 x 500GB SATA in RAID 0 (I know, I know) storage Media Composer... [view my complete system specs]
  • Sun, Jun 22 2008 12:01 AM In reply to
    3. I don't think it would be hard. Although, interlace footage would produce the incredible jitter on certain frames (ie fast moving objects).
    4. It is pointless by now. XP is being phased out and XP64 was just a stop-gap solution for MS.
    Other than that, 1 and 2 have been requested since I can remember :(
    Hopefully someday...
  • Mon, Jun 23 2008 11:23 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 35
    • Points 455
    I just upgraded to SNDX 3.0 from a MC Adrenaline HD. While the DX is much more responsive that the Adrenaline hardware. I am a little underwhelmed by the Symphony software compared to the Media Composer. The color correction on the SN is much more advanced than MC and it will take me some time to learn how to use it all. Unfortunately, that's about where the difference ends from what I can tell. The rest of the interface and effects appear exactly as in MC.
    I have been using MC since the mid '90's and over the years I thought there would be a bigger difference between MC and SN. There has always been a big price difference between the two. I think it would be great if Avid could give the SN a few more bells and whistles to help justify the difference in costs.
    Derrick
    Mac Pro 8 Core 3.0ghz, Symphony Nitris DX 3.0.5, 3 gigs RAM, OS 10.5.4, AvidVideoRaid 1.2 terrabytes, Atto Ultra 5D, dual Apple 23 cinema, HDCAM HDW-D1800... [view my complete system specs]
  • Mon, Jun 23 2008 11:57 PM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 386
    • Points 4,635
    Universal mastering is pretty big, for me at least.
    I have 10 Avid systems, DX, Meridian and DNA. 1 MCA 1.8 on 2.5 quad G5 w/ 5 Gigs of Ram, 1 Symphony Nitris DX on eight core mac pro with 4 gig ram, 1 MC... [view my complete system specs]
    Andy
  • Fri, Jul 4 2008 5:41 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 950
    • Points 11,530
    • Moderator: Avid Symphony Nitris
    I'm still waiting for a soft drop shadow in the DVE.
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Fri, Jul 4 2008 5:46 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,513
    • Points 65,860
    Scott Carnegie:
     Yeah, I remember making a post here requesting this sometime last year, I think it was.
  • Fri, Jul 4 2008 6:17 PM In reply to
    Still SD only, right?
  • Sat, Jul 5 2008 2:56 AM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 386
    • Points 4,635
    Job ter Burg:
    Nope, HD too.
    Andy
  • Sat, Jul 5 2008 8:34 AM In reply to
    Hmmmm. On the L, Terry says otherwise.... ??
