Latest post Thu, Jun 19 2008 8:50 PM by Baklap. 2 replies.
  • Thu, Jun 19 2008 8:13 PM
    • weekender
    • Joined on Thu, Jan 4 2007
    • Vancouver, Canada
    • Posts 14
    • Points 240
    I transcoded some captured HDV to DNxHD and the DNxHD file is larger. Are my settings wrong?
    I shot my footage in HDV and captured it with setting the PROJECT TYPE to 1080i/59.94 HDV. I captured 8 minutes of video and I checked the size of the media file on the harddrive after and it was only 1.5GB. When you capture in HDV, shouldn't it take up more space? Did I not actually capture it in HDV then? I'm really want to get very good quality out of my project. Then, when I transcoded the 8 minutes of video to DNxHD 145,  the size of this on the harddrive was 8GB, which is 1GB per minute which I believe should be correct(?)  I thought the purpose of transcoding to DNxHD is because the captured HDV files are so huge. Is this not correct or do you think I do not have my settings correct in order to capture in HDV quality?
    THANKS!!
    Windows XP Pro SP2 Avid Media Composer 3.0 Quicktime 7.5 Intel Core2 Quad CPU @ 2.4GHz 4 GB Ram NVIDIA GeForce 7300 GT (512 MB) Video Realtech HD... [view my complete system specs]
  • Thu, Jun 19 2008 8:49 PM In reply to
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 60
    • Points 755
    Re: I transcoded some captured HDV to DNxHD and the DNxHD file is larger. Are my settings wrong?
    HDV has the same data rate as standaard DV I think. So the files will be smaller than DNxHD. One of the  reasons to transcode to DNxHD is for ease of editing, you dont't have to deal with long GOP.
    Media Composer Nitris DX 3.0.5 Dual 3GHz Quad Mac Pro 4GB Ram 10.5.5, Symphony Nitris DX 3.0.5 Dual 3GHz Quad Mac Pro 4GB Ram 10.5.5, Unity MediaNet... [view my complete system specs]
  • Thu, Jun 19 2008 8:50 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,625
    • Points 78,505
    No HDV is small as in 25 mbps .. the trouble with HDV is it is long gop mpeg as in it has no individual frames. That will be noticed when editing. Also the raster size of HDV is smaller then 1980 (as in "normal HD"). The transcode to DNxHD will increase file size because in your case you went to DNxHD 145 as in 145mbps as opposite to the 25 of HDV.
    Editing DNxHD will feel better then editing HDV as it does not has to encode the group of pictures everytime you do something.
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
