Latest post Fri, Jul 11 2008 10:21 PM by robg. 22 replies.
Page 2 of 2 (23 items) < Previous 1 2
  • Mon, Jun 23 2008 7:42 PM In reply to
    • rfayan
    • Joined on Fri, May 5 2006
    • Posts 7
    • Points 100
    Re: Legalizing question
    In the Safe Color Limiter, when you set the levels to 18-232, are you setting the Luma parameter in the Composite/Luma Levels group, or are you setting the RGB Gamut values in the RGB Levels group, or both?
    -Randy
  • Mon, Jun 23 2008 9:05 PM In reply to
    • Red Ochre
    • Joined on Fri, Jan 27 2006
    • San Francisco
    • Posts 215
    • Points 2,740
    Huh? The Hamlet is a peice of hardware, unless there is some aspect of its internal operations that I don't understand.
    MCA 2.7.2 (PC) and mojo MC 3.0 (mac) [view my complete system specs]
  • Tue, Jun 24 2008 2:54 AM In reply to
    • Red Ochre
    • San Francisco
    • Posts 215
    • Points 2,740
    I've been setting the RGB gamut only. When I encounter illegal video I raise the luma but its still ilegal at 7.5 IRE and I must raise it still higher.
  • Tue, Jun 24 2008 4:09 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 125
    • Points 1,675
      Moderator: Avid Symphony Nitris
    Red,
    If possible, I would like to get a small clip that shows the problem. Pleae send me an email (click on robg and hit Options -> Send robg an email) and I will respond with instructions.
    - Rob
  • Mon, Jun 30 2008 5:14 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 125
    • Points 1,675
     Red,
    Your system specs say you are running MCA 2.7.2. Is this correct?
    - Rob
  • Tue, Jul 1 2008 10:57 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 125
    • Points 1,675
    We tracked this down in our lab and found a problem when using the Safe Color Limiter for RGB Limiting on HD material in MC 3.0. The work-around is to enable the Composite/Luma Levels checkbox. This fixes the problem with the RGB limiter. Note that this is not a problem with SD material.
    See the tech note for more info:
    We will keep you posted on a SW fix...
    - Rob
  • Fri, Jul 11 2008 6:43 PM In reply to
    • Red Ochre
    • San Francisco
    • Posts 215
    • Points 2,740
    Hi Rob.
    Is it possible this problem exists with 2.7.2 as well? That's what were running here.
  • Fri, Jul 11 2008 10:21 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 125
    • Points 1,675
    Red Ochre:
    I do not believe this problem exists in 2.7.2.
    We looked at the source code here and did not see any changes to Safe Color Limiting from 2.7.2 to 2.8.3.
    - Rob
