Latest post Thu, Jun 19 2008 9:43 PM by Baklap. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jun 19 2008 4:58 PM
    Issues w/QT Exports
    Hi all,
    Trying to make QT movies out of Avid and I'm noting in the QT player after export that edges of my text and alpha graphics are, well googy.  They look sawtooth as in the image below.   When I then import that QT back into Avid, they edges are "wavy" in the second image.
    Thoughts?
    Thanks for considering!
    Tim Scarpino
    Avid MCA v2.6.4 on HP xw8200 Windows XP SP2 4 gig RAM QT v7.2 [view my complete system specs]
  • Thu, Jun 19 2008 5:10 PM In reply to
    • camoscato
    • Posts 4,498
    • Points 53,765
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Issues w/QT Exports
     Hi Tim,
    That looks like an interlacing problem.  What is your goal with the exported files?  DVD?  Broadcast? Internet?  If we know where you're trying to go we can help get you there.
    good luck,
    Carl
  • Thu, Jun 19 2008 5:13 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,243
    • Points 168,005
      Moderator: MCA Mac
    That also looks like viewing an interlaced image on a progressive monitor. Could that be all this is? Have you tried deinterlacing the QT?
  • Thu, Jun 19 2008 5:19 PM In reply to
     I've just added a Terabyte Storage device to my system and would like to take projects that I MAY want to revisit in the future and archive them to the drive.   Basically if I have a number of clips, string them all together in a sequence, make an uncompressed QT and then store them.
    If I want to bring the stuff back into Avid down the road, I was hoping to simply import the QT.
    I'm trying to avoid the Avid "Same as Source" in case I want to use the QTs somewhere else.
    Make sense?
    Tim
  • Thu, Jun 19 2008 5:24 PM In reply to
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 40
    • Points 520
    Why not use the consolidate command on that sequence you create with the clips you want to keep?
    Media Composer Nitris DX 3.0 Dual 3GHz Quad Mac Pro 4GB Ram 10.5.3, Symphony Nitris DX 3.0 Dual 3GHz Quad Mac Pro 4GB Ram 10.5.3, Unity MediaNet 5.1 [view my complete system specs]
  • Thu, Jun 19 2008 9:28 PM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Rankweil | Austria | Europe
    • Posts 116
    • Points 1,450
    or make a video-/audio downmix and save the mxf file?
    otherwise: if you have your "right" field order ("upper field first" for PAL / "lower field first" for NTSC) for the export AND import, nothing should happen...
    regards - moses
    Avid Adrenaline DNxcel | HP xw8400 - Xeon CPU @ 2.66 GHz - 3GB RAM | easyRAID 4TB | MC 3.0.5 | PDW-U1 (Firmware 2.0) | DVW-M2000P [view my complete system specs]
  • Thu, Jun 19 2008 9:43 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,598
    • Points 78,170
    it's a reversed field order... top field first on uncompressed output.
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
