Latest post Fri, Jun 20 2008 1:52 PM by SPROCKETS. 2 replies.
  • Thu, Jun 19 2008 10:02 AM
    • SPROCKETS
    • Joined on Fri, Nov 18 2005
    • Posts 3
    • Points 35
    HD 23.976 Project ( Shot film 24fps) - Audio Import Issues
    Hi All
    Just wondered if I could run this workflow past people to see what they think.
    I am helping out on a project and they recently started importing rushes on a NEW different Avid.  Currently on the new rushes the audio is currently running slightly faster than the picture, noticeable at around 2 minutes, about 3 frames fast or so.
    When I Untick the Middle Audio Import Box below and re-batch import the clip, it’s then in sync with exactly the same picture. No re-sync clip required. I presume then that I need to keep this box unticked and then re-batch import the sound rushes again
    Is the re-batch import safe to do? It worked on an original sync clip
    Is this workflow actually correct? I thought audio needs to be recorded at 30 NDF
    Is this safe then to proceed for the rest of the post workflow?
    Shooting rate:               24fps
    Sound Recording:         29.97 NDF at 48.048 khz - BWF
    Telecine:                       MOS at 23.976 to HD
    Avid Project:                1080p/23.976 (3 perf)/ 48khz
    Audio Import Settings:  All 3 boxes ticked –                   SR conversion
      SR conversion w/pull-up/pull-down ?????
       Bit Rate conversion
    Many thanks
    Paul
    Assistant Editor
    UK
  • Thu, Jun 19 2008 12:21 PM In reply to
    • MichaelP
    • Boston
    • Posts 1,456
    • Points 18,160
      Moderator: Film
    Re: HD 23.976 Project ( Shot film 24fps) - Audio Import Issues
    The recommended practice for 24.000fps shooting on set would be to record audio at 30fps/48.048kHz for a 23.976 post. That way both get slowed down .1% to create 29.97/48kHz to be in sync with the now 23.976 picture.
    Pull up or pull down deals with the .1% issue when it sees a sample rate other than 48kHz in the header of the BWF file. See http://www.24p.com/AvidInsider2.htm for tools to deal with that if the import settings do not work for you.
    It is safe to rebatch import as you are doing.
    Michael
    HP 8600 Symphony Nitris DX v3 || MBP 15" Media Composer v3 [view my complete system specs]
    ____________ Anything 24fps
  • Fri, Jun 20 2008 1:52 PM In reply to
    • SPROCKETS
    • Posts 3
    • Points 35
    Hi Michael
    Many, many thanks for that.
    So if we are proceeding and still recording sound at 29.97 NDF (not correct- we know) as per workflow above and then unticking the middle audio SR conversion w/pullup,pulldown to import; and files run in sync; and we have done HDcam playout and hd/qt at 23.976 with omf all in sync, then are we ok? Or are there further implications for our sound editors. Do we need to do a 24fps Qucktime/playout test?
    Many thanks again.
    Paul
    Assistant Editor
    UK
