Latest post Thu, Jun 19 2008 1:40 AM by Kenton.VanNatten. 4 replies.
  • Wed, Jun 18 2008 9:23 PM
    • slackp11
    • NYC
    • Posts 97
    • Points 1,285
    External Storage
    When I first started moving media to multiple systems I used the Lacie 500's, but I found even with the firewire 800, the system gets hung up when scrubbing video, and if I've got a lot of effects.  I've got two PC's with 2 terabytes of Raided internal storage, and have been carrying computers to and from separate locations (stupid i know) but was wondering if there was a sata drive or possibly another suggestion?
    Thanks!
    PC Pentium 4 CPU 2.00GHz 2.02GHz, 1.25 GB RAM Windows XP PRO MAC G5 dual 2.7 GHz Power PC 2.5 GB Ram [view my complete system specs]
    PBS godfatherproductions.tv
  • Wed, Jun 18 2008 9:37 PM In reply to
    • jasperfdo
    • Joined on Wed, Oct 11 2006
    • Los Angeles
    • Posts 437
    • Points 5,660
    Re: External Storage
    g-technology.com.
    faster and more reliable than LaCie.
    Dell Precision 690, Intel 3.2GHz Dual Core Xeon (5060)4GB RAM, nVidia Quadro FX 3500 / Media Composer v3.0 / Mojo [view my complete system specs]
    kyler boudreau | www.theatereleven.com
    "Therefore I hated life; because the work that is wrought under the sun is grievous unto me: for all is vanity and vexation of spirit." - ecc 2:17
  • Wed, Jun 18 2008 9:38 PM In reply to
    • Tugger
    • Champaign Illinois USA
    • Posts 380
    • Points 4,725
     If you're working in SD even firewire 400 should be sufficient provided the drives themselves are fast enough. Since you're experiencing stuttering with FW800's I don't think upping it to a SATA or eSATA drive will help. I think Lacie drives tend to be 5400 rpm models, better (and same general price range) are Seagate barracuda series which run at 7200 rpm. I use USB2 connections with seagate pocket drives with my laptop with no problems. If you do want to go the eSATA route there are a number of drive enclosures you can get that have a multiple interface (FW, USB, eSATA) and you could use the faster eSATA connection, but then you'd need to have an external connection on each computer to plug in.
    good luck
    MediaComposer 3 on HP nw9440 (2.17ghz dual proc-nVidia 1500m-4gig RAM) / AXP 5.8 on HP zd8000 (3.2ghz P4 proc-ATI X600-2gig RAM) USB or eSATA external... [view my complete system specs]
  • Wed, Jun 18 2008 9:43 PM In reply to
    • slackp11
    • NYC
    • Posts 97
    • Points 1,285
    thanks for the replies.  All the Lacie drives are 7200rpm.  Was thinking about going the eSata route, and getting a card for the motherboard.  I was just wondering if there was some sort of eSata raid that someone might suggest!
  • Thu, Jun 19 2008 1:40 AM In reply to
    slackp11:
    G-Speed eS from G-Tech...
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 2x500GB Hitachi SATA-II internals various external... [view my complete system specs]
