Latest post Sun, Jun 22 2008 12:34 AM by jwrl. 46 replies.
Page 3 of 4 (47 items) < Previous 1 2 3 4 Next >
  • Thu, Jun 19 2008 6:18 PM In reply to
    • fiendish
    • Posts 221
    • Points 2,675
    Re: Hows MC 3.0 Holding up!
    evansmalley - "Not to mention the dreaded interlacing blocky edges! I think you have a great point, mr. fiendish... I would so love to see MXF/AVI take over QuickTime! I see QuickTime edges on all kinds of stuff- can't believe more purists aren't up in arms!"
    Incidentally, there is a particularly ludicrious option in quicktime player that was only pointed out to me recently. In Edit, Player Preferences there is a "Use high quality video setting when available" checkbox. Make sure this is checked. DV QTs can often look as you describe if it isn't. The option also exists for individual movs in the movie properties dialog. It's a really great option that one. Idiots.
    xw8600 Dual Quad 3ghz - MC 3.0 / QT 7.4.5 with Mojo SDI - 4gb RAM / quadro 3700 and 3ware 9650SE Raid 5 [view my complete system specs]
  • Thu, Jun 19 2008 6:20 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,252
    • Points 168,085
      Moderator: MCA Mac
    Telegram!:
    For some reason, I cannot both Capture via HD-SDI and simultaneously monitor (or record) the letterboxed, SD downconverted signal coming out of the same SD-SDI cable that feeds my SD-SDI monitor perfectly when I'm playing back the 1080i timeline.
    This limitation was introduced late in the Beta process for some reason. Early beta builds could play back with the simultaneous down covert. Don't know why they changed a good thing...Brian might though.
  • Thu, Jun 19 2008 7:57 PM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 854
    • Points 10,565
    BLKDOG:
    Telegram!:
     ....You mean you pay $14,000.00 US and you can't even simultaneously monitor what you're capturing ? Huh?
    EDIT: If this feature could be turned off in beta, then perhaps it could be turned back on ?
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0.5. Also added Avid Studio Toolkit 5.7 running on.....HP Compaq nw 9440 Laptop PC w/2... [view my complete system specs]
  • Thu, Jun 19 2008 8:06 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,252
    • Points 168,085
      Moderator: MCA Mac
    No...no. IT shows up in the record monitor and an HD monitor, just not in an SD downconvert.
  • Thu, Jun 19 2008 9:07 PM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 385
    • Points 4,630
    fiendish:
    I confirmed this by mistake recently by installing OSX on my PC
    How'd you do that?
    I have 10 Avid systems, DX, Meridian and DNA. 1 MCA 1.8 on 2.5 quad G5 w/ 5 Gigs of Ram, 1 Symphony Nitris DX on eight core mac pro with 4 gig ram, 1 MC... [view my complete system specs]
    Andy
  • Thu, Jun 19 2008 9:34 PM In reply to
    • fiendish
    • Posts 221
    • Points 2,675
    long story. all part of the shadowy world of hackintoshing.
    http://forum.insanelymac.com/index.php?s=b563603b83e24736d10c35e3753c4893&
  • Thu, Jun 19 2008 10:02 PM In reply to
    evansmalley:
    let's get up a pro-Avid, anti-QuickTime vigilante rabble
    I have a pitchfork and some serious explosions in the FX files
    It is not necessary to defend QT. I don't get why people get upset that QT can't play certain files in RT. First, QT is a general purpose media player so one should expect that it has certain limitations. Second, Avid should be able to play DNxHD better. It is their own format.
    That being said, Brian Williams is right. QT just needs to be updated to take advantage of multi core systems and newer GPU features. With the announcement of Snow Leopard, I'm sure Apple is working hard to update FCP and QT's engine to take advantage of these new technologies.
  • Fri, Jun 20 2008 2:14 AM In reply to
    • Laptopeditor
    • Montreal, Canada
    • Posts 854
    • Points 10,565
    Dom Q. Silverio:
    ...I hope we in PC Avid land will see the trickle down from the QT Apple update.Big Smile
  • Fri, Jun 20 2008 2:18 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,311
    • Points 38,030
    Don't hold your breath!
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
  • Fri, Jun 20 2008 2:54 AM In reply to
    • Laptopeditor
    • Montreal, Canada
    • Posts 854
    • Points 10,565
    jwrl:
     ...Wink
  • Fri, Jun 20 2008 3:12 AM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,205
    • Points 13,405
    For this reason I love my P2 ingest It can't be beaton...
    MC 3.0 AXP 5.8.3 QTime 7.3 win xp pro service pak 2 Core 2 Duo Quad core 2.4 clocked to 3.1 4 gig ram 667mhz pci x nvidia 512mb geforce 8600 162... [view my complete system specs]
  • Fri, Jun 20 2008 10:57 AM In reply to
    • fiendish
    • Posts 221
    • Points 2,675
    Well perhaps Brian could confirm this but it seems QT is already multithreaded on the mac, in which case perhaps they don't intend to port it to PC.
  • Fri, Jun 20 2008 4:57 PM In reply to
    • Telegram!
    • Joined on Wed, Jun 28 2006
    • nyc
    • Posts 15
    • Points 205
    BLKDOG:
    Telegram!:
    Thanks for clearing that up, BLKDOG- I'm glad I have one less thing to think about.
    Win XP Pro version 2002 SP2; HP 8600 Xeon 5450@3.0Ghz, 3.25GB ram; quadro FX3700 driver= 6.14.11.6947; Composer Nitris DX, Video Raid ST 5x1TB [view my complete system specs]
  • Fri, Jun 20 2008 9:55 PM In reply to
    Fiendish,
    There is a good chance that parts of QT is multithreaded on the PC, too.  But it's more of an old-school style of multithreading, which worked fine in the days of 2 cores, maybe 4.
    old-school multithreading involves looking for parts of your code that you can parallelize and then run those in multiple threads.  Normally that's done on an algorythm level (for example, processing a filter which creates a blur).
    But normally, those parts are followed by parts that can't be parallelized.  This is called forking and joining.  Think about a single lane highway that suddenly becomes 8 lanes (forking) for short bits of time and then merges back down to one lane (joining).  If those lanes were cores on a CPU a good part of the time your cores are waiting around for more work to do.  Also, quite often, the join has to wait until all parts of the fork have completed.
    We've been focused on multicore and multidomain (CPU vs GPU) scalability for over 2 years now.
    Instead of parallelizing an alogorythm, we parallelize a pipeline.  Our video player is constantly do its best to process multiple frames at once.  This means that while one frame may be less busy at one of those join points, we have several other frames that are waiting to get work done.
    So back to QuickTime... what we can't do is ask QuickTime to decompress multiple frames at once.  We have to ask for each frame in a serial manner.
    I am not saying there is isn't more that we can do to improve performance.  We will certainly continue to look to improve performance where we can, it's a matter of time and prioritization.
    Brian Williams
    Principal Software Engineer
    Media Products Group
    Avid Technology, Inc.
    "Be a non-conformist like me!"
  • Sat, Jun 21 2008 11:50 AM In reply to
    • fiendish
    • Posts 221
    • Points 2,675
    Thanks Brian, you've made that very clear. Does AVI work in the same way? would there be anything to gained by implementing Avid Codecs within an AVI wrapper?
